I need help to set up multiple ZED 2i cameras in a scenario. I have 4 cameras and I want to record all 4 simultaneously but i don’t know what is the best hardware configuration for this. Basically I need to get 4 svo files recorded for a scene with enough quality (30 or 60 fps) - no need
Can i do this with only a PC? I need extra hardware like a zed box?
I did some tests and I only managed to record two of them. Anyone did some test with a similar configuration?
My problem is that I have a laptop and in that case the USB ports are sharing the internal USB bus. Let’s see if I can find a solution to extend the capacity of USB channel
