Is the Zed Link Mono Capture Card compatible with the Jetson Xavier AGX developer kit? It is not listed under the compatible boards, but the board is stated to be “compatible with all Jetson Orin and Xavier models”. If it is compatible, would any adaptor be required (22-pin to 15-pin)?
Hi @aayushg55,
I apologize, the ZED Link Mono Capture Card is not compatible with AGX Orin or Xavier AGX developer kits.
Thank you for the report, we will update the website accordingly.
Is there any plan for future support? We are considering using an Orin AGX but only need one camera and don’t really want to spend an extra $200 for the dual link capture card. Creating/supplying an adapter from the AGX CSI port to the 22pin csi port is not an issue.
