Module 'pyzed.sl' has no attribute 'SENSING_MODE'
As I see, sensing mode is not a parameter of pyzed module anymore but unfortunately I couldn’t find a new parameter to use instead of sensing mode. Can you help me if you know?
by default SDK 4.X behaves as the previous STANDARD sensing mode.
to use the sensing mode fill you can should now use the var enable_fill_mode
Okay, I got it. Thank you so much
[Discourse post]
