Hi @Myzhar, thanks for the response. I copied the diagnostic file in here:
"AI Models": {
"info": [
"NEURAL DEPTH is not optimized"
"Camera Test": {
"InternalDevicesCount": 2,
"ZEDCount": 1,
"camera": {
"Device ID": 0,
"Firmware": 1523,
"Init Output": "OK",
"Model": "ZED 2i",
"Serial Number": 37382940,
"valid": [
"<b>Camera: </b>ZED 2i",
"<b>Firmware: </b>1523"
"resolutions": {
"HD1080@15": {
"fps (input)": 15,
"fps (output)": 15,
"height (input)": 1080,
"height (output)": 1080,
"initialization": "OK",
"status": true,
"width (input)": 1920,
"width (output)": 1920
"HD1080@30": {
"fps (input)": 30,
"fps (output)": 25,
"status": true,
"HD2K@15": {
"fps (input)": 15,
"fps (output)": 15,
"height (input)": 1242,
"height (output)": 1242,
"status": true,
"width (input)": 2208,
"width (output)": 2208
"HD720@15": {
"fps (input)": 15,
"fps (output)": 15,
"height (input)": 720,
"height (output)": 720,
"status": true,
"width (input)": 1280,
"width (output)": 1280
"HD720@30": {
"fps (input)": 30,
"fps (output)": 28,
"status": true,
"HD720@60": {
"dropCount": 0,
"fps (input)": 60,
"fps (output)": 41,
"imageCount": 500,
"status": true,
"tearingCount": 0,
"VGA@100": {
"fps (input)": 100,
"fps (output)": 65,
"height (input)": 376,
"height (output)": 376,
"status": true,
"width (input)": 672,
"width (output)": 672
"VGA@15": {
"fps (input)": 15,
"fps (output)": 15,
"status": true,
"VGA@30": {
"fps (input)": 30,
"fps (output)": 30,
"status": true,
"VGA@60": {
"fps (input)": 60,
"fps (output)": 41,
"status": true,
"sensors": {
"Firmware": 777,
"Model": "ZED 2i (MCU)",
"Graphics Card": {
"deviceCount": 1,
"deviceDriverVersion": 10020,
"devices": [
"arch": "Kepler",
"computeCapability": "3.0",
"cores": 1344,
"name": "Quadro K4200",
"totalMemoryBytes": "4294967296",
"totalMemoryMB": 4096
"initResult": 0,
"valid": [
"<b>Graphics card: </b> Quadro K4200"
"Processor": {
"avxSupported": true,
"coreCount": "4",
"cpu": "Intel(R) Xeon(R) CPU E5-1620 v3 @ 3.50GHz",
"datetime": "2025-02-11 16:56:54",
"hyperThreading": "1",
"motherboard": "0K240Y, Dell Inc.",
"ramCapacity": "63.924",
"ramUsage": "1.30078e-311",
"ramUsed": "10.4581",
"threadCount": "8",
"valid": [
"<b>Processor: </b> Intel(R) Xeon(R) CPU E5-1620 v3 @ 3.50GHz",
"<b>Motherboard: </b> 0K240Y, Dell Inc."
"USB": {
"ASMediaFound": false,
"CorruptedFirmware": false,
"MCUDetected": true,
"OC_Cam_Detected": false,
"OtherUSBDevices": [
"USBList": [
"USB_path": "/6",
"idProduct": "0x1010",
"idVendor": "0x413c"
"USB_path": "/6/4",
"idProduct": "0x2110",
"USBMode": 3,
"USB_path": "/16",
"bDescriptorType": 1,
"bDeviceProtocol": 1,
"bLength": 18,
"bMaxPacketSize0": 9,
"bNumConfigurations": 1,
"bcdDevice": "1.0",
"bcdUSB": "3.0",
"bcdUSBClass": 239,
"bcdUSBSubClass": 2,
"busNumber": 2,
"device": "ZED2i",
"iManufacturer": 1,
"iProduct": 2,
"iSerial": 4,
"idProduct": "0xf880",
"idVendor": "0x2b03"
"USBMode": 2,
"USB_path": "/5/2",
"bDeviceProtocol": 0,
"bLength": 18,
"bMaxPacketSize0": 64,
"bcdDevice": "3.9",
"bcdUSB": "2.0",
"bcdUSBClass": 0,
"bcdUSBSubClass": 0,
"busNumber": 2,
"device": "ZED2i MCU",
"iManufacturer": 1,
"iProduct": 2,
"iSerial": 3,
"idProduct": "0xf881",
"USB_path": "/6/1",
"idProduct": "0x301a",
"USB_path": "/5",
"idProduct": "0x2512",
"idVendor": "0x0424"
"USB_path": "/1",
"idProduct": "0x800a",
"idVendor": "0x8087"
"USB_path": "/1",
"idProduct": "0x8002",
"USBMode": 3,
"ZED Camera Module Detected": 63616,
"ZED MCU Module Detected": 63617,
"ZEDDetected": true,
"captureDevices": [
"controllers": [
"CompatibleIDs": "USB\\USB20_HUB",
"Description": "Generischer USB-Hub",
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0011",
"Location": "Port_#0006.Hub_#0003",
"Manufacturer": "(Standardm ige USB-HUBs)",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-3"
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0009",
"Location": "Port_#0008.Hub_#0003",
"Name": "USB",
"PhysicalName": ""
"CompatibleIDs": "",
"Description": "USB-Root-Hub",
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0003",
"Location": "",
"Manufacturer": "(Standard-USB-Hostcontroller)",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-1"
"CompatibleIDs": "PCI\\VEN_8086&DEV_8D31&REV_05",
"Description": "USB-xHCI-kompatibler Hostcontroller",
"DeviceName": "Intel(R) USB 3.0 eXtensible-Hostcontroller \u0013 1.0 (Microsoft)",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0000",
"Location": "PCI-Bus 0, Ger t 20, Funktion 0",
"Manufacturer": "Generischer USB-xHCI-Hostcontroller",
"Name": "PCI",
"PhysicalName": "\\Device\\NTPNP_PCI0068"
"Description": "USB-Root-Hub (USB 3.0)",
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0005",
"Location": "",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-0"
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0004",
"Location": "",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-2"
"CompatibleIDs": "PCI\\VEN_8086&DEV_8D2D&REV_05",
"Description": "Intel(R) C610 series/X99 chipset USB Enhanced Host Controller #2 - 8D2D",
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0001",
"Location": "PCI-Bus 0, Ger t 26, Funktion 0",
"Manufacturer": "INTEL",
"Name": "PCI",
"PhysicalName": "\\Device\\NTPNP_PCI0073"
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0015",
"Location": "Port_#0014.Hub_#0003",
"Name": "USB",
"PhysicalName": ""
"CompatibleIDs": "USB\\COMPAT_VID_8087&Class_09&SubClass_00&Prot_00",
"Description": "Generic USB Hub",
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0007",
"Location": "Port_#0001.Hub_#0001",
"Manufacturer": "(Generic USB Hub)",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-4"
"CompatibleIDs": "PCI\\VEN_8086&DEV_8D26&REV_05",
"Description": "Intel(R) C610 series/X99 chipset USB Enhanced Host Controller #1 - 8D26",
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0002",
"Location": "PCI-Bus 0, Ger t 29, Funktion 0",
"Name": "PCI",
"PhysicalName": "\\Device\\NTPNP_PCI0077"
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0008",
"Location": "Port_#0001.Hub_#0002",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-5"
"valid": [
"<b>USB Bandwidth: </b> OK"
"ZED SDK": {
"CUDA Toolkit version": "V10.2.89 -->located in C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v10.2/bin/nvcc.exe",
"CUDA loading": false,
"CUDA_reachable": true,
"ZED SDK Version (Diag)": "3.7.7",
"ZED SDK Version (RT)": "3.7.7",
"ai": {
"checkAI": true,
"cudaVersion": 10020,
"cudnnCudartVersion": 10020,
"cudnnVersion": 8204,
"cudnnVersionExpected": 8204,
"tensorVersion": 8200
"binFiles": [
"cudnn64_8.dll",
"cudnn_adv_infer64_8.dll",
"cudnn_adv_train64_8.dll",
"cudnn_cnn_infer64_8.dll",
"cudnn_cnn_train64_8.dll",
"cudnn_ops_infer64_8.dll",
"cudnn_ops_train64_8.dll",
"nvinfer.dll",
"nvinfer_builder_resource.dll",
"nvinfer_plugin.dll",
"nvonnxparser.dll",
"nvparsers.dll",
"sl_ai64.dll",
"sl_zed64.dll",
"zlibwapi.dll"
"driverVersion": "441.22",
"drivervDllVersion": "26.21.14.4122",
"resourcesFiles": [
"objects_performance_2.2.model"
"resourcesFilesExpected": [
"objects_performance_2.2"
"runtimeDllVersion": 10020,
"valid": [
"<b>ZED SDK version:</b> 3.7.7",
"<b>CUDA version:</b> V10.2.89"
