Hello, I have an application in which I want to inspect an object from two sides with two ZED2i cameras. Is there a way how I can merge the point cloud of the two cameras?
Hi @Phyrokar
You can use external libraries to manage point clouds:
- Open3D: http://www.open3d.org/ (methods)
- PCL: https://pointclouds.org/ (methods)
the algorithm that you need is called Iterative Closest Point (ICP). There are many variants available, I suggest you to test them all to find the one that better fits your requirements.
