Low Bandwidth error
any possible solution yet?
OK, this confirms that they are on different channels.
Please check the connectivity of the cameras.
Is the failing camera always the same? Have you tried to change/switch the USB3 cable?
Are the screws of the USB3 connector strongly strengthened?
it’s always the same camera that’s failing.
Suppose 2 2i as camA and camB, and it’s cable cableA and cableB
I tried camA-cableA, camB-cableB where camA failed
and then camA-cableB, camB-cableA, where camA failed again
i reconnected cable many times, and each time screws on the connector was strengthen with flathead screwdriver
Is the camera working correctly when used “alone” in single camera configuration?
If you are facing errors also in these conditions, please write an email to support@stereolabs.com with a link to this discussion.
it used to work alone before, but not anymore.
I’ll try to contact the support team
