Hello! I’m using the spatial mapping code provided in the ZED SDK examples on GitHub. As you know, that code does live spatial mapping and generates the map (mesh/fused point cloud) live and displays in onto the OpenGL window.
What I want to achieve is that instead of generating the map live, I would like to load an existing saved map (.obj file) and display it the same way as the live map is displayed. So basically I don’t want to generate the map when I run the code, I just want to display an existing map the same way as it happens on Zed FU tool. I am aware that there’s sl.Mesh.load() or sl.FusedPointCloud.load() functions in the sdk to load a .obj file and I have been able to load the .obj files successfully into my code using those. But I am not sure what to do further after loading it.
What changes to the spatial mapping code would be needed? Or what approach should I take? I really need help with this and would appreciate any guidance! Looking forward to your response. Thankyou so much!!
