Hi I’m building a robot that is controlled by a remote operator using a VR headset. I’m trying to reduce video latency as much as possible. I’m not interested in passing any depth points or any other non visual data to the operator
- To achieve the least latency possible to a remote operator (while retaining useable resolution), what setup would you recommend?
A. ZED Mini (56ms minimum latency using Jetson Xavier - source)
B. ZED X Mini (are there any comparable real world latency tests with this?)
C. Some other setup
