Jetson Xavier Wifi Module
Is there a way I can connect a wireless wifi module to the Stereolabs Jetson Xavier? I have an M2 wif/bluetooth card, I have installed it on a Jetson Nano, but I cannot see the port to connect it to on the Xavier. Is there another method to get wireless wifi on the Xavier? Thanks!
Hi @jacobnihsal
You cannot open the ZED Box to install an M.2 card, otherwise, you will void the warranty.
Furthermore, our custom carrier board has no available M.2 ports to install the WiFi card. The M.2 slot is used for the SSD memory.
You can add a USB adapter, we tested and validated a few modules:
