Successfully got the body tracking ai model installed on a local windows computer, however when trying to run and install the object detection model the terminal gets stuck on the optimizing the AI model for the graphics card.
Is it possible to uninstall and redownload the AI model? If so, which directory is the AI model information stored?
Is there any solution to a model stuck in optimization? I’m having a strange problem on just one specific computer. Other models, such as the body tracking, work perfectly fine.
The model optim should not be stuck forever, it either ends successfully, fails or crashes. It may take longer to optimize. What are the specifications of your computer ?
You can also run the ZED Diagnostic tool and share the result here.
Strangely on this Windows device it took about an hour before the optimization completed, but it eventually got there and all is working now. 2060 Graphics Card.
