Isaac sim zed camera integration with goal to implement navigation ROS2
Help Needed: TF Issues with ZED Camera Integration in Isaac Sim
Hi everyone,
I’m working on a robotics project where I imported a robot model into Isaac Sim using the Onshape CAD importer (.usdc format). I’m now trying to integrate the ZED camera for navigation.
What’s working:
  • ZED ROS 2 wrapper is installed and running.
  • Isaac Sim streamer node is added.
  • I can successfully visualize stereo images and point cloud in RViz.
  • I’ve followed the available documentation and community examples.
The problem: The main issue starts when I try to use Nav2 for navigation. In RViz, I see TF flickering between the robot and the ZED camera.
TF Conflict:
  • Isaac Sim creates a correct TF chain: odom → base_link → robot parts.
  • But the ZED wrapper adds its own TF frames (like camera_center, zed_camera_left_frame) that appear to float in space.
  • These frames are not part of my robot’s USD file and there are no matching xform prims in the ZED USD provided by Stereolabs — but they are still published by the wrapper also can be seen in the launch file .
This leads to conflicts in the TF tree, causing flickering in RViz and unstable behavior in Nav2.
What I want:
  • I don’t want to rebuild the robot using URDF or XACRO.
  • I just want to:
    • Attach the ZED camera properly under base_link in Isaac Sim.
    • Make sure the TF tree is clean and consistent: odom → base_link → zed_camera_link.
I’ve tried:
  • Disabling TF broadcasting from the ZED wrapper.
  • Manually editing the ZED launch file and adding base_link as a parent in urfd_des.urdf.xacro under the wrapper
  • Turning off map → odom transform.(as nav2 AMCL will create this )
odom to base link isaac sim action graoh will do it
Still, I see invalid or duplicate TFs in RViz. I’m sure I followed the documentation carefully, but something’s still off.
My Questions: Has anyone faced similar TF problems when integrating the ZED camera in Isaac Sim (especially with Onshape-exported models)?
Can anyone suggest:
  • How to disable or remap the TFs published by the ZED wrapper?
  • How to ensure the ZED camera is correctly attached to the robot body in the TF tree?
  • How to verify in RViz that all TF joints are properly connected to base_link?
Any help or tips would be greatly appreciated. Thank you!
tried to add base_link(i expect the base_link of my_robot not any others) in zed_desc.urdf
<robot name="stereolabs_camera" xmlns:xacro="http://ros.org/wiki/xacro">
  <!-- Arguments -->
  <xacro:arg name="camera_name" default="zed" />
  <xacro:arg name="camera_model" default="zed" />
  <xacro:arg name="custom_baseline" default="0.0" />
  <xacro:arg name="enable_gnss" default="false" />
  <xacro:arg name="gnss_x" default="0.0" />
  <xacro:arg name="gnss_y" default="0.0" />
  <xacro:arg name="gnss_z" default="0.0" />
  <xacro:arg name="use_zed_localization" default="false" />
  <!-- Include ZED camera macro -->
  <xacro:include filename="$(find zed_wrapper)/urdf/zed_macro.urdf.xacro" />
  <!-- Instantiate the camera -->
  <xacro:zed_camera
      name="$(arg camera_name)"
      model="$(arg camera_model)"
      custom_baseline="$(arg custom_baseline)"
      enable_gnss="$(arg enable_gnss)">
    <origin xyz="$(arg gnss_x) $(arg gnss_y) $(arg gnss_z)" rpy="0 0 0"/>
  </xacro:zed_camera>
  <!-- Add joint connecting camera to base_link -->
  <xacro:if value="$(arg use_zed_localization)">
    <joint name="$(arg camera_name)_joint" type="fixed">
      <parent link="$(arg camera_name)_camera_link"/>
      <child link="base_link"/>
      <origin xyz="-0.12 0.0 -0.25" rpy="0 0 0"/>
    </joint>
  </xacro:if>
  <xacro:unless value="$(arg use_zed_localization)">
      <parent link="base_link"/>
      <child link="$(arg camera_name)_camera_link"/>
      <origin xyz="0.12 0.0 0.25" rpy="0 0 0"/>
    </joint>
  </xacro:unless>
</robot>
set this parameters in common_stero.yaml
pos_tracking:
            pos_tracking_mode: 'GEN_1' # Matches the ZED SDK setting: 'GEN_1', 'GEN_2'
            imu_fusion: false # enable/disable IMU fusion. When set to false, only the optical odometry will be used.
            publish_tf: false or true tried both # [overwritten by launch file options] publish `odom -> camera_link` TF
            publish_map_tf: false # [overwritten by launch file options] publish `map -> odom` TF
            map_frame: 'map'
            odometry_frame: 'odom'
            area_memory_db_path: ''
in launch file added this
  xacro_command.append(' ')
    xacro_command.append('use_zed_localization:=')
    xacro_command.append(use_zed_localization.perform(context))
'publish_urdf',
                default_value='true',
                description='Enable URDF processing and starts Robot State Published to propagate static TF.',
                choices=['true', 'false']),
            DeclareLaunchArgument(
                'publish_tf',
                default_value='true or false doesnt give the camera loction , ',
                description='Enable publication of the `odom -> camera_link` TF.',
                'publish_map_tf',
                default_value='false',
                description='Enable publication of the `map -> odom` expect from nav2 launch
Hi @DevadasVijayanSheela
The reasons of this problem are well explained in the tutorial that you linked.
If you want to use localization nodes from Nav2 you must set the use_zed_localization option to FALSE.
Nothing else is required.
