I want to run zed unity livelink to send data to Unity, and body tracking to display the real-world cam and skeleton representation on top of the people in the frame at the same time. I can probably make the applications into a single application, but is it possible to run both at the same time? I get “Camera not detected” now if I try to run both, but are there some easy adjustments to make it work?
@haakonflaar
The ZED cameras are only usable by one application at a time.
I don’t think there are easy adjustments to improve this, it’s the normal behavior for a device like this (like if you made an app with any camera, you would not be able to see the video stream in another application).
