I am planning to use a ZED X camera with a Jetson AGX Orin mounted on an Avermedia D315-1 board (using a ZED Link Duo and JetPack 5.1.2). On the driver installation page, the section for “3rd party embedded computers” indicates “Contact partner.” Could you please clarify whether I should reach out to the partner (Avermedia) directly, or if I should instead install the driver for JetPack 5.1.2 provided on the Stereolabs website?
Hi @ljs9605,
“Should I contact Avermedia directly, or install the JetPack 5.1.2 driver from the StereoLabs website?”
Please contact Avermedia support directly. The ZED Link Duo drivers on our drivers page are built for the NVIDIA Jetson AGX Orin Developer Kit carrier board. The D315-1 needs a driver made for its own hardware configuration, so the standard JetPack 5.1.2 package won’t work on it.
That is why the “3rd Party Embedded Computers” table says “Contact partner” for the Avermedia D315 with the ZED Link Duo. Avermedia can give you the right driver for your board and JetPack version.
You can also have us grant you access to the GitHub repository with the ZED X Driver source code and all the relevant documentation, once a mutual NDA is signed. Would this arrangement work for you?
