Inconsistent localisation with ZED X
I have the Jetson AGX Orin running the latest Jetpack version and the ZED SDK. First things first, I’ve tried mapping the room I was in using the ZEDfu tool included with the SDK.
It created an approximate model of the space good enough for the conditions. I couldn’t move around a lot, as the camera had to stay connected to the computer and the monitor to record. After a few minutes of looking around the room from a stationary point, the camera lost its sense of location and placed itself 0.5m away from the right position. Then, it continued to record false data and litter the previously constructed map.
I have also tried using the Ros2 wrapper and RTAB-Map + RVIZ to scan the room, but while frames of the scan were fairly accurate, in just a few seconds it created multiple versions of the scene, shifted in random directions and orientations.
How can I make the process more stable and get better results?
Hi @elekes.peter
The mapping process requires that you move the camera around to obtain all the required information. A constraint, like the one you described, can invalidate the process.
Please add more information about your configuration.
