i have checked depth value accuracy using zed2i
real distance from wall is 1m but calculated value using depth map is 0.65m
(distance with mono camera using opencv is 1.02m)
how to improve accuracy of depth value?
*** code ***
import cv2
import pyzed.sl as sl
import numpy as np
from utils import *
def main():
# ZED camera init
zed = sl.Camera()
# set camera params
init_params.camera_resolution = sl.RESOLUTION.HD1080
init_params.depth_mode = sl.DEPTH_MODE.ULTRA # Use ULTRA depth mode
# open camera
err = zed.open(init_params)
print(f"Error, unable to open ZED camera: {err}")
zed.close()
return 1
camera_info = zed.get_camera_information().camera_configuration
image_size = camera_info.resolution
image_zed = sl.Mat(image_size.width, image_size.height, sl.MAT_TYPE.U8_C4)
image_ocv_rgb = np.zeros((image_size.height, image_size.width, 3), dtype=np.uint8)
depth_map = sl.Mat(image_size.width, image_size.height, sl.MAT_TYPE.F32_C1)
point_cloud = sl.Mat()
runtime_parameters.enable_fill_mode
calib_info = camera_info.calibration_parameters.left_cam
camera_matrix = np.array([[1067.17, 0, 959.66],
[0, 1067.9, 535.059],
[0, 0, 1]])
dist_coeffs = np.array(([-0.0727677727482817, 0.06090582313382647, 6.853173013136698e-06, 0.00022630862399272667]))
dictionary = cv2.aruco.getPredefinedDictionary(cv2.aruco.DICT_7X7_1000)
print(calib_info.fx, calib_info.fy, calib_info.cx, calib_info.cy)
key = '.'
while key != ord('q'):
# Retrieve the left image
zed.retrieve_image(image_zed, sl.VIEW.LEFT, sl.MEM.CPU)
zed.retrieve_measure(depth_map, sl.MEASURE.DEPTH) # Retrieve depth
zed.retrieve_measure(point_cloud, sl.MEASURE.XYZRGBA, sl.MEM.CPU, image_size)
frame = image_zed.get_data()
# convert to RGB
image_ocv_rgb = cv2.cvtColor(frame, cv2.COLOR_RGBA2RGB)
image_gray = cv2.cvtColor(frame, cv2.COLOR_RGBA2GRAY)
# detect marker
corners, ids, _ = cv2.aruco.detectMarkers(image_gray, dictionary)
for corner in corners:
cv2.polylines(image_ocv_rgb, [corner.astype(np.int32).reshape((-1, 1, 2))], True, (0, 255, 0), 2)
if ids is not None and len(ids) > 1:
origin_center ,centers, tvecs, rvecs = marker(corners,ids, camera_matrix, dist_coeffs)
print(f'original center : {origin_center}')
print(f'center : {centers}')
print(f'tvecs : {tvecs}')
_, origin_center_depth = depth_map.get_value(origin_center[0], origin_center[1])
_, center_depth = depth_map.get_value(centers[0][0], centers[0][1])
print(f'origin_center_depth:{origin_center_depth}')
print(f'center_depth : {center_depth}')
err_1, origin_pcd = point_cloud.get_value(origin_center[0], origin_center[1])
err_2, center_pcd = point_cloud.get_value(centers[0][0], centers[0][1])
# print(f'origin_pcd = {origin_pcd}')
# print(f'center_pcd = {center_pcd}')
# image_ocv_rgb, relative_position, relative_rvec = cal_distance(image_ocv_rgb, origin_center ,centers, tvecs, rvecs)
# Display image
cv2.imshow("Image", image_ocv_rgb)
# Handle key event
key = cv2.waitKey(10)
zed.close()
return 0
if name == “main”:
main()
