Hello, I record using 2 ZED cameras and I do not have any problems. But I want to set the exposure value to 1 and the gain value to automatic. I changed my code for this, but with this code, exposure and gain values are not adjusted. The camera continues to record normally. I share my code below. What should I do??
this is my code:
// ZED includes
#include <sl/Camera.hpp>
// Sample includes
#include "utils.hpp"
// Using namespace
using namespace sl;
void runner(sl::Camera& zed, bool& exit, int id) {
RecordingParameters rec_p;
rec_p.compression_mode = SVO_COMPRESSION_MODE::H264;
auto cam_infos = zed.getCameraInformation();
auto SN = cam_infos.serial_number;
std::string svo_name("SVO_SN" + std::to_string(SN) + ".svo");
// Enable recording with the filename specified in argument
rec_p.video_filename = String(svo_name.c_str());
auto err = zed.enableRecording(rec_p);
if (err != ERROR_CODE::SUCCESS)
std::cout << "ZED [" << id << "] can not record, " << err << std::endl;
int fps = cam_infos.camera_configuration.fps;
std::cout << "ZED[" << id << "]" << " Start recording "<< cam_infos.camera_configuration.resolution.width<<"@"<< fps <<"\n";
int frames_recorded = 0;
int nb_grabbed = 0;
auto start = std::chrono::high_resolution_clock::now();
sl::RecordingStatus state;
while (!exit) {
if (zed.grab() == ERROR_CODE::SUCCESS) {
// Each new frame is added to the SVO file
if (1) {
state = zed.getRecordingStatus();
if (state.status) frames_recorded++;
nb_grabbed++;
if ((nb_grabbed % fps) == 0)
std::cout << "Z" << id << ": " << nb_grabbed << "\n";
zed.disableRecording();
auto stop = std::chrono::high_resolution_clock::now();
auto duration = std::chrono::duration_cast<std::chrono::milliseconds>(stop - start).count();
int nb_frame_theoric = (duration / 1000.f) * fps;
std::cout << "Recording status ["<< id<<"]: theoric " << nb_frame_theoric << ", grabed " << nb_grabbed << ", saved " << frames_recorded << " frames, avg compression time "<< state.average_compression_time<<"ms\n";
// Set configuration parameters for the ZED
InitParameters initParameters;
std::cout << "ARG 2: RESOLUTION ID: 0:2K / 1:FHD / 3:HD / 3:VGA" << std::endl;
if (argc >= 2)
initParameters.camera_resolution = static_cast<RESOLUTION>(atoi(argv[1]));
std::cout << "Open Camera in: " << initParameters.camera_resolution << std::endl;
initParameters.depth_mode = DEPTH_MODE::NONE;
if(argc == 3)
initParameters.camera_fps = atoi(argv[2]);
const int NB_ZED = Camera::getDeviceList().size();
// Create a ZED camera
std::vector<Camera> zeds(NB_ZED);
std::vector<std::thread> pool(NB_ZED);
std::cout << "Try to open " << NB_ZED << " ZEDs\n";
for (int z = 0; z < NB_ZED; z++) {
initParameters.input.setFromCameraID(z);
// Open the camera
ERROR_CODE err = zeds[z].open(initParameters);
if (err != ERROR_CODE::SUCCESS) {
std::cout << "ZED [" << z << "] can not be opened, " << err << std::endl;
else {
// Set exposure and gain here for each camera
zeds[z].setCameraSettings(sl::VIDEO_SETTINGS::EXPOSURE, 1);
zeds[z].setCameraSettings(sl::VIDEO_SETTINGS::GAIN, sl::VIDEO_SETTINGS_VALUE_AUTO);
std::cout << "Exposure value is set to 1, gain value is auto for ZED " << z << std::endl;
// Start recording SVO, stop with Ctrl-C command
std::cout << "SVO is Recording, use Ctrl-C to stop." << std::endl;
SetCtrlHandler();
if(zeds[z].isOpened())
pool[z] = std::thread(runner, std::ref(zeds[z]), std::ref(exit_app), z);
while (!exit_app)
sl::sleep_us(50);
if (zeds[z].isOpened())
if(pool[z].joinable())
pool[z].join();
zeds[z].close();
return 0;
