hannah
                    February 12, 2025,  3:04pm
              1
              I installed zed sdk on the docker image, and also installed ros2 foxy.
The main body is jetson orin, and i’m using jetpack 5.1.2.
ros2 launch zed_wrapper zed_camera.launch.py camera_model:=zedxm
The above command was entered to execute the zed node, but an error occurred.
[component_container-2] [ZED-X][Warning] Failed to connect to zed_x_daemon.
[component_container-2] [INFO] [1739356886.936725056] [zed.zed_node]: Advertised on topic: /zed/zed_node/pose
[component_container-2] [INFO] [1739356886.938627340] [zed.zed_node]: Advertised on topic: /zed/zed_node/pose/status
[component_container-2] [INFO] [1739356886.940718970] [zed.zed_node]: Advertised on topic: /zed/zed_node/pose_with_covariance
[component_container-2] [INFO] [1739356886.943451948] [zed.zed_node]: Advertised on topic: /zed/zed_node/odom
[component_container-2] [INFO] [1739356886.946366846] [zed.zed_node]: Advertised on topic: /zed/zed_node/path_map
[component_container-2] [INFO] [1739356886.948761902] [zed.zed_node]: Advertised on topic: /zed/zed_node/path_odom
[component_container-2] [INFO] [1739356886.951692513] [zed.zed_node]: Advertised on topic: /zed/plane_marker
[component_container-2] [INFO] [1739356886.954009520] [zed.zed_node]: Advertised on topic: /zed/plane
[component_container-2] [INFO] [1739356886.956000732] [zed.zed_node]: Advertised on topic: /zed/zed_node/imu/data
[component_container-2] [INFO] [1739356886.957693767] [zed.zed_node]: Advertised on topic: /zed/zed_node/imu/data_raw
[component_container-2] [INFO] [1739356886.959605396] [zed.zed_node]: Advertised on topic: /zed/zed_node/temperature/imu
[component_container-2] [INFO] [1739356886.961347935] [zed.zed_node]: Advertised on topic: /zed/zed_node/left_cam_imu_transform
[component_container-2] [INFO] [1739356886.961870914] [zed.zed_node]: Camera-IMU Translation:
[component_container-2]  0 -0.034502 -0.004356
[component_container-2] [INFO] [1739356886.962529127] [zed.zed_node]: Camera-IMU Rotation:
[component_container-2] FFFFF130CFB0
[component_container-2] 1.000000 0.000044 -0.000001
[component_container-2] -0.000044 0.999990 -0.004523
[component_container-2] 0.000000 0.004523 0.999990
[component_container-2] [INFO] [1739356886.963681358] [zed.zed_node]: *** Subscribers ***
[component_container-2] terminate called after throwing an instance of 'rclcpp::exceptions::InvalidTopicNameError'
[component_container-2]   what():  Invalid topic name: topic name must not be empty string:
[component_container-2]   ''
[component_container-2]    ^
[ERROR] [component_container-2]: process has died [pid 233, exit code -6, cmd '/opt/ros/foxy/lib/rclcpp_components/component_container --ros-args -r __node:=zed_container -r __ns:=/zed'].
Could you help me …? please…
                Myzhar
                    February 12, 2025,  3:28pm
              2
              Are you using ROS 2 Foxy?
Please read this:
        opened 04:24PM - 05 Dec 24 UTC
          bug
          Stale
    ### Preliminary Checks
- [X] This issue is not a duplicate. Before opening a ne… w issue, please search existing issues.
- [X] This issue is not a question, feature request, or anything other than a bug report directly related to this project.
### Description
Hello, i have encountered this error when launching the wrapper with the command:
`ros2 launch zed_wrapper zed_camera.launch.py camera_model:=zed2i`
[component_container-2] [INFO] [1733414829.790032321] [zed.zed_node]: Camera-IMU Translation:
[component_container-2]  -0.002 -0.023061 0.000217
[component_container-2] [INFO] [1733414829.790224267] [zed.zed_node]: Camera-IMU Rotation:
[component_container-2] FFFFD08A1670
[component_container-2] 0.999985 0.004895 -0.002594
[component_container-2] -0.004901 0.999986 -0.002006
[component_container-2] 0.002584 0.002019 0.999995
[component_container-2] [INFO] [1733414829.790310928] [zed.zed_node]: *** Subscribers ***
[ERROR] [component_container-2]: process has died [pid 102219, exit code -6, cmd '/opt/ros/foxy/lib/rclcpp_components/component_container --ros-args -r __node:=zed_container -r __ns:=/zed'].
### Steps to Reproduce
1. `git clone  --recursive https://github.com/stereolabs/zed-ros2-wrapper.git`
2. `sudo apt update`
3. `rosdep update`
4. `rosdep install --from-paths src --ignore-src -r -y`
5. `colcon build --symlink-install --cmake-args=-DCMAKE_BUILD_TYPE=Release --parallel-workers $(nproc)`
6. source the workspace
### Expected Result
The wrapper node is launched correctly
### Actual Result
This is the full log of after launching the node:
[INFO] [launch]: All log files can be found below /home/wrapper/.ros/log/2024-12-05-17-07-03-003395-wrapper-desktop-102203
Using common configuration file: /home/wrapper/ros2_ws/install/zed_wrapper/share/zed_wrapper/config/common_stereo.yaml
[INFO] [robot_state_publisher-1]: process started with pid [102217]
[INFO] [component_container-2]: process started with pid [102219]
[robot_state_publisher-1] Parsing robot urdf xml string.
[robot_state_publisher-1] Link zed_camera_center had 2 children
[robot_state_publisher-1] Link zed_left_camera_frame had 1 children
[robot_state_publisher-1] Link zed_left_camera_optical_frame had 0 children
[robot_state_publisher-1] Link zed_right_camera_frame had 1 children
[robot_state_publisher-1] Link zed_right_camera_optical_frame had 0 children
[robot_state_publisher-1] [INFO] [1733414824.703258184] [zed.zed_state_publisher]: got segment zed_camera_center
[robot_state_publisher-1] [INFO] [1733414824.703679550] [zed.zed_state_publisher]: got segment zed_camera_link
[robot_state_publisher-1] [INFO] [1733414824.703799717] [zed.zed_state_publisher]: got segment zed_left_camera_frame
[robot_state_publisher-1] [INFO] [1733414824.703904394] [zed.zed_state_publisher]: got segment zed_left_camera_optical_frame
[robot_state_publisher-1] [INFO] [1733414824.703965294] [zed.zed_state_publisher]: got segment zed_right_camera_frame
[robot_state_publisher-1] [INFO] [1733414824.704017776] [zed.zed_state_publisher]: got segment zed_right_camera_optical_frame
[component_container-2] [INFO] [1733414824.803875680] [zed.zed_container]: Load Library: /home/wrapper/ros2_ws/install/zed_components/lib/libzed_camera_component.so
[component_container-2] [INFO] [1733414825.055269395] [zed.zed_container]: Found class: rclcpp_components::NodeFactoryTemplate<stereolabs::ZedCamera>
[component_container-2] [INFO] [1733414825.055590948] [zed.zed_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<stereolabs::ZedCamera>
[component_container-2] [INFO] [1733414825.517992398] [zed.zed_node]: ********************************
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/zed/zed_node' in container '/zed/zed_container'
[component_container-2] [INFO] [1733414825.518255196] [zed.zed_node]:       ZED Camera Component
[component_container-2] [INFO] [1733414825.518334464] [zed.zed_node]: ********************************
[component_container-2] [INFO] [1733414825.518396067] [zed.zed_node]:  * namespace: /zed
[component_container-2] [INFO] [1733414825.518506569] [zed.zed_node]:  * node name: zed_node
[component_container-2] [INFO] [1733414825.518602254] [zed.zed_node]: ********************************
[component_container-2] [INFO] [1733414825.569349521] [zed.zed_node]: *** DEBUG parameters ***
[component_container-2] [INFO] [1733414825.569906863] [zed.zed_node]:  * SDK Verbose: 1
[component_container-2] [INFO] [1733414825.570390536] [zed.zed_node]:  * Debug Common: FALSE
[component_container-2] [INFO] [1733414825.570841888] [zed.zed_node]:  * Debug Simulation: FALSE
[component_container-2] [INFO] [1733414825.571222580] [zed.zed_node]:  * Debug Video/Depth: FALSE
[component_container-2] [INFO] [1733414825.571463137] [zed.zed_node]:  * Debug Control settings: FALSE
[component_container-2] [INFO] [1733414825.571703822] [zed.zed_node]:  * Debug Point Cloud: FALSE
[component_container-2] [INFO] [1733414825.572069313] [zed.zed_node]:  * Debug GNSS: FALSE
[component_container-2] [INFO] [1733414825.572307054] [zed.zed_node]:  * Debug Positional Tracking: FALSE
[component_container-2] [INFO] [1733414825.572515225] [zed.zed_node]:  * Debug sensors: FALSE
[component_container-2] [INFO] [1733414825.572690466] [zed.zed_node]:  * Debug Mapping: FALSE
[component_container-2] [INFO] [1733414825.575436756] [zed.zed_node]:  * Debug Object Detection: FALSE
[component_container-2] [INFO] [1733414825.575666432] [zed.zed_node]:  * Debug Body Tracking: FALSE
[component_container-2] [INFO] [1733414825.576306754] [zed.zed_node]:  * Debug Streaming: FALSE
[component_container-2] [INFO] [1733414825.576953060] [zed.zed_node]:  * Debug ROI: FALSE
[component_container-2] [INFO] [1733414825.577516066] [zed.zed_node]:  * Debug Advanced: FALSE
[component_container-2] [INFO] [1733414825.577981403] [zed.zed_node]: *** GENERAL parameters ***
[component_container-2] [INFO] [1733414825.579872351] [zed.zed_node]:  * Camera model: zed2i - ZED 2i
[component_container-2] [INFO] [1733414825.580401531] [zed.zed_node]:  * Camera name: zed
[component_container-2] [INFO] [1733414825.581200742] [zed.zed_node]:  * Camera SN: 0
[component_container-2] [INFO] [1733414825.581484245] [zed.zed_node]:  * Camera timeout [sec]: 5
[component_container-2] [INFO] [1733414825.582211259] [zed.zed_node]:  * Camera reconnection temptatives: 5
[component_container-2] [INFO] [1733414825.582423494] [zed.zed_node]:  * Camera framerate: 15
[component_container-2] [INFO] [1733414825.583201520] [zed.zed_node]:  * GPU ID: -1
[component_container-2] [WARN] [1733414825.584166467] [zed.zed_node]: Not valid 'general.pub_resolution' value: 'MEDIUM'. Using default setting instead.
[component_container-2] [INFO] [1733414825.584296714] [zed.zed_node]:  * Publishing resolution: NATIVE
[component_container-2] [INFO] [1733414825.584733921] [zed.zed_node]:  * OpenCV custom calibration:
[component_container-2] [INFO] [1733414825.585346881] [zed.zed_node]:  * Camera self calibration: TRUE
[component_container-2] [INFO] [1733414825.585781657] [zed.zed_node]:  * Camera flip: FALSE
[component_container-2] [INFO] [1733414825.586578563] [zed.zed_node]:  * [DYN] Publish framerate [Hz]:  15
[component_container-2] [INFO] [1733414825.586758604] [zed.zed_node]: *** VIDEO parameters ***
[component_container-2] [INFO] [1733414825.586957527] [zed.zed_node]:  * [DYN] Brightness: 4
[component_container-2] [INFO] [1733414825.587604313] [zed.zed_node]:  * [DYN] Contrast: 4
[component_container-2] [INFO] [1733414825.587938955] [zed.zed_node]:  * [DYN] Hue: 0
[component_container-2] [INFO] [1733414825.588495624] [zed.zed_node]:  * [DYN] Saturation: 4
[component_container-2] [INFO] [1733414825.589077095] [zed.zed_node]:  * [DYN] Sharpness: 4
[component_container-2] [INFO] [1733414825.589265809] [zed.zed_node]:  * [DYN] Gamma: 8
[component_container-2] [INFO] [1733414825.589874482] [zed.zed_node]:  * [DYN] Auto Exposure/Gain: TRUE
[component_container-2] [INFO] [1733414825.590395565] [zed.zed_node]:  * [DYN] Exposure: 80
[component_container-2] [INFO] [1733414825.590824740] [zed.zed_node]:  * [DYN] Gain: 80
[component_container-2] [INFO] [1733414825.591349728] [zed.zed_node]:  * [DYN] Auto White Balance: TRUE
[component_container-2] [INFO] [1733414825.591619982] [zed.zed_node]:  * [DYN] White Balance Temperature: 42
[component_container-2] [INFO] [1733414825.591717139] [zed.zed_node]: *** DEPTH parameters ***
[component_container-2] [INFO] [1733414825.592089703] [zed.zed_node]:  * Depth mode: ULTRA [3]
[component_container-2] [INFO] [1733414825.592279921] [zed.zed_node]:  * Min depth [m]: 0.2
[component_container-2] [INFO] [1733414825.592707464] [zed.zed_node]:  * Max depth [m]: 10
[component_container-2] [INFO] [1733414825.592925523] [zed.zed_node]:  * Depth Stabilization: 1
[component_container-2] [INFO] [1733414825.593204194] [zed.zed_node]:  * OpenNI mode (16bit point cloud): FALSE
[component_container-2] [INFO] [1733414825.593519091] [zed.zed_node]:  * [DYN] Point cloud rate [Hz]: 15
[component_container-2] [INFO] [1733414825.593748447] [zed.zed_node]:  * [DYN] Depth Confidence: 50
[component_container-2] [INFO] [1733414825.593916744] [zed.zed_node]:  * [DYN] Depth Texture Confidence: 100
[component_container-2] [INFO] [1733414825.594197783] [zed.zed_node]:  * [DYN] Remove saturated areas: TRUE
[component_container-2] [INFO] [1733414825.594330942] [zed.zed_node]: *** GNSS FUSION parameters ***
[component_container-2] [INFO] [1733414825.594496775] [zed.zed_node]:  * GNSS fusion enabled: FALSE
[component_container-2] [INFO] [1733414825.594581131] [zed.zed_node]: *** POSITIONAL TRACKING parameters ***
[component_container-2] [INFO] [1733414825.594721459] [zed.zed_node]:  * Positional tracking enabled: FALSE
[component_container-2] [WARN] [1733414825.594982528] [zed.zed_node]: 'pos_tracking.pos_tracking_mode' not valid (''). Using default value.
[component_container-2] [INFO] [1733414825.595216717] [zed.zed_node]:  * Positional tracking mode: GEN 2
[component_container-2] [INFO] [1733414825.595395734] [zed.zed_node]:  * Map frame id: map
[component_container-2] [INFO] [1733414825.595605442] [zed.zed_node]:  * Odometry frame id: odom
[component_container-2] [INFO] [1733414825.595893841] [zed.zed_node]:  * Broadcast Odometry TF: TRUE
[component_container-2] [INFO] [1733414825.596157887] [zed.zed_node]:  * Broadcast Pose TF: TRUE
[component_container-2] [INFO] [1733414825.596433581] [zed.zed_node]:  * [DYN] Depth minimum range: 0
[component_container-2] [INFO] [1733414825.597170516] [zed.zed_node]:  * [DYN] TF timestamp offset: 0.05
[component_container-2] [INFO] [1733414825.597504550] [zed.zed_node]:  * [DYN] Path publishing rate: 2
[component_container-2] [INFO] [1733414825.597870778] [zed.zed_node]:  * Path history lenght: -1
[component_container-2] [INFO] [1733414825.598497819] [zed.zed_node]:  * Initial pose: [0,0,0,0,0,0,]
[component_container-2] [INFO] [1733414825.599015606] [zed.zed_node]:  * Area Memory: TRUE
[component_container-2] [INFO] [1733414825.599577588] [zed.zed_node]:  * Area Memory DB:
[component_container-2] [INFO] [1733414825.600182900] [zed.zed_node]:  * Camera is static: FALSE
[component_container-2] [INFO] [1733414825.600693679] [zed.zed_node]:  * Gravity as origin [not for ZED]: FALSE
[component_container-2] [INFO] [1733414825.601176201] [zed.zed_node]:  * IMU Fusion [not for ZED]: TRUE
[component_container-2] [INFO] [1733414825.601592575] [zed.zed_node]:  * Floor Alignment: FALSE
[component_container-2] [INFO] [1733414825.602012277] [zed.zed_node]:  * Reset Odometry with Loop Closure: TRUE
[component_container-2] [INFO] [1733414825.602467373] [zed.zed_node]:  * 2D mode: FALSE
[component_container-2] [INFO] [1733414825.602857378] [zed.zed_node]: *** Region of Interest parameters ***
[component_container-2] [INFO] [1733414825.603050636] [zed.zed_node]:  * Automatic ROI generation: FALSE
[component_container-2] [INFO] [1733414825.603692846] [zed.zed_node]:  * Manual ROI polygon: []
[component_container-2] [INFO] [1733414825.603807540] [zed.zed_node]: *** SENSORS STACK parameters ***
[component_container-2] [INFO] [1733414825.604193641] [zed.zed_node]:  * Broadcast IMU TF [not for ZED]: TRUE
[component_container-2] [INFO] [1733414825.604362642] [zed.zed_node]:  * Sensors Camera Sync: FALSE
[component_container-2] [INFO] [1733414825.604514426] [zed.zed_node]:  * Sensors publishing rate: 400 Hz
[component_container-2] [INFO] [1733414825.604603359] [zed.zed_node]: *** Spatial Mapping parameters ***
[component_container-2] [INFO] [1733414825.604783272] [zed.zed_node]:  * Spatial Mapping Enabled: FALSE
[component_container-2] [INFO] [1733414825.604949585] [zed.zed_node]:  * Spatial Mapping resolution [m]: 0.05
[component_container-2] [INFO] [1733414825.605089592] [zed.zed_node]:  * 3D Max Mapping range [m]: 10
[component_container-2] [INFO] [1733414825.605222976] [zed.zed_node]:  * Map publishing rate [Hz]: 1
[component_container-2] [INFO] [1733414825.605391720] [zed.zed_node]:  * Clicked point topic:
[component_container-2] [INFO] [1733414825.605531216] [zed.zed_node]:  * Plane Det. Max Dist. Thresh.: 0.15
[component_container-2] [INFO] [1733414825.605673207] [zed.zed_node]:  * Plane Det. Normals Sim. Thresh.: 15
[component_container-2] [INFO] [1733414825.605752860] [zed.zed_node]: *** Object Det. parameters ***
[component_container-2] [INFO] [1733414825.605871618] [zed.zed_node]:  * Object Det. enabled: FALSE
[component_container-2] [WARN] [1733414825.606188243] [zed.zed_node]: The value of the parameter 'object_detection.model' is not valid: ''. Using the default value.
[component_container-2] [INFO] [1733414825.606283736] [zed.zed_node]:  * Object Det. model: MULTI CLASS BOX FAST
[component_container-2] [INFO] [1733414825.606416511] [zed.zed_node]:  * Object Det. allow reduced precision: FALSE
[component_container-2] [INFO] [1733414825.606590184] [zed.zed_node]:  * Object Det. maximum range [m]: 15
[component_container-2] [INFO] [1733414825.606972092] [zed.zed_node]:  * Object Det. min. confidence: 40
[component_container-2] [INFO] [1733414825.607220489] [zed.zed_node]:  * Object Det. prediction timeout [sec]: 0.5
[component_container-2] [INFO] [1733414825.607421044] [zed.zed_node]:  * Object Det. tracking: TRUE
[component_container-2] [INFO] [1733414825.607595389] [zed.zed_node]:  * Object Filtering mode: 1 - NMS3D
[component_container-2] [INFO] [1733414825.608377063] [zed.zed_node]:  * MultiClassBox people: TRUE
[component_container-2] [INFO] [1733414825.608567793] [zed.zed_node]:  * MultiClassBox vehicles: TRUE
[component_container-2] [INFO] [1733414825.608700216] [zed.zed_node]:  * MultiClassBox bags: TRUE
[component_container-2] [INFO] [1733414825.608824414] [zed.zed_node]:  * MultiClassBox animals: TRUE
[component_container-2] [INFO] [1733414825.608945701] [zed.zed_node]:  * MultiClassBox electronics: TRUE
[component_container-2] [INFO] [1733414825.609071948] [zed.zed_node]:  * MultiClassBox fruits and vegetables: TRUE
[component_container-2] [INFO] [1733414825.609196466] [zed.zed_node]:  * MultiClassBox sport-related objects: TRUE
[component_container-2] [INFO] [1733414825.609269398] [zed.zed_node]: *** Body Track. parameters ***
[component_container-2] [INFO] [1733414825.609421630] [zed.zed_node]:  * Body Track. enabled: FALSE
[component_container-2] [INFO] [1733414825.610081281] [zed.zed_node]:  * Body Track. model: HUMAN BODY FAST
[component_container-2] [INFO] [1733414825.610342927] [zed.zed_node]:  * Body Track. format: BODY 38
[component_container-2] [INFO] [1733414825.610705666] [zed.zed_node]:  * Body Track. allow reduced precision: FALSE
[component_container-2] [INFO] [1733414825.610902125] [zed.zed_node]:  * Body Track. maximum range [m]: 15
[component_container-2] [INFO] [1733414825.611563120] [zed.zed_node]:  * Body Track. KP selection: FULL
[component_container-2] [INFO] [1733414825.611804957] [zed.zed_node]:  * Body fitting: TRUE
[component_container-2] [INFO] [1733414825.612096524] [zed.zed_node]:  * Body joints tracking: TRUE
[component_container-2] [INFO] [1733414825.612435262] [zed.zed_node]:  * Body Track. prediction timeout [sec]: 0.5
[component_container-2] [INFO] [1733414825.612824403] [zed.zed_node]:  * Body Track. confidence thresh.: 50
[component_container-2] [INFO] [1733414825.613165061] [zed.zed_node]:  * Body Track. min. KP thresh.: 10
[component_container-2] [INFO] [1733414825.613265066] [zed.zed_node]: *** Streaming Server parameters ***
[component_container-2] [INFO] [1733414825.613511511] [zed.zed_node]:  * Streaming Server enabled: FALSE
[component_container-2] [INFO] [1733414825.613882763] [zed.zed_node]:  * Stream codec: H264
[component_container-2] [INFO] [1733414825.614180955] [zed.zed_node]:  * Stream port:30000
[component_container-2] [INFO] [1733414825.614480490] [zed.zed_node]:  * Stream bitrate: 12500
[component_container-2] [INFO] [1733414825.614785851] [zed.zed_node]:  * Stream GOP size: -1
[component_container-2] [INFO] [1733414825.614957156] [zed.zed_node]:  * Stream Chunk size: 16084
[component_container-2] [INFO] [1733414825.615235955] [zed.zed_node]:  * Adaptive bitrate: FALSE
[component_container-2] [INFO] [1733414825.615685066] [zed.zed_node]:  * Target frame rate:0
[component_container-2] [INFO] [1733414825.615768303] [zed.zed_node]: *** Advanced parameters ***
[component_container-2] [INFO] [1733414825.616024316] [zed.zed_node]:  * Thread sched. policy:
[component_container-2] [INFO] [1733414825.616458323] [zed.zed_node]: *** SERVICES ***
[component_container-2] [INFO] [1733414825.619690495] [zed.zed_node]:  * '/zed/zed_node/reset_odometry'
[component_container-2] [INFO] [1733414825.621548993] [zed.zed_node]:  * '/zed/zed_node/reset_pos_tracking'
[component_container-2] [INFO] [1733414825.626276220] [zed.zed_node]:  * '/zed/zed_node/set_pose'
[component_container-2] [INFO] [1733414825.628981579] [zed.zed_node]:  * '/zed/zed_node/enable_obj_det'
[component_container-2] [INFO] [1733414825.630900817] [zed.zed_node]:  * '/zed/zed_node/enable_body_trk'
[component_container-2] [INFO] [1733414825.632879354] [zed.zed_node]:  * '/zed/zed_node/enable_mapping'
[component_container-2] [INFO] [1733414825.634644376] [zed.zed_node]:  * '/zed/zed_node/enable_streaming'
[component_container-2] [INFO] [1733414825.637241505] [zed.zed_node]:  * '/zed/zed_node/start_svo_rec'
[component_container-2] [INFO] [1733414825.639028032] [zed.zed_node]:  * '/zed/zed_node/stop_svo_rec'
[component_container-2] [INFO] [1733414825.641396574] [zed.zed_node]:  * '/zed/zed_node/set_roi'
[component_container-2] [INFO] [1733414825.643201566] [zed.zed_node]:  * '/zed/zed_node/reset_roi'
[component_container-2] [INFO] [1733414825.643632532] [zed.zed_node]: ***** STARTING CAMERA *****
[component_container-2] [INFO] [1733414825.777592596] [zed.zed_node]: ZED SDK Version: 4.2.2 - Build 95990_fb77e75e
[component_container-2] [2024-12-05 16:07:05 UTC][ZED][INFO] Logging level INFO
[component_container-2] [INFO] [1733414825.791615228] [zed.zed_node]: *** CAMERA OPENING ***
[component_container-2] [2024-12-05 16:07:06 UTC][ZED][INFO] Logging level INFO
[component_container-2] [2024-12-05 16:07:07 UTC][ZED][INFO] Using USB input... Switched to default resolution HD720
[component_container-2] [2024-12-05 16:07:07 UTC][ZED][INFO] [Init]  Depth mode: ULTRA
[component_container-2] [2024-12-05 16:07:08 UTC][ZED][INFO] [Init]  Camera successfully opened.
[component_container-2] [2024-12-05 16:07:08 UTC][ZED][INFO] [Init]  Camera FW version: 1523
[component_container-2] [2024-12-05 16:07:08 UTC][ZED][INFO] [Init]  Video mode: HD720@15
[component_container-2] [2024-12-05 16:07:08 UTC][ZED][INFO] [Init]  Serial Number: S/N 36513009
[component_container-2] [2024-12-05 16:07:08 UTC][ZED][WARNING] [Init]  Self-calibration failed. Point the camera towards a more textured and brighter area. Avoid objects closer than 1 meter (Error code: 0x01)
[component_container-2] [INFO] [1733414829.010677840] [zed.zed_node]: ZED SDK running on GPU #0
[component_container-2] [INFO] [1733414829.010948222] [zed.zed_node]:  * Camera Model  -> ZED 2i
[component_container-2] [INFO] [1733414829.011062884] [zed.zed_node]:  * Serial Number -> 36513009
[component_container-2] [INFO] [1733414829.011427544] [zed.zed_node]:  * Focal Lenght -> 2.09102 mm
[component_container-2] [INFO] [1733414829.011550110] [zed.zed_node]:  * Input	 -> USB
[component_container-2] [INFO] [1733414829.011688741] [zed.zed_node]:  * Camera FW Version  -> 1523
[component_container-2] [INFO] [1733414829.011761225] [zed.zed_node]:  * Sensors FW Version -> 777
[component_container-2] [INFO] [1733414829.011881840] [zed.zed_node]:  * Camera grab frame size -> 1280x720
[component_container-2] [INFO] [1733414829.011991733] [zed.zed_node]:  * Publishing frame size  -> 1280x720
[component_container-2] [INFO] [1733414829.012233474] [zed.zed_node]: *** TF FRAMES ***
[component_container-2] [INFO] [1733414829.012305510] [zed.zed_node]:  * Map			-> map
[component_container-2] [INFO] [1733414829.012370634] [zed.zed_node]:  * Odometry		-> odom
[component_container-2] [INFO] [1733414829.012435693] [zed.zed_node]:  * Base			-> zed_camera_link
[component_container-2] [INFO] [1733414829.012501136] [zed.zed_node]:  * Camera			-> zed_camera_center
[component_container-2] [INFO] [1733414829.012565492] [zed.zed_node]:  * Left			-> zed_left_camera_frame
[component_container-2] [INFO] [1733414829.012629911] [zed.zed_node]:  * Left Optical		-> zed_left_camera_optical_frame
[component_container-2] [INFO] [1733414829.012695291] [zed.zed_node]:  * RGB			-> zed_left_camera_frame
[component_container-2] [INFO] [1733414829.012787840] [zed.zed_node]:  * RGB Optical		-> zed_left_camera_optical_frame
[component_container-2] [INFO] [1733414829.012856323] [zed.zed_node]:  * Right			-> zed_right_camera_frame
[component_container-2] [INFO] [1733414829.012920903] [zed.zed_node]:  * Right Optical		-> zed_right_camera_optical_frame
[component_container-2] [INFO] [1733414829.013034861] [zed.zed_node]:  * Depth			-> zed_left_camera_frame
[component_container-2] [INFO] [1733414829.013142482] [zed.zed_node]:  * Depth Optical		-> zed_left_camera_optical_frame
[component_container-2] [INFO] [1733414829.013212406] [zed.zed_node]:  * Point Cloud		-> zed_left_camera_optical_frame
[component_container-2] [INFO] [1733414829.013315452] [zed.zed_node]:  * Disparity		-> zed_left_camera_frame
[component_container-2] [INFO] [1733414829.013380767] [zed.zed_node]:  * Disparity Optical	-> zed_left_camera_optical_frame
[component_container-2] [INFO] [1733414829.013475204] [zed.zed_node]:  * Confidence		-> zed_left_camera_frame
[component_container-2] [INFO] [1733414829.013542472] [zed.zed_node]:  * Confidence Optical	-> zed_left_camera_optical_frame
[component_container-2] [INFO] [1733414829.013607019] [zed.zed_node]:  * IMU			-> zed_imu_link
[component_container-2] [INFO] [1733414829.013676303] [zed.zed_node]:  * Barometer		-> zed_camera_center
[component_container-2] [INFO] [1733414829.013742770] [zed.zed_node]:  * Magnetometer		-> zed_imu_link
[component_container-2] [INFO] [1733414829.013808278] [zed.zed_node]:  * Left Temperature	-> zed_left_camera_frame
[component_container-2] [INFO] [1733414829.013872313] [zed.zed_node]:  * Right Temperature	-> zed_right_camera_frame
[component_container-2] [INFO] [1733414829.014006944] [zed.zed_node]: *** PUBLISHED TOPICS ***
[component_container-2] [INFO] [1733414829.467506161] [zed.zed_node]: Advertised on topic: /zed/zed_node/rgb/image_rect_color
[component_container-2] [INFO] [1733414829.467741950] [zed.zed_node]: Advertised on topic: /zed/zed_node/rgb/camera_info
[component_container-2] [INFO] [1733414829.482124601] [zed.zed_node]: Advertised on topic: /zed/zed_node/rgb_gray/image_rect_gray
[component_container-2] [INFO] [1733414829.482315299] [zed.zed_node]: Advertised on topic: /zed/zed_node/rgb_gray/camera_info
[component_container-2] [INFO] [1733414829.495767052] [zed.zed_node]: Advertised on topic: /zed/zed_node/rgb_raw/image_raw_color
[component_container-2] [INFO] [1733414829.495965271] [zed.zed_node]: Advertised on topic: /zed/zed_node/rgb_raw/camera_info
[component_container-2] [INFO] [1733414829.511638358] [zed.zed_node]: Advertised on topic: /zed/zed_node/rgb_raw_gray/image_raw_gray
[component_container-2] [INFO] [1733414829.511835840] [zed.zed_node]: Advertised on topic: /zed/zed_node/rgb_raw_gray/camera_info
[component_container-2] [INFO] [1733414829.531952107] [zed.zed_node]: Advertised on topic: /zed/zed_node/left/image_rect_color
[component_container-2] [INFO] [1733414829.532155254] [zed.zed_node]: Advertised on topic: /zed/zed_node/left/camera_info
[component_container-2] [INFO] [1733414829.550110030] [zed.zed_node]: Advertised on topic: /zed/zed_node/left_gray/image_rect_gray
[component_container-2] [INFO] [1733414829.550319961] [zed.zed_node]: Advertised on topic: /zed/zed_node/left_gray/camera_info
[component_container-2] [INFO] [1733414829.569081724] [zed.zed_node]: Advertised on topic: /zed/zed_node/left_raw/image_raw_color
[component_container-2] [INFO] [1733414829.569282823] [zed.zed_node]: Advertised on topic: /zed/zed_node/left_raw/camera_info
[component_container-2] [INFO] [1733414829.587852736] [zed.zed_node]: Advertised on topic: /zed/zed_node/left_raw_gray/image_raw_gray
[component_container-2] [INFO] [1733414829.588074283] [zed.zed_node]: Advertised on topic: /zed/zed_node/left_raw_gray/camera_info
[component_container-2] [INFO] [1733414829.607608951] [zed.zed_node]: Advertised on topic: /zed/zed_node/right/image_rect_color
[component_container-2] [INFO] [1733414829.607881414] [zed.zed_node]: Advertised on topic: /zed/zed_node/right/camera_info
[component_container-2] [INFO] [1733414829.626536067] [zed.zed_node]: Advertised on topic: /zed/zed_node/right_gray/image_rect_gray
[component_container-2] [INFO] [1733414829.626734989] [zed.zed_node]: Advertised on topic: /zed/zed_node/right_gray/camera_info
[component_container-2] [INFO] [1733414829.645109532] [zed.zed_node]: Advertised on topic: /zed/zed_node/right_raw/image_raw_color
[component_container-2] [INFO] [1733414829.645320903] [zed.zed_node]: Advertised on topic: /zed/zed_node/right_raw/camera_info
[component_container-2] [INFO] [1733414829.664779663] [zed.zed_node]: Advertised on topic: /zed/zed_node/right_raw_gray/image_raw_gray
[component_container-2] [INFO] [1733414829.664988282] [zed.zed_node]: Advertised on topic: /zed/zed_node/right_raw_gray/camera_info
[component_container-2] [INFO] [1733414829.682111846] [zed.zed_node]: Advertised on topic: /zed/zed_node/depth/depth_registered
[component_container-2] [INFO] [1733414829.682313009] [zed.zed_node]: Advertised on topic: /zed/zed_node/depth/camera_info
[component_container-2] [INFO] [1733414829.687258487] [zed.zed_node]: Advertised on topic: /zed/zed_node/depth/depth_info
[component_container-2] [INFO] [1733414829.701147160] [zed.zed_node]: Advertised on topic: /zed/zed_node/stereo/image_rect_color
[component_container-2] [INFO] [1733414829.715993995] [zed.zed_node]: Advertised on topic: /zed/zed_node/stereo_raw/image_raw_color
[component_container-2] [INFO] [1733414829.718679961] [zed.zed_node]: Advertised on topic: /zed/zed_node/confidence/confidence_map
[component_container-2] [INFO] [1733414829.724795614] [zed.zed_node]: Advertised on topic: /zed/zed_node/disparity/disparity_image
[component_container-2] [INFO] [1733414829.729157733] [zed.zed_node]: Advertised on topic: /zed/zed_node/point_cloud/cloud_registered
[component_container-2] [INFO] [1733414829.733111063] [zed.zed_node]: Advertised on topic: /zed/zed_node/pose
[component_container-2] [INFO] [1733414829.735987055] [zed.zed_node]: Advertised on topic: /zed/zed_node/pose/status
[component_container-2] [INFO] [1733414829.739439526] [zed.zed_node]: Advertised on topic: /zed/zed_node/pose_with_covariance
[component_container-2] [INFO] [1733414829.743911891] [zed.zed_node]: Advertised on topic: /zed/zed_node/odom
[component_container-2] [INFO] [1733414829.748014285] [zed.zed_node]: Advertised on topic: /zed/zed_node/path_map
[component_container-2] [INFO] [1733414829.751840472] [zed.zed_node]: Advertised on topic: /zed/zed_node/path_odom
[component_container-2] [INFO] [1733414829.756601300] [zed.zed_node]: Advertised on topic: /zed/plane_marker
[component_container-2] [INFO] [1733414829.760196083] [zed.zed_node]: Advertised on topic: /zed/plane
[component_container-2] [INFO] [1733414829.763840148] [zed.zed_node]: Advertised on topic: /zed/zed_node/imu/data
[component_container-2] [INFO] [1733414829.766367258] [zed.zed_node]: Advertised on topic: /zed/zed_node/imu/data_raw
[component_container-2] [INFO] [1733414829.770057502] [zed.zed_node]: Advertised on topic: /zed/zed_node/temperature/imu
[component_container-2] [INFO] [1733414829.773978190] [zed.zed_node]: Advertised on topic: /zed/zed_node/imu/mag
[component_container-2] [INFO] [1733414829.778009540] [zed.zed_node]: Advertised on topic: /zed/zed_node/atm_press
[component_container-2] [INFO] [1733414829.781007523] [zed.zed_node]: Advertised on topic: /zed/zed_node/temperature/left
[component_container-2] [INFO] [1733414829.785315975] [zed.zed_node]: Advertised on topic: /zed/zed_node/temperature/right
[component_container-2] [INFO] [1733414829.789749938] [zed.zed_node]: Advertised on topic: /zed/zed_node/left_cam_imu_transform
### ZED Camera model
ZED2i
### Environment
```shell
OS: Ubuntu 20 - L4T 35.4.1 - Jetpack 5.1.2
ZED SDK Version: v4.2.2
GPU: Nvidian Jetson Xavier
ROS: ROS2 Foxy
### Anything else?
_No response_
                hannah
                    February 13, 2025, 11:50am
              3
              First of all, thank you for your answer.
I’d like to ask if I understand well.
I went to the site and read it
Is it right to modify the demo.yaml file?
But, I can’t find it… ( I don’t have it…)
root@fb048dde5aec:/usr/local/zed# find / -type f -name “*.yaml”
/root/ros2_ws/src/zed-ros2-examples/examples/zed_aruco_localization/config/aruco_loc.yaml
/root/ros2_ws/src/zed-ros2-examples/examples/zed_depth_to_laserscan/config/zed_depth_to_laserscan.yaml
/root/ros2_ws/src/zed-ros2-wrapper/zed_wrapper/config/zedm.yaml
/root/ros2_ws/src/zed-ros2-wrapper/zed_wrapper/config/virtual.yaml
/root/ros2_ws/src/zed-ros2-wrapper/zed_wrapper/config/zedxone4k.yaml
/root/ros2_ws/src/zed-ros2-wrapper/zed_wrapper/config/zedxm.yaml
/root/ros2_ws/src/zed-ros2-wrapper/zed_wrapper/config/zedx.yaml
/root/ros2_ws/src/zed-ros2-wrapper/zed_wrapper/config/zed2i.yaml
/root/ros2_ws/src/zed-ros2-wrapper/zed_wrapper/config/zedxonegs.yaml
/root/ros2_ws/src/zed-ros2-wrapper/zed_wrapper/config/ffmpeg.yaml
/root/ros2_ws/src/zed-ros2-wrapper/zed_wrapper/config/common_mono.yaml
/root/ros2_ws/src/zed-ros2-wrapper/zed_wrapper/config/zed2.yaml
/root/ros2_ws/src/zed-ros2-wrapper/zed_wrapper/config/common_stereo.yaml
/root/ros2_ws/src/zed-ros2-wrapper/zed_wrapper/config/zed.yaml
/tmp/binarydeb/ros-foxy-rclcpp-2.4.3/.obj-aarch64-linux-gnu/test/resources/test_node/test_parameters.yaml
/tmp/binarydeb/ros-foxy-rcl-1.1.14/obj-aarch64-linux-gnu/test/resources/test_arguments/test_parameters.2.yaml
/tmp/binarydeb/ros-foxy-rcl-1.1.14/obj-aarch64-linux-gnu/test/resources/test_arguments/test_parameters.1.yaml
/opt/ros/foxy/share/rcl_interfaces/mapping_rules.yaml
/opt/ros/foxy/share/joy/config/joy-params.yaml
/opt/ros/foxy/share/example_interfaces/mapping_rules.yaml
/opt/ros/foxy/share/teleop_twist_joy/config/xbox.config.yaml
/opt/ros/foxy/share/teleop_twist_joy/config/atk3.config.yaml
/opt/ros/foxy/share/teleop_twist_joy/config/xd3.config.yaml
/opt/ros/foxy/share/teleop_twist_joy/config/ps3.config.yaml
/opt/ros/foxy/share/teleop_twist_joy/config/ps3-holonomic.config.yaml
/opt/ros/foxy/share/dummy_robot_bringup/launch/dummy_robot_bringup_launch.yaml
/opt/ros/foxy/share/tf2_msgs/tfmessage_bridge_mapping_rule.yaml
/opt/ros/foxy/share/unique_identifier_msgs/mapping_rules.yaml
/opt/ros/foxy/share/depthimage_to_laserscan/cfg/param.yaml
/opt/ros/foxy/share/geographic_msgs/geographic_msgs_mapping_rule.yaml
/opt/ros/foxy/share/robot_localization/test/test_ekf_localization_node_interfaces.yaml
/opt/ros/foxy/share/robot_localization/test/test_ros_robot_localization_listener.yaml
/opt/ros/foxy/share/robot_localization/test/test_filter_base_diagnostics_timestamps.yaml
/opt/ros/foxy/share/robot_localization/test/test_ekf_localization_node_bag2.yaml
/opt/ros/foxy/share/robot_localization/test/test_ekf_localization_node_bag3.yaml
/opt/ros/foxy/share/robot_localization/test/test_ukf_localization_node_bag1.yaml
/opt/ros/foxy/share/robot_localization/test/test_ukf_localization_node_interfaces.yaml
/opt/ros/foxy/share/robot_localization/test/test_ukf_localization_node_bag2.yaml
/opt/ros/foxy/share/robot_localization/test/test_ekf_localization_node_bag1.yaml
/opt/ros/foxy/share/robot_localization/test/test_ukf_localization_node_bag3.yaml
/opt/ros/foxy/share/robot_localization/params/dual_ekf_navsat_example.yaml
/opt/ros/foxy/share/robot_localization/params/ukf.yaml
/opt/ros/foxy/share/robot_localization/params/navsat_transform.yaml
/opt/ros/foxy/share/robot_localization/params/ekf.yaml
OR I have to edit ComposableNode in zed_camera.launch.py ??
what should i do… also i can’t understand well…
please teach me easily
                Myzhar
                    February 14, 2025,  6:18pm
              4
              In my opinion, the better solution is to migrate to Jetpack 6 which is based on Ubuntu 22.04. You can then install ROS 2 Humble and use newer software.
ROS 2 Foxy is now EOL.
                hannah
                    February 17, 2025, 12:32am
              5
              Thank you so much for your reply.
I think so too. I will try it. Thank you! Have a nice day~
