In the standard settings the object detection ROS node is printing END OF SVO FILE IS REACHED in a loop when the .svo file has finished. What is the cleanest way to kill (shutdown) the ros node inside the c++ code when the end of the .svo file is reached?
Hi @hgutze
you must modify the code of the nodelet to stop the node when the EOF is reached:
thx for your reply! I tried to kill the node from where you said via ros::shutdown() but it seems that this kills just one process but not the entire node like via ctrl + C. Do you know what would be the equivalent to ctrl + C here inside the program? Thx again.
For this kind of question related to ROS, I suggest you search/ask on https://answers.ros.org/
