How can I do navigation and localization with zed camera.
Hi @alpgrgn
Can you please provide more information? Your request is too generic.
Are you using ROS? ROS2? Other frameworks?
Are you using the ZED SDK natively?
Other important information?
I am using ros melodic I have installed the ZED SDK packages zed_ros_example and zed_wrapper.
I think I need to do localization first, do you know?
Localization is usually performed with the AMCL node, but it requires a 2D Laser scan.
If you decide to use it you can use this example to generate a virtual 2D laser scan:
I did that and now I’m trying to navigate, but when I give direction in rviz, it doesn’t draw the road. I can get speed information with rostopic echo, but angle values are not coming.
Hi @alpgrgn
this seems to be a ROS configuration issue, so I suggest you ask on https://answers.ros.org/ where the ROS community can provide you with better and more detailed information.
