Heartbeat when using pyzed
Hi @mattrouss,
Setup:
I am streaming 2 zed XOne GS cameras from jetson AGX Orin and opening the cameras via pyzed on my laptop.
ZED SDK : 5.1.1
The script I am running on my laptop basically opens the cameras and then calls enable_recording to start SVO recording and disable_recording to stop SVO recording. I notice that when the streaming fails (i.e you kill the streaming script), I am still able to record the SVOs (they are of much smaller size 1.6kb compared to a normal SVO which goes in MBs)
Here a couple of related questions to this topic:
  1. I wanted to check if there is any API that I could use to check the heartbeat/ streaming status to ensure that the streaming is running and I am able to receive the frames?
  2. When I call enable_recording, I think zed internally calls zed.grab() to grab a frame and then write it to the svo. In contrast, I see that the ZED documentation has an example where it says that grab has to be explicitly called after enable_recording is set. I wanted to check what is the right way of doing it?
My code snippet
def start_recording(self, svo_path: Path):
        Start SVO recording
        :param svo_path: Path to save SVO file
        if not self._is_initialized:
            _logger.error(f"[{self.name}] Not initialized! Call initialize() first")
            return False
        _logger.info(f"[{self.name}] Starting recording to {svo_path}")
        recording_params = sl.RecordingParameters()
        recording_params.compression_mode = sl.SVO_COMPRESSION_MODE.H265_LOSSLESS
        recording_params.video_filename = str(svo_path)
        recording_params.bitrate = 0
        recording_params.target_framerate = self.config.get("fps", 30)
        status = sl.CameraOne.enable_recording(recording_params)
            _logger.error(f"[{self.name}] Failed to start recording: {status}")
            return False
        _logger.info(f"[{self.name}] Recording started (SDK handling frames internally)")
        return True
From the documentation:
def main() :
    # Create a ZED camera object
    zed = sl.Camera()
    # Set initial parameters
    init_params.camera_resolution = sl.RESOLUTION.HD720 # Use HD720 video mode (default fps: 60)
    init_params.coordinate_units = sl.UNIT.METER # Set units in meters
    # Open the camera
    err = zed.open(init_params)
    if (err != sl.ERROR_CODE.SUCCESS):
        print(repr(err))
        exit(-1)
    # Enable video recording
    record_params = sl.RecordingParameters("myVideoFile.svo")
    err = zed.enable_recording(record_params)
        print(repr(err))
        exit(-1)
    # Grab data during 500 frames
    i = 0
    while i < 500 :
        # Grab a new frame
            # Record the grabbed frame in the video file
            i = i + 1
    zed.disable_recording()
    print("Video has been saved ...")
    zed.close()
    return 0
if __name__ == "__main__" :
    main()
Hi @abhishekpavani,
Usually when the stream is stopped on the sender, the receiver gives an error after a given timeout. Is this not happening in your case?
Also is there any reason you are not saving the data on the box directly, as recording the stream adds an additional encoding layer, reducing the quality of the recorded image?
