Hi there,
I’m wondering if there is a recommended way to handle depths of partially-occluded objects.
I am having issues with scenarios that resemble the following:
Suppose there is a tall cardboard box ~3m away from a Zed X camera.
When a person ~5m away from the camera walks across the frame, they are detected at ~5m, but as they pass behind the box, for a brief moment their depth reads ~3m.
I have numerous down-pipeline attempts at recognizing when this situation is happening, but I am wondering if there is a recommended way (or ways) that people have overcome these false depth readings.
Thanks.
Hi @stripedapus
Is it possible to record a video or take screenshots to show the problem while appearing?
Hi @Myzhar
Thanks for your response. Unfortunately I am not able to share the videos publicly.
We could either start a private conversation or keep it more hypothetical so hopefully other people can benefit as well.
This is a fairly well-known issue with any depth problem, so I’m wondering if ZED itself takes actions to try to mitigate this and if there is any well-known indicators that a person-detection (sl.ObjectData) could be occluded.
Some thoughts off the top of my head:
- Occlusion could somehow be inferred from a detection’s
dimensions or 3D bounding_box size (perhaps they are very “long” depth-wise)
- Perhaps the
position_covariance could somehow be used
- We could use the depth confidence map to disregard poor readings downstream.
Could any of these or other values be used as hints that occlusion could be happening?
Thanks.
You can send videos that you cannot share publicly to support@stereolabs.com with a link to this discussion.
We will continue on that channel.
