Hand detection using Z Camera
I have seen a tutorial using leapmotion for hand detection in connection with Zed.
Is it a must to use that solution? Can I do handtracking using only Zed camera ?
The leapmotion solution and Zed is expensive for me.
If I can use only zed, is there an example or a way to do that ?
Hi @andreahmed
That’s only one of the possible solutions.
You can use any kind of hand-tracking library to perform a similar task.
Unfortunately, the ZED SDK does not currently provide hand-tracking capabilities out of the shelf
Would you recommend on of the libraries please ?
I’m sorry, but I do not have this information.
You should try to search the internet
What is a current headset that can be used with Zed Cameras ?
