I am attempting to achieve GNSS calibration in order to produce geo-rectified positions for predictions from detectron2. Despite varying the position covariances with randomized values, when they are ingested the fusion module returns “GNSS DATA COVARIANCE MUST VARY”
Data: test_pk - Google Drive
Code:
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
# "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
# LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
# A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
# OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
# SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
# LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
# DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
# THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
This sample shows how to fuse the position of the ZED camera with an external GNSS Sensor
import sys
import pyzed.sl as sl
import json
from datetime import datetime
import cv2
import numpy as np
def gnss_str_to_pyzed(data:str) -> sl.GNSSData:
# '{"timestamp":"2024-05-06T20:13:09+00:00",
# "time_delta":0,
# "lat":46.8655633,"lon":-113.975665,
# "elevation":985.933,
# "covariance":"[34.727449, 0.0, 0.0, 0.0, 47.651408999999994, 0.0, 0.0, 0.0, 1.940449]"}'
data = json.loads(data)
gps_data = sl.GNSSData()
date_time = datetime.fromisoformat(data["timestamp"])
zed_ts = sl.Timestamp()
zed_ts.set_nanoseconds(int(date_time.timestamp()*1e9))
gps_data.ts = zed_ts
gps_data.set_coordinates(data["lat"],data["lon"],data["elevation"],False)
covariances = json.loads(data["covariance"])
covariances[0] += 4*np.random.random((1,))[0]
covariances[4] += 4*np.random.random((1,))[0]
covariances[8] += 4*np.random.random((1,))[0]
gps_data.position_covariances = [float(x)**.5 for x in covariances]
return gps_data
if __name__ == "__main__":
cv2.namedWindow("RGB",cv2.WINDOW_NORMAL)
filepath = "camera_recording_0.svo2"
input_type = sl.InputType()
input_type.set_from_svo_file(filepath) #Set init parameter to run from the .svo
init = sl.InitParameters(input_t=input_type, svo_real_time_mode=False,camera_resolution=sl.RESOLUTION.AUTO,
coordinate_units=sl.UNIT.METER,
coordinate_system=sl.COORDINATE_SYSTEM.RIGHT_HANDED_Z_UP)
init.depth_mode = sl.DEPTH_MODE.PERFORMANCE
zed = sl.Camera()
status = zed.open(init)
if status != sl.ERROR_CODE.SUCCESS: #Ensure the camera opened succesfully
print("Camera Open", status, "Exit program.")
exit(1)
print('External SVOData channels:', zed.get_svo_data_keys())
# some variables
odometry_pose = sl.Pose()
py_translation = sl.Translation()
pose_data = sl.Transform()
rgb = sl.Mat()
text_translation = ""
text_rotation = ""
current_gnss = sl.GNSSData()
current_geopose = sl.GeoPose()
# Create a ZED camera object
# set up communication parameters and start publishing
communication_parameters = sl.CommunicationParameters()
communication_parameters.set_for_shared_memory()
zed.start_publishing(communication_parameters)
# warmup for camera
if zed.grab() != sl.ERROR_CODE.SUCCESS:
print("Camera grab: " + repr(status) + ". Exit program.")
exit()
else:
zed.get_position(odometry_pose, sl.REFERENCE_FRAME.WORLD)
tracking_params = sl.PositionalTrackingParameters()
# These parameters are mandatory to initialize the transformation between GNSS and ZED reference frames.
tracking_params.enable_imu_fusion = True
tracking_params.set_gravity_as_origin = True
err = zed.enable_positional_tracking(tracking_params)
if (err != sl.ERROR_CODE.SUCCESS):
print("Camera positional tracking: " + repr(status) + ". Exit program.")
exit()
camera_info = zed.get_camera_information()
# step 2
# init the fusion module that will input both the camera and the GPS
fusion = sl.Fusion()
init_fusion_parameters = sl.InitFusionParameters()
init_fusion_parameters.coordinate_system = sl.COORDINATE_SYSTEM.RIGHT_HANDED_Y_UP
init_fusion_parameters.coordinate_units = sl.UNIT.METER
gnss_calibration_params = sl.GNSSCalibrationParameters()
gnss_calibration_params.gnss_vio_reinit_threshold = 1
fusion.init(init_fusion_parameters)
positional_tracking_fusion_parameters = sl.PositionalTrackingFusionParameters()
positional_tracking_fusion_parameters.gnss_calibration_parameters = gnss_calibration_params
fusion.enable_positionnal_tracking(positional_tracking_fusion_parameters)
uuid = sl.CameraIdentifier(camera_info.serial_number)
print("Subscribing to", uuid.serial_number, communication_parameters.comm_type) #Subscribe fusion to camera
status = fusion.subscribe(uuid, communication_parameters, sl.Transform(0,0,0))
if status != sl.FUSION_ERROR_CODE.SUCCESS:
print("Failed to subscribe to", uuid.serial_number, status)
exit(1)
x = 0
i = 0
while i < 1e7:
# get the odometry information
zed.retrieve_image(rgb, sl.VIEW.LEFT)
rgb_img = cv2.cvtColor(rgb.get_data(), cv2.COLOR_RGBA2RGB)
cv2.imshow("RGB",rgb_img)
elif zed.grab() == sl.ERROR_CODE.END_OF_SVOFILE_REACHED:
break
ts_camera : sl.Timestamp = zed.get_timestamp(sl.TIME_REFERENCE.IMAGE)
last_timestamp = sl.Timestamp()
data_map = {}
ing = zed.retrieve_svo_data("GNSS",data_map,last_timestamp,ts_camera)
data_map = [(k,v) for k,v in data_map.items()]
for data in data_map:
data_string = data[1].get_content_as_string()
gnss_data = gnss_str_to_pyzed(data_string)
time_delta = ts_camera.get_microseconds() - gnss_data.ts.get_microseconds()
print(gnss_data.position_covariances)
print(f"Camera-GNSS time difference [s]: {time_delta/1e6}")
status = fusion.ingest_gnss_data(gnss_data)
if status.name == "SUCCESS":
print("Ingested GNSS data")
else:
print(status)
last_timestamp = ts_camera
# get the fused position
if fusion.process() == sl.FUSION_ERROR_CODE.SUCCESS:
fused_tracking_state = fusion.get_position(odometry_pose, sl.REFERENCE_FRAME.WORLD)
if fused_tracking_state == sl.POSITIONAL_TRACKING_STATE.OK:
rotation = odometry_pose.get_rotation_vector()
translation = odometry_pose.get_translation(py_translation)
text_rotation = str((round(rotation[0], 2), round(rotation[1], 2), round(rotation[2], 2)))
text_translation = str((round(translation.get()[0], 2), round(translation.get()[1], 2), round(translation.get()[2], 2)))
pose_data = odometry_pose.pose_data(sl.Transform())
print("get position translation = ",text_translation,", rotation_message = ",text_rotation)
# get geopose
fusion.get_geo_pose(current_geopose)
current_latlng = current_geopose.latlng_coordinates
print("Lat/Lon = ",current_latlng.get_coordinates(False))
print("Heading = ",current_geopose.heading)
gnss_status, yaw_unc,pos_unc = fusion.get_current_gnss_calibration_std()
print(f"Translation Uncertainty = {pos_unc}")
print(f"Yaw Uncertainty = {yaw_unc}")
print(f"GNSS Status = {gnss_status}")
i = i + 1
if cv2.waitKey(1) & 0xFF == ord('q'):
break
zed.close()
Terminal:
[2024-05-07 19:17:17 UTC][ZED][INFO] Logging level INFO
[2024-05-07 19:17:17 UTC][ZED][INFO] [Init] Depth mode: PERFORMANCE
[2024-05-07 19:17:17 UTC][ZED][INFO] [Init] Serial Number: S/N 47733007
External SVOData channels: ['GNSS']
Subscribing to 47733007 COMM_TYPE.INTRA_PROCESS
[5.9722080993062905, 0.0, 0.0, 0.0, 7.019680286243853, 0.0, 0.0, 0.0, 7.493503332753606]
Camera-GNSS time difference [s]: 0.444982
INVALID TIMESTAMP
[6.194840942204799, 0.0, 0.0, 0.0, 7.023651622792437, 0.0, 0.0, 0.0, 7.585296382575726]
Camera-GNSS time difference [s]: 0.844801
INVALID TIMESTAMP
[6.171552139034422, 0.0, 0.0, 0.0, 6.964669227777214, 0.0, 0.0, 0.0, 7.68532695876349]
Camera-GNSS time difference [s]: 1.128145
[6.075807473616566, 0.0, 0.0, 0.0, 6.932670192297998, 0.0, 0.0, 0.0, 7.331001010091511]
Camera-GNSS time difference [s]: 0.128145
[5.911707914198045, 0.0, 0.0, 0.0, 6.962864443731021, 0.0, 0.0, 0.0, 7.684549962226894]
Camera-GNSS time difference [s]: 1.444801
[6.0248786292402094, 0.0, 0.0, 0.0, 6.921640656722431, 0.0, 0.0, 0.0, 7.320255678483056]
Camera-GNSS time difference [s]: 0.444801
get position translation = (0.0, 0.0, 0.0) , rotation_message = (-0.07, 0.0, -0.1)
Lat/Lon = (0.0, 0.44762327744595565, 0.0)
Heading = 0.0
Translation Uncertainty = [0. 0. 0.]
Yaw Uncertainty = -3.8337059698629783e-38
GNSS Status = CALIBRATION_IN_PROGRESS
[6.096176117576387, 0.0, 0.0, 0.0, 7.166065866210921, 0.0, 0.0, 0.0, 7.674799407766699]
Camera-GNSS time difference [s]: 1.678267
[6.085925853881649, 0.0, 0.0, 0.0, 7.057691089006473, 0.0, 0.0, 0.0, 7.33464524886549]
Camera-GNSS time difference [s]: 0.678267
get position translation = (-0.0, 0.0, -0.0) , rotation_message = (-0.07, 0.0, -0.1)
Heading = 0.0
Yaw Uncertainty = -0.00011822805390693247
[6.12171539494147, 0.0, 0.0, 0.0, 7.141807969267532, 0.0, 0.0, 0.0, 7.584266773765523]
Camera-GNSS time difference [s]: 1.928095
[6.181952663130769, 0.0, 0.0, 0.0, 7.186098985318484, 0.0, 0.0, 0.0, 7.278686166734894]
Camera-GNSS time difference [s]: 0.928095
get position translation = (-0.0, 0.0, -0.0) , rotation_message = (-0.07, 0.01, -0.1)
Heading = 0.0
