GNSS Calibration Positional Uncertainty
I am attempting to perform SLAM with VIO/GNSS Fusion. After a a few minutes, my positional uncertainty as given by fusion.get_current_gnss_calibration_std() becomes quite large (> 1e19) and my calibration becomes off. Could this be some oversight on my end with GNSS ingestion?
Note that uncertainties will be printed to the terminal
Data:
https://drive.google.com/file/d/1XxqANF3J-y4Q6GYiCN7eC22UHCCcZ8Kr/view?usp=sharing
Code:
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
# "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
# LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
# A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
# OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
# SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
# LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
# DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
# THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    This sample shows how to fuse the position of the ZED camera with an external GNSS Sensor
import sys
import pyzed.sl as sl
import json
from datetime import datetime
import cv2
import numpy as np
from typing import Tuple
import matplotlib.pyplot as plt
def gnss_str_to_pyzed(data:str) -> sl.GNSSData:
    # '{"timestamp":"2024-05-06T20:13:09+00:00",
    # "time_delta":0,
    # "lat":46.8655633,"lon":-113.975665,
    # "elevation":985.933,
    # "covariance":"[34.727449, 0.0, 0.0, 0.0, 47.651408999999994, 0.0, 0.0, 0.0, 1.940449]"}'
    data = json.loads(data)
    gps_data = sl.GNSSData()
    sl_fix_mode = sl.GNSS_MODE.FIX_3D
    sl_status = sl.GNSS_STATUS.RTK_FIX
    gps_data.gnss_mode = sl_fix_mode.value
    gps_data.gnss_status = sl_status.value
    date_time = datetime.fromisoformat(data["timestamp"])
    zed_ts = sl.Timestamp()
    zed_ts.set_nanoseconds(int(date_time.timestamp()*1e9))
    gps_data.ts = zed_ts
    gps_data.set_coordinates(data["lat"],data["lon"],data["elevation"],False)
    covariances = json.loads(data["covariance"])
    gps_data.position_covariances = [float(x) for x in covariances]
    return gps_data
if __name__ == "__main__":
    gnss_measurements = []
    fused_position_measurements = []
    fused_geopose_measurements = []
    cv2.namedWindow("RGB",cv2.WINDOW_NORMAL)
    filepath = "camera_recording_0.svo2"
    input_type = sl.InputType()
    input_type.set_from_svo_file(filepath)  #Set init parameter to run from the .svo
    init = sl.InitParameters(input_t=input_type, svo_real_time_mode=False,camera_resolution=sl.RESOLUTION.AUTO,
                                 coordinate_units=sl.UNIT.METER,
                                 coordinate_system=sl.COORDINATE_SYSTEM.RIGHT_HANDED_Z_UP)
    init.depth_mode = sl.DEPTH_MODE.PERFORMANCE
    zed = sl.Camera()
    status = zed.open(init)
    if status != sl.ERROR_CODE.SUCCESS: #Ensure the camera opened succesfully
        print("Camera Open", status, "Exit program.")
        exit(1)
    print('External SVOData channels:', zed.get_svo_data_keys())
    # some variables
    odometry_pose = sl.Pose()
    py_translation = sl.Translation()
    pose_data = sl.Transform()
    rgb = sl.Mat()
    text_translation = ""
    text_rotation = ""
    current_gnss = sl.GNSSData()
    current_geopose = sl.GeoPose()
    # Create a ZED camera object
    # set up communication parameters and start publishing
    communication_parameters = sl.CommunicationParameters()
    communication_parameters.set_for_shared_memory()
    zed.start_publishing(communication_parameters)
    # warmup for camera
    if zed.grab() != sl.ERROR_CODE.SUCCESS:
        print("Camera grab: " + repr(status) + ". Exit program.")
        exit()
    else:
        zed.get_position(odometry_pose, sl.REFERENCE_FRAME.WORLD)
    tracking_params = sl.PositionalTrackingParameters()
    # These parameters are mandatory to initialize the transformation between GNSS and ZED reference frames.
    tracking_params.enable_imu_fusion = True
    tracking_params.set_gravity_as_origin = True
    err = zed.enable_positional_tracking(tracking_params)
    if (err != sl.ERROR_CODE.SUCCESS):
        print("Camera positional tracking: " + repr(status) + ". Exit program.")
        exit()
    camera_info = zed.get_camera_information()
    # step 2
    # init the fusion module that will input both the camera and the GPS
    fusion = sl.Fusion()
    init_fusion_parameters = sl.InitFusionParameters()
    init_fusion_parameters.coordinate_system = sl.COORDINATE_SYSTEM.RIGHT_HANDED_Y_UP
    init_fusion_parameters.coordinate_units = sl.UNIT.METER
    gnss_calibration_params = sl.GNSSCalibrationParameters()
    gnss_calibration_params.gnss_vio_reinit_threshold = 5
    fusion.init(init_fusion_parameters)
    positional_tracking_fusion_parameters = sl.PositionalTrackingFusionParameters()
    positional_tracking_fusion_parameters.enable_GNSS_fusion = True
    positional_tracking_fusion_parameters.gnss_calibration_parameters = gnss_calibration_params
    fusion.enable_positionnal_tracking(positional_tracking_fusion_parameters)
    print(gnss_calibration_params)
    uuid = sl.CameraIdentifier(camera_info.serial_number)
    print("Subscribing to", uuid.serial_number, communication_parameters.comm_type) #Subscribe fusion to camera
    status = fusion.subscribe(uuid, communication_parameters, sl.Transform(0,0,0))
    if status != sl.FUSION_ERROR_CODE.SUCCESS:
        print("Failed to subscribe to", uuid.serial_number, status)
        exit(1)
    x = 0
    i = 0
        zed.retrieve_image(rgb, sl.VIEW.LEFT)
        rgb_img = cv2.cvtColor(rgb.get_data(), cv2.COLOR_RGBA2RGB)
        last_timestamp = rgb.timestamp
        cv2.imshow("RGB",rgb_img)
    while i < 1e7:
        # get the odometry information
        elif zed.grab() == sl.ERROR_CODE.END_OF_SVOFILE_REACHED:
            break
        ts_camera : sl.Timestamp = rgb.timestamp
        data_map = {}
        ing = zed.retrieve_svo_data("GNSS",data_map,last_timestamp,ts_camera)
        data_map = [(k,v) for k,v in data_map.items()]
        for data in data_map:
            data_string = data[1].get_content_as_string()
            gnss_data = gnss_str_to_pyzed(data_string)
            time_delta = ts_camera.get_microseconds() - gnss_data.ts.get_microseconds()
            status = fusion.ingest_gnss_data(gnss_data)
            if status.name == "SUCCESS":
                gnss_measurements.append(
                    [gnss_data.get_coordinates(False)]
        last_timestamp = ts_camera
        # get the fused position
        if fusion.process() == sl.FUSION_ERROR_CODE.SUCCESS:
            fused_tracking_state = fusion.get_position(odometry_pose, sl.REFERENCE_FRAME.WORLD)
            if fused_tracking_state == sl.POSITIONAL_TRACKING_STATE.OK:
                rotation = odometry_pose.get_rotation_vector()
                translation = odometry_pose.get_translation(py_translation)
                fused_position_measurements.append(translation.get())
                # get geopose
                gp_status = fusion.get_geo_pose(current_geopose)
                if gp_status.name == "OK":
                    fused_geopose_measurements.append(
                        current_geopose.latlng_coordinates.get_coordinates(False)
                process_metrics: Tuple[sl.FUSION_ERROR_CODE,sl.FusionMetrics] = fusion.get_process_metrics()
                fusion_error_code, fusion_metrics = process_metrics
                fusion_metrics = {"mean_camera_fused":np.round(fusion_metrics.mean_camera_fused,3),"mean_stdev_camera_ts":np.round(fusion_metrics.mean_stdev_between_camera,3)}
                vio_gnss_trns: sl.Transform = fusion.get_geo_tracking_calibration()
                vio_gnss_trns_translation:np.ndarray = vio_gnss_trns.get_translation().get()
                gnss_calibration_data: Tuple[sl.GNSS_FUSION_STATUS,float,np.ndarray] = fusion.get_current_gnss_calibration_std()
                gnss_status, yaw_unc, pos_unc = gnss_calibration_data
                out = {
                    "fusion_error_code": fusion_error_code.name,
                    "fusion_metrics": fusion_metrics,
                    "vio_gnss_trns": [np.round(x,3) for x in vio_gnss_trns_translation.tolist()],
                    "gnss_calibration":gnss_status.name,
                    "yaw_unc": np.round(yaw_unc,3),
                    "pos_unc": [np.round(x,3) for x in pos_unc.tolist()]
                print(out)
        i = i + 1
        if cv2.waitKey(1) & 0xFF == ord('q'):
            break
    zed.close()
    # Assuming gnss_measurements and fused_geopose_measurements are lists of [lat, lon] pairs
    gnss_lats, gnss_lons = zip(*gnss_measurements)
    fused_lats, fused_lons = zip(*fused_geopose_measurements)
    # Assuming fused_position_measurements is a list of [x, y, z] coordinates
    fused_xs, fused_ys, fused_zs = zip(*fused_position_measurements)
    fig, axs = plt.subplots(2)
    # Plot lat, lon from gnss_measurements and fused_geopose_measurements
    axs[0].plot(gnss_lats, gnss_lons, label='GNSS Measurements',color='r')
    axs[0].plot(fused_lats, fused_lons, label='Fused Geopose Measurements',color='b')
    axs[0].set_xlabel('Latitude')
    axs[0].set_ylabel('Longitude')
    axs[0].legend()
    # Plot fused_position_measurements
    axs[1].plot(fused_xs, fused_ys, label='Fused Position Measurements')
    axs[1].set_xlabel('X')
    axs[1].set_ylabel('Y')
    axs[1].legend()
    plt.show()
gps.json (1.0 MB)
These are the GNSS measurements that were ingested:
These are the computed “Fused Geopose” Positions
I changed the geopose to be sourced from the “Fused Pose” as opposed to the “Camera Pose”, this is the result before the GNSS/VIO fusion broke down.
heading_t
Another comment,
When GNSS Calibration is obtained, I store the “sl.GeoPose.heading” values. This is a plot for each value along the track in the above image. The camera is traveling in the southeast direction along this frame so the heading values from the geopose object do not make sense. Could these values be roll/pitch?
@mattrouss @alassagne @TanguyHardelin please help.
Hello @fdunbar,
Again I cannot reproduce your issue. By using the ZED SDK official sample (adapted for your data) the VIO / GNSS fusion seems OK.
I have plotted the heading values returned by the GNSS fusion, and they appear to be correct. However, I noticed that during the recording, you made abrupt changes to the rotation of the camera. It’s important to note that since the fusion relies on VIO (Visual-Inertial Odometry) predicted rotation for heading prediction, sudden changes in camera orientation can result in abrupt changes in the heading value.
Despite this, I specifically examined the heading values at various moments, and they generally seem acceptable. For instance, I focused on the heading value at the end of the sequence, where the camera remained fixed on the direction of movement. Considering this context, the heading estimation is reasonably accurate and within acceptable bounds.
To provide a comprehensive view, I have plotted the complete set of values for the entire sequence:
Please note that the GNSS fusion relies on the assumption that the transformation between the camera and the GNSS remains constant throughout the fusion process. In other words, the camera and GNSS should be rigidly fixed. Considering your sequence, it is important to determine if this assumption holds true.
Since the rigidity of the camera-GNSS setup is crucial, it is also necessary to provide the transformation between the GNSS and VIO components. This additional information will greatly enhance the accuracy of the fusion results by enabling proper alignment and calibration between the different sensor inputs.
Regards,
Tanguy
@TanguyHardelin Thank you so much!!! Could you perhaps share the exact code you used to perform this? I cannot seem to figure out what I am doing wrong.
Thanks!!
I am just using the default sample provided with our SDK. It is available here: zed-sdk/global localization/playback/python at master · stereolabs/zed-sdk · GitHub. I adapted this file for playing back your data: zed-sdk/global localization/playback/python/gnss_replay.py at master · stereolabs/zed-sdk · GitHub and plot the heading contained in GeoPose. Nothing more.
Moreover we also provide sample for recording data. It is available here: zed-sdk/global localization/recording at master · stereolabs/zed-sdk · GitHub. It is works well with our playback sample without any code modification.
I hope this will helps you,
Tanguy
Noted. Again thanks for your efforts!
Just a small critique on the python documentation:
https://www.stereolabs.com/docs/api/python/classpyzed_1_1sl_1_1GeoPose.html#a72dc267d4eb862151328321a2a826ba0
It says that the geopose heading is in degrees and “clockwise” from north. It seems that the heading values are in radians and “counter-clockwise”.
Thank you very much for your feed-back ! Indeed this is a very nice catch it modified and supposed to be update very soon. Sorry for the inconvenience. Indeed it is radian s and increase in counter-clockwise.
