Gmsl camera detected disconnected
I have connected both a ZED X and a ZED X Mini camera to my ZED Box Orin. However, after running them for a while, I encountered the error shown in the image below.
I tried following the recommended solution by running the following command:
Sometimes the cameras start working again after restarting the service, while other times I need to reboot the entire system. However, after running for some time, the same issue occurs again.
I’m not sure whether this issue could be related to the operating temperature.
I’m using the ZED SDK with C++.
Could you please help me identify the possible cause of this issue and suggest a permanent solution?
Thank you.
Hi @patcharapon-fullstac,
The temperatures in your jtop screenshot (about 60 °C) do not point to a thermal problem; however, it was taken 14 minutes after boot, so it may not reflect the conditions at the time of the failure.
Both CAM0 and CAM1 report a configuration error at the same moment, so a common cause, like power supply or cabling, seems more likely than a single faulty camera.
Can you please share the following information?
  1. The ZED SDK and ZED X Driver versions you are using. The latest versions are ZED SDK v5.5.1 and ZED X Driver v1.4.4; ZED SDK v5.5.0 fixed GMSL cameras freezing until reboot when the sensor emits a spurious timestamp.
  2. How the ZED Box Orin is powered (original adapter, battery, or other source) and the GMSL2 cable lengths.
  3. The output of sudo journalctl -u zed_x_daemon -b and sudo dmesg, collected right after the error occurs.
  • ZED Box Duo Driver Version: 1.4.0
  • ZED SDK Version: 5.2.1
  • Power Supply: 12V lithium battery
  • GMSL2 Cable Length: 0.8 meters
  • Programming Language: C++ (ZED SDK)
I also collected the ZED X Daemon logs using the following command:
sudo journalctl -u zed_x_daemon --since "2026-11-03 12:30:00" --until "2026-11-03 13:24:00"
user@GTW-ONX16-ubuntu:~$ sudo journalctl -u zed_x_daemon --since "2026-11-03 12:30:00" --until "2026-11-03 13:24:00"
Nov 03 13:00:56 GTW-ONX16-ubuntu systemd[1]: Started ZED-X Daemon service.
Nov 03 13:06:27 GTW-ONX16-ubuntu ZEDX_Daemon[3336]: [ZED-X Daemon] Received signal, shutting down...
Nov 03 13:06:27 GTW-ONX16-ubuntu systemd[1]: Stopping ZED-X Daemon service...
Nov 03 13:06:27 GTW-ONX16-ubuntu systemd[1]: zed_x_daemon.service: Deactivated successfully.
Nov 03 13:06:27 GTW-ONX16-ubuntu systemd[1]: Stopped ZED-X Daemon service.
Nov 03 13:06:34 GTW-ONX16-ubuntu systemd[1]: Started ZED-X Daemon service.
Nov 03 13:07:37 GTW-ONX16-ubuntu ZEDX_Daemon[4737]: [ZED-X Daemon] Received signal, shutting down...
Nov 03 13:07:37 GTW-ONX16-ubuntu systemd[1]: Stopping ZED-X Daemon service...
Nov 03 13:07:37 GTW-ONX16-ubuntu systemd[1]: zed_x_daemon.service: Deactivated successfully.
Nov 03 13:07:37 GTW-ONX16-ubuntu systemd[1]: Stopped ZED-X Daemon service.
Nov 03 13:07:44 GTW-ONX16-ubuntu systemd[1]: Started ZED-X Daemon service.
Nov 03 13:09:28 GTW-ONX16-ubuntu ZEDX_Daemon[5302]: [ZED-X Daemon] Received signal, shutting down...
Nov 03 13:09:28 GTW-ONX16-ubuntu systemd[1]: Stopping ZED-X Daemon service...
Nov 03 13:09:28 GTW-ONX16-ubuntu systemd[1]: zed_x_daemon.service: Deactivated successfully.
Nov 03 13:09:28 GTW-ONX16-ubuntu systemd[1]: Stopped ZED-X Daemon service.
Nov 03 13:09:35 GTW-ONX16-ubuntu systemd[1]: Started ZED-X Daemon service.
Nov 03 13:11:12 GTW-ONX16-ubuntu ZEDX_Daemon[5740]: [ZED-X Daemon] Received signal, shutting down...
Nov 03 13:11:12 GTW-ONX16-ubuntu systemd[1]: Stopping ZED-X Daemon service...
Nov 03 13:11:12 GTW-ONX16-ubuntu systemd[1]: zed_x_daemon.service: Deactivated successfully.
Nov 03 13:11:12 GTW-ONX16-ubuntu systemd[1]: Stopped ZED-X Daemon service.
Nov 03 13:11:19 GTW-ONX16-ubuntu systemd[1]: Started ZED-X Daemon service.
Nov 03 13:14:06 GTW-ONX16-ubuntu ZEDX_Daemon[6227]: [ZED-X Daemon] Received signal, shutting down...
Nov 03 13:14:06 GTW-ONX16-ubuntu systemd[1]: Stopping ZED-X Daemon service...
Nov 03 13:14:06 GTW-ONX16-ubuntu systemd[1]: zed_x_daemon.service: Deactivated successfully.
Nov 03 13:14:06 GTW-ONX16-ubuntu systemd[1]: Stopped ZED-X Daemon service.
Nov 03 13:14:13 GTW-ONX16-ubuntu systemd[1]: Started ZED-X Daemon service.
Nov 03 13:15:16 GTW-ONX16-ubuntu ZEDX_Daemon[6723]: [ZED-X Daemon] Received signal, shutting down...
Nov 03 13:15:16 GTW-ONX16-ubuntu systemd[1]: Stopping ZED-X Daemon service...
Nov 03 13:15:16 GTW-ONX16-ubuntu systemd[1]: zed_x_daemon.service: Deactivated successfully.
Nov 03 13:15:16 GTW-ONX16-ubuntu systemd[1]: Stopped ZED-X Daemon service.
Nov 03 13:15:23 GTW-ONX16-ubuntu systemd[1]: Started ZED-X Daemon service.
Nov 03 13:18:27 GTW-ONX16-ubuntu ZEDX_Daemon[7286]: [ZED-X Daemon] Received signal, shutting down...
Nov 03 13:18:27 GTW-ONX16-ubuntu systemd[1]: Stopping ZED-X Daemon service...
Nov 03 13:18:27 GTW-ONX16-ubuntu systemd[1]: zed_x_daemon.service: Deactivated successfully.
Nov 03 13:18:27 GTW-ONX16-ubuntu systemd[1]: Stopped ZED-X Daemon service.
Nov 03 13:18:34 GTW-ONX16-ubuntu systemd[1]: Started ZED-X Daemon service.
Nov 03 13:19:36 GTW-ONX16-ubuntu ZEDX_Daemon[7784]: [ZED-X Daemon] Received signal, shutting down...
Nov 03 13:19:36 GTW-ONX16-ubuntu systemd[1]: Stopping ZED-X Daemon service...
Nov 03 13:19:36 GTW-ONX16-ubuntu systemd[1]: zed_x_daemon.service: Deactivated successfully.
Nov 03 13:19:36 GTW-ONX16-ubuntu systemd[1]: Stopped ZED-X Daemon service.
Nov 03 13:19:43 GTW-ONX16-ubuntu systemd[1]: Started ZED-X Daemon service.
Nov 03 13:20:41 GTW-ONX16-ubuntu ZEDX_Daemon[8340]: [ZED-X Daemon] Received signal, shutting down...
Nov 03 13:20:41 GTW-ONX16-ubuntu systemd[1]: Stopping ZED-X Daemon service...
Nov 03 13:20:41 GTW-ONX16-ubuntu systemd[1]: zed_x_daemon.service: Deactivated successfully.
Nov 03 13:20:41 GTW-ONX16-ubuntu systemd[1]: Stopped ZED-X Daemon service.
Nov 03 13:20:48 GTW-ONX16-ubuntu systemd[1]: Started ZED-X Daemon service.
Nov 03 13:21:58 GTW-ONX16-ubuntu ZEDX_Daemon[8772]: [ZED-X Daemon] Received signal, shutting down...
Nov 03 13:21:58 GTW-ONX16-ubuntu systemd[1]: Stopping ZED-X Daemon service...
Nov 03 13:21:58 GTW-ONX16-ubuntu systemd[1]: zed_x_daemon.service: Deactivated successfully.
Nov 03 13:21:58 GTW-ONX16-ubuntu systemd[1]: Stopped ZED-X Daemon service.
Nov 03 13:22:05 GTW-ONX16-ubuntu systemd[1]: Started ZED-X Daemon service.
Nov 03 13:23:22 GTW-ONX16-ubuntu ZEDX_Daemon[9338]: [ZED-X Daemon] Received signal, shutting down...
The logs show that the ZED X Daemon repeatedly shuts down and restarts within a short period. This happens many times, sometimes just a few minutes apart.
My main concern is whether this issue is related to temperature.
I installed the ZED Box Orin inside an enclosure and deployed it outdoors under direct sunlight. Sometimes, the temperature inside the enclosure reaches approximately 40–50°C.
I suspect temperature might be the cause because I have observed a significant difference between indoor and outdoor operation:
  • Indoor testing: The temperature inside the enclosure stays below 40°C. The cameras are relatively stable, and I have even been able to run them continuously for up to 7 hours without any disconnection.
  • Outdoor testing: Under direct sunlight, the cameras disconnect much more frequently, even though the ZED Box Orin itself does not appear to reach a particularly high temperature.
user@GTW-ONX16-ubuntu:~$ sudo dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.148-tegra (buildbrain@mobile-u64-6354-d6000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Thu Sep 18 15:08:33 PDT 2025 ()
[    0.000000] Machine model: NVIDIA Jetson Orin NX Engineering Reference Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x46d81f198 TPMFinalLog=0x45e3e0000 SMBIOS=0xffff0000 SMBIOS 3.0=0x46d210000 MEMATTR=0x467169018 ESRT=0x46719a998 TPMEventLog=0x45e3f8018 RNG=0x45a920018 MEMRESERVE=0x45e3fac18
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot disabled
[    0.000000] esrt: Reserving ESRT space from 0x000000046719a998 to 0x000000046719a9d0.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000044a000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000477ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x470247800-0x470249fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000477ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000bdffffff]
[    0.000000]   node   0: [mem 0x00000000c2000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000045e226fff]
[    0.000000]   node   0: [mem 0x000000045e227000-0x000000045e3effff]
[    0.000000]   node   0: [mem 0x000000045e3f0000-0x000000045e3fafff]
[    0.000000]   node   0: [mem 0x000000045e3fb000-0x000000045e3fbfff]
[    0.000000]   node   0: [mem 0x000000045e3fc000-0x000000046b8dffff]
[    0.000000]   node   0: [mem 0x000000046b8e0000-0x000000046d81ffff]
[    0.000000]   node   0: [mem 0x000000046d820000-0x0000000471dfffff]
[    0.000000]   node   0: [mem 0x0000000471e00000-0x0000000471ffffff]
[    0.000000]   node   0: [mem 0x0000000472000000-0x000000047259ffff]
[    0.000000]   node   0: [mem 0x0000000472f00000-0x0000000472ffffff]
[    0.000000]   node   0: [mem 0x0000000476000000-0x0000000477ffffff]
[    0.000000] mminit::pageflags_layout_widths Section 0 Node 4 Zone 2 Lastcpupid 16 Kasantag 0 Flags 24
[    0.000000] mminit::pageflags_layout_shifts Section 21 Node 4 Zone 2 Lastcpupid 16 Kasantag 0
[    0.000000] mminit::pageflags_layout_pgshifts Section 0 Node 60 Zone 58 Lastcpupid 42 Kasantag 0
[    0.000000] mminit::pageflags_layout_nodezoneid Node/Zone ID: 64 -> 58
[    0.000000] mminit::pageflags_layout_usage location: 64 -> 42 layout 42 -> 24 unused 24 -> 0 page-flags
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000477ffffff]
[    0.000000] mminit::memmap_init Initialising map node 0 zone 0 pfns 524288 -> 1048576
[    0.000000] mminit::memmap_init Initialising map node 0 zone 2 pfns 1048576 -> 4685824
[    0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[    0.000000] pcpu-alloc: s80408 r8192 d30184 u118784 alloc=29*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Address authentication (architected algorithm)
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: patching kernel code
[    0.000000] mminit::zonelist general 0:DMA = 0:DMA
[    0.000000] mminit::zonelist general 0:Normal = 0:Normal 0:DMA
[    0.000000] mminit::zonelist thisnode 0:DMA = 0:DMA
[    0.000000] mminit::zonelist thisnode 0:Normal = 0:Normal 0:DMA
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 4065440
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=PARTUUID=6693956c-0478-4f7e-a3b5-a5e44fc23e95 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb video=efifb:off console=tty0 bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00000
[    0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00000", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[    0.000000] Memory: 15745216K/16521856K available (20160K kernel code, 4064K rwdata, 10056K rodata, 7680K init, 529K bss, 514496K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000000] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000386] Console: colour dummy device 80x25
[    0.000392] printk: console [tty0] enabled
[    0.000433] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000438] pid_max: default: 32768 minimum: 301
[    0.000465] LSM: Security Framework initializing
[    0.000480] Yama: becoming mindful.
[    0.000490] SELinux:  Initializing.
[    0.000552] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.000571] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.001498] rcu: Hierarchical SRCU implementation.
[    0.004804] Tegra Revision: A01 SKU: 211 CPU Process: 0 SoC Process: 0
[    0.005242] Remapping and enabling EFI services.
[    0.006107] smp: Bringing up secondary CPUs ...
[    0.006616] Detected PIPT I-cache on CPU1
[    0.006657] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.006692] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.007152] Detected PIPT I-cache on CPU2
[    0.007163] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.007176] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.007592] Detected PIPT I-cache on CPU3
[    0.007602] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.007617] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.010084] Detected PIPT I-cache on CPU4
[    0.010110] GICv3: CPU4: found redistributor 20000 region 0:0x000000000f540000
[    0.010136] CPU4: Booted secondary processor 0x0000020000 [0x410fd421]
[    0.010612] Detected PIPT I-cache on CPU5
[    0.010623] GICv3: CPU5: found redistributor 20100 region 0:0x000000000f560000
[    0.010637] CPU5: Booted secondary processor 0x0000020100 [0x410fd421]
[    0.011068] Detected PIPT I-cache on CPU6
[    0.011079] GICv3: CPU6: found redistributor 20200 region 0:0x000000000f580000
[    0.011092] CPU6: Booted secondary processor 0x0000020200 [0x410fd421]
[    0.011532] Detected PIPT I-cache on CPU7
[    0.011544] GICv3: CPU7: found redistributor 20300 region 0:0x000000000f5a0000
[    0.011558] CPU7: Booted secondary processor 0x0000020300 [0x410fd421]
[    0.011611] smp: Brought up 1 node, 8 CPUs
[    0.011616] SMP: Total of 8 processors activated.
[    0.011619] CPU features: detected: 32-bit EL0 Support
[    0.011620] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.011622] CPU features: detected: Common not Private translations
[    0.011623] CPU features: detected: CRC32 instructions
[    0.011624] CPU features: detected: Data cache clean to Point of Persistence
[    0.011626] CPU features: detected: Generic authentication (architected algorithm)
[    0.011627] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.011628] CPU features: detected: LSE atomic instructions
[    0.011629] CPU features: detected: Privileged Access Never
[    0.011630] CPU features: detected: RAS Extension Support
[    0.011632] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.026700] spectre-bhb mitigation disabled by command line option
[    0.040771] CPU: All CPU(s) started at EL2
[    0.042487] devtmpfs: initialized
[    0.059487] KASLR enabled
[    0.059578] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.059590] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.061720] pinctrl core: initialized pinctrl subsystem
[    0.062225] SMBIOS 3.6.0 present.
[    0.062232] DMI: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.4.3-gcid-38968081 01/08/2025
[    0.062517] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.063654] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.063761] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.063856] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.063886] audit: initializing netlink subsys (disabled)
[    0.063963] audit: type=2000 audit(0.060:1): state=initialized audit_enabled=0 res=1
[    0.065277] thermal_sys: Registered thermal governor 'step_wise'
[    0.065280] thermal_sys: Registered thermal governor 'user_space'
[    0.065281] thermal_sys: Registered thermal governor 'power_allocator'
[    0.067952] cpuidle: using governor menu
[    0.068070] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.068152] ASID allocator initialised with 32768 entries
[    0.069579] Serial: AMBA PL011 UART driver
[    0.082632] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[    0.091996] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[    0.102433] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.102439] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.102441] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.102441] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.103545] cryptd: max_cpu_qlen set to 1000
[    0.105654] ACPI: Interpreter disabled.
[    0.106957] VDD_1V8_AO: supplied by VDD_5V0_SYS
[    0.107116] VDD_3V3_AO: supplied by VDD_5V0_SYS
[    0.107332] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[    0.107779] iommu: Default domain type: Translated
[    0.107785] iommu: DMA domain TLB invalidation policy: strict mode
[    0.108096] SCSI subsystem initialized
[    0.108194] libata version 3.00 loaded.
[    0.108275] vgaarb: loaded
[    0.108461] usbcore: registered new interface driver usbfs
[    0.108486] usbcore: registered new interface driver hub
[    0.108501] usbcore: registered new device driver usb
[    0.108931] pps_core: LinuxPPS API ver. 1 registered
[    0.108935] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.108952] PTP clock support registered
[    0.109037] EDAC MC: Ver: 3.0.0
[    0.110462] Registered efivars operations
[    0.111068] FPGA manager framework
[    0.111192] Advanced Linux Sound Architecture Driver Initialized.
[    0.111867] Bluetooth: Core ver 2.22
[    0.111897] NET: Registered PF_BLUETOOTH protocol family
[    0.111902] Bluetooth: HCI device and connection manager initialized
[    0.111913] Bluetooth: HCI socket layer initialized
[    0.111918] Bluetooth: L2CAP socket layer initialized
[    0.111935] Bluetooth: SCO socket layer initialized
[    0.112413] clocksource: Switched to clocksource arch_sys_counter
[    0.147054] VFS: Disk quotas dquot_6.6.0
[    0.147136] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.147373] pnp: PnP ACPI: disabled
[    0.150567] NET: Registered PF_INET protocol family
[    0.151165] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.153613] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.153795] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.153813] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.153981] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.155318] TCP: Hash tables configured (established 131072 bind 65536)
[    0.155506] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.155552] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.155780] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.156189] RPC: Registered named UNIX socket transport module.
[    0.156193] RPC: Registered udp transport module.
[    0.156195] RPC: Registered tcp transport module.
[    0.156196] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.156215] PCI: CLS 0 bytes, default 64
[    0.156493] Unpacking initramfs...
[    0.166015] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[    0.166443] kvm [1]: IPA Size Limit: 48 bits
[    0.166482] kvm [1]: GICv3: no GICV resource entry
[    0.166489] kvm [1]: disabling GICv2 emulation
[    0.166506] kvm [1]: GIC system register CPU interface enabled
[    0.166590] kvm [1]: vgic interrupt IRQ9
[    0.166766] kvm [1]: VHE mode initialized successfully
[    0.169756] Initialise system trusted keyrings
[    0.169801] Key type blacklist registered
[    0.169906] workingset: timestamp_bits=42 max_order=22 bucket_order=0
[    0.173458] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.173853] NFS: Registering the id_resolver key type
[    0.173871] Key type id_resolver registered
[    0.173875] Key type id_legacy registered
[    0.173908] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.173922] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.173946] ntfs: driver 2.1.32 [Flags: R/O].
[    0.174099] 9p: Installing v9fs 9p2000 file system support
[    0.174750] integrity: Platform Keyring initialized
[    0.185969] Key type asymmetric registered
[    0.185976] Asymmetric key parser 'x509' registered
[    0.186054] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.186064] io scheduler mq-deadline registered
[    0.186074] io scheduler kyber registered
[    0.197517] EINJ: ACPI disabled.
[    0.209651] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.211592] SuperH (H)SCI(F) driver initialized
[    0.211948] msm_serial: driver initialized
[    0.212724] printk: console [ttyTCU0] enabled
[    0.213620] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.213627] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.213635] arm-smmu 8000000.iommu: 	stage 1 translation
[    0.213636] arm-smmu 8000000.iommu: 	stage 2 translation
[    0.213638] arm-smmu 8000000.iommu: 	nested translation
[    0.213646] arm-smmu 8000000.iommu: 	stream matching with 128 register groups
[    0.213651] arm-smmu 8000000.iommu: 	128 context banks (0 stage-2 only)
[    0.213673] arm-smmu 8000000.iommu: 	Supported page sizes: 0x61311000
[    0.213674] arm-smmu 8000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.213676] arm-smmu 8000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.214684] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.214688] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.214691] arm-smmu 10000000.iommu: 	stage 1 translation
[    0.214692] arm-smmu 10000000.iommu: 	stage 2 translation
[    0.214693] arm-smmu 10000000.iommu: 	nested translation
[    0.214707] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    0.214710] arm-smmu 10000000.iommu: 	128 context banks (0 stage-2 only)
[    0.214715] arm-smmu 10000000.iommu: 	Supported page sizes: 0x61311000
[    0.214716] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.214717] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.215069] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.215073] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.215074] arm-smmu 12000000.iommu: 	stage 1 translation
[    0.215077] arm-smmu 12000000.iommu: 	stage 2 translation
[    0.215077] arm-smmu 12000000.iommu: 	nested translation
[    0.215081] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    0.215083] arm-smmu 12000000.iommu: 	128 context banks (0 stage-2 only)
[    0.215088] arm-smmu 12000000.iommu: 	Supported page sizes: 0x61311000
[    0.215091] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    0.215092] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    0.223937] loop: module loaded
[    0.224777] megasas: 07.717.02.00-rc1
[    0.228788] tun: Universal TUN/TAP device driver, 1.6
[    0.229347] thunder_xcv, ver 1.0
[    0.229378] thunder_bgx, ver 1.0
[    0.229401] nicpf, ver 1.0
[    0.230222] hclge is initializing
[    0.230254] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.230261] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.230301] e1000: Intel(R) PRO/1000 Network Driver
[    0.230306] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.230341] e1000e: Intel(R) PRO/1000 Network Driver
[    0.230345] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.230371] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.230376] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.230393] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.230397] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.230607] sky2: driver version 1.30
[    0.231261] VFIO - User Level meta-driver version: 0.3
[    0.233042] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.233052] ehci-pci: EHCI PCI platform driver
[    0.233080] ehci-platform: EHCI generic platform driver
[    0.233164] ehci-orion: EHCI orion driver
[    0.233237] ehci-exynos: EHCI Exynos driver
[    0.233303] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.233330] ohci-pci: OHCI PCI platform driver
[    0.233361] ohci-platform: OHCI generic platform driver
[    0.233436] ohci-exynos: OHCI Exynos driver
[    0.233874] usbcore: registered new interface driver usb-storage
[    0.235817] i2c_dev: i2c /dev entries driver
[    0.237127] pps pps0: new PPS source ktimer
[    0.237138] pps pps0: ktimer PPS source registered
[    0.237147] pps_ldisc: PPS line discipline registered
[    0.239254] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    0.241235] sdhci: Secure Digital Host Controller Interface driver
[    0.241240] sdhci: Copyright(c) Pierre Ossman
[    0.241669] Synopsys Designware Multimedia Card Interface Driver
[    0.242297] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.243422] ledtrig-cpu: registered to indicate activity on CPUs
[    0.244351] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.244952] tegra-bpmp bpmp: Adding to iommu group 0
[    0.246372] tegra-bpmp bpmp: firmware: dc3fd3cac60f9b918e11-da583751bbf
[    0.406683] Freeing initrd memory: 15492K
[    2.206783] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    2.206813] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[    2.206817] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    2.207028] hid: raw HID events driver (C) Jiri Kosina
[    2.207412] usbcore: registered new interface driver usbhid
[    2.207418] usbhid: USB HID core driver
[    2.211314] optee: probing for conduit method.
[    2.211377] optee: revision 4.2 (d78bc5fa)
[    2.270750] optee: dynamic shared memory is enabled
[    2.271012] optee: initialized driver
[    2.274032] usbcore: registered new interface driver snd-usb-audio
[    2.275559] NET: Registered PF_PACKET protocol family
[    2.276679] Bluetooth: RFCOMM TTY layer initialized
[    2.276715] Bluetooth: RFCOMM socket layer initialized
[    2.276749] Bluetooth: RFCOMM ver 1.11
[    2.277051] 9pnet: Installing 9P2000 support
[    2.277178] Key type dns_resolver registered
[    2.278191] printk: console [tty0]: printing thread started
[    2.278745] printk: console [ttyTCU0]: printing thread started
[    2.278892] Loading compiled-in X.509 certificates
[    2.283499] Loaded X.509 cert 'Build time autogenerated kernel key: 9709b2c1b7afae80ccbf49cf4e8a5d004d951f84'
[    2.312769] gpio-397 (camera-control-output-high): hogged as output/high
[    2.316050] gpio-331 (mux-control-output-low): hogged as output/low
[    2.317591] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    2.319017] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[    2.320609] serial-tegra 3100000.serial: RX in PIO mode
[    2.320616] serial-tegra 3100000.serial: TX in PIO mode
[    2.320683] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    2.321724] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[    2.324471] tegra_rtc c2a0000.rtc: registered as rtc1
[    2.324481] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    2.324901] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    2.328263] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    2.331866] i2c i2c-9: of_i2c: modalias failure on /bus@0/i2c@3180000/tca9546@70/i2c@0/zedxone_uhd_ser@44
[    2.331878] i2c i2c-9: Failed to create I2C device for /bus@0/i2c@3180000/tca9546@70/i2c@0/zedxone_uhd_ser@44
[    2.331885] i2c i2c-9: of_i2c: modalias failure on /bus@0/i2c@3180000/tca9546@70/i2c@0/zedxone_uhd@1a
[    2.331889] i2c i2c-9: Failed to create I2C device for /bus@0/i2c@3180000/tca9546@70/i2c@0/zedxone_uhd@1a
[    2.333431] i2c i2c-2: Added multiplexed i2c bus 9
[    2.336629] i2c i2c-2: Added multiplexed i2c bus 10
[    2.337920] i2c i2c-2: Added multiplexed i2c bus 11
[    2.339236] i2c i2c-2: Added multiplexed i2c bus 12
[    2.339267] pca954x 2-0070: registered 4 multiplexed busses for I2C switch pca9546
[    2.340416] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    2.348160] tegra-i2c c240000.i2c: Adding to iommu group 1
[    2.354999] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[    2.356060] tegra-i2c c250000.i2c: Adding to iommu group 1
[    2.363267] irq: IRQ220: trimming hierarchy from :bus@0:pmc@c360000
[    2.363429] pps pps1: new PPS source bus@0:pps.-1
[    2.363487] pps pps1: Registered IRQ 220 as PPS source
[    2.389455] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1989000 KHz, changing to: 1984000 KHz
[    2.393595] irq: IRQ221: trimming hierarchy from :bus@0:pmc@c360000
[    2.395033] tegra-xusb 3610000.usb: Adding to iommu group 2
[    2.395443]  usb2: Requested PHY is disabled
[    2.409419] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[    2.409426] tegra-xusb 3610000.usb: xHCI Host Controller
[    2.409435] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[    2.410166] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[    2.410182] tegra-xusb 3610000.usb: irq 123, io mem 0x03610000
[    2.410277] tegra-xusb 3610000.usb: xHCI Host Controller
[    2.410282] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[    2.410285] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[    2.410984] hub 1-0:1.0: USB hub found
[    2.411001] hub 1-0:1.0: 4 ports detected
[    2.411290] hub 2-0:1.0: USB hub found
[    2.411300] hub 2-0:1.0: 4 ports detected
[    2.413368] irq: IRQ229: trimming hierarchy from :bus@0:pmc@c360000
[    2.413421] irq: IRQ230: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    2.413477] irq: IRQ231: trimming hierarchy from :bus@0:pmc@c360000
[    2.413536] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    2.454410] ALSA device list:
[    2.454414]   No soundcards found.
[    2.463744] Freeing unused kernel memory: 7680K
[    2.463808] Run /init as init process
[    2.463810]   with arguments:
[    2.463810]     /init
[    2.463811]   with environment:
[    2.463811]     HOME=/
[    2.463812]     TERM=linux
[    2.463812]     bl_prof_dataptr=2031616@0x471E10000
[    2.463813]     bl_prof_ro_ptr=65536@0x471E00000
[    2.474914] Checking overlayfs setting...
[    2.482899] Overlayfs is disabled...
[    2.488280] Root device found: PARTUUID=6693956c-0478-4f7e-a3b5-a5e44fc23e95
[    2.752413] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    2.905126] hub 1-2:1.0: USB hub found
[    2.905904] hub 1-2:1.0: 4 ports detected
[    3.200580] usb 1-2.1: new full-speed USB device number 3 using tegra-xusb
[    3.318671] input: Gamepad as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.1/1-2.1:1.0/0003:2345:E05C.0001/input/input1
[    3.319275] hid-generic 0003:2345:E05C.0001: input,hidraw0: USB HID v1.10 Gamepad [Gamepad] on usb-3610000.usb-2.1/input0
[    3.322540] input: Gamepad System Control as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.1/1-2.1:1.1/0003:2345:E05C.0002/input/input2
[    3.381317] input: Gamepad Consumer Control as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.1/1-2.1:1.1/0003:2345:E05C.0002/input/input3
[    3.382512] hid-generic 0003:2345:E05C.0002: input,hidraw1: USB HID v1.01 Device [Gamepad] on usb-3610000.usb-2.1/input1
[    3.464409] usb 1-2.3: new full-speed USB device number 4 using tegra-xusb
[    5.855333] tegra194-pcie 14100000.pcie: Adding to iommu group 3
[    5.856347] irq: IRQ232: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    5.859459] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[    5.859487] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    5.859493] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    5.859496] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    5.859991] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[    5.859993] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    5.879458] tegra-xudc 3550000.usb: Adding to iommu group 4
[    6.956416] tegra194-pcie 14100000.pcie: Phy link never came up
[    7.957328] tegra194-pcie 14100000.pcie: Phy link never came up
[    7.957447] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    7.957452] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    7.957456] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    7.957460] pci_bus 0001:00: root bus resource [bus 00-ff]
[    7.957461] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    7.957519] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    7.957694] pci 0001:00:00.0: PME# supported from D0 D3hot
[    7.965918] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    7.966054] pcieport 0001:00:00.0: Adding to iommu group 3
[    7.966158] pcieport 0001:00:00.0: PME: Signaling with IRQ 190
[    7.966446] pcieport 0001:00:00.0: AER: enabled with IRQ 190
[    7.966990] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[    7.967077] pci 0001:00:00.0: Removing from iommu group 3
[    7.967087] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[    7.968914] tegra194-pcie 14160000.pcie: Adding to iommu group 5
[    7.970705] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[    7.970716] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    7.970722] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    7.970725] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    7.971036] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[    7.971038] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.076590] tegra194-pcie 14160000.pcie: Link up
[    8.079376] tegra194-pcie 14160000.pcie: Link up
[    8.079418] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    8.079422] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    8.079424] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    8.079426] pci_bus 0004:00: root bus resource [bus 00-ff]
[    8.079427] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    8.079469] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    8.079615] pci 0004:00:00.0: PME# supported from D0 D3hot
[    8.083939] pci 0004:01:00.0: [1987:5013] type 00 class 0x010802
[    8.084133] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    8.100266] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    8.100274] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[    8.100359] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    8.100363] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    8.100467] pcieport 0004:00:00.0: Adding to iommu group 5
[    8.100545] pcieport 0004:00:00.0: PME: Signaling with IRQ 192
[    8.101144] pcieport 0004:00:00.0: AER: enabled with IRQ 192
[    8.101322] nvme 0004:01:00.0: Adding to iommu group 5
[    8.101675] nvme nvme0: pci function 0004:01:00.0
[    8.101900] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    8.102217] tegra194-pcie 141e0000.pcie: Adding to iommu group 6
[    8.104200] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[    8.104211] tegra194-pcie 141e0000.pcie:      MEM 0x3000000000..0x3227ffffff -> 0x3000000000
[    8.104216] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    8.104220] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    8.104516] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[    8.104519] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.139073] nvme nvme0: allocated 128 MiB host memory buffer.
[    8.150161] nvme nvme0: 8/0/0 default/read/poll queues
[    8.155400]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    8.212413] tegra194-pcie 141e0000.pcie: Link up
[    8.213995] tegra194-pcie 141e0000.pcie: Link up
[    8.214053] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    8.214058] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[    8.214061] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[    8.214064] pci_bus 0007:00: root bus resource [bus 00-ff]
[    8.214065] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227ffffff pref]
[    8.214109] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[    8.214248] pci 0007:00:00.0: PME# supported from D0 D3hot
[    8.218722] pci 0007:01:00.0: [8086:2725] type 00 class 0x028000
[    8.218906] pci 0007:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    8.219847] pci 0007:01:00.0: PME# supported from D0 D3hot D3cold
[    8.236325] pci 0007:00:00.0: BAR 14: assigned [mem 0x3228000000-0x32280fffff]
[    8.236332] pci 0007:01:00.0: BAR 0: assigned [mem 0x3228000000-0x3228003fff 64bit]
[    8.236418] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[    8.236423] pci 0007:00:00.0:   bridge window [mem 0x3228000000-0x32280fffff]
[    8.236556] pcieport 0007:00:00.0: Adding to iommu group 6
[    8.236651] pcieport 0007:00:00.0: PME: Signaling with IRQ 194
[    8.237621] pcieport 0007:00:00.0: AER: enabled with IRQ 194
[    8.238569] tegra194-pcie 140a0000.pcie: Adding to iommu group 7
[    8.349664] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ranges:
[    8.349690] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[    8.349699] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[    8.349704] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[    8.350023] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[    8.350025] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.456588] tegra194-pcie 140a0000.pcie: Link up
[    8.458095] tegra194-pcie 140a0000.pcie: Link up
[    8.458161] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[    8.458165] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[    8.458169] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[    8.458172] pci_bus 0008:00: root bus resource [bus 00-ff]
[    8.458178] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[    8.458221] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[    8.458371] pci 0008:00:00.0: PME# supported from D0 D3hot
[    8.462969] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[    8.463153] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    8.463361] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    8.463478] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    8.464464] pci 0008:01:00.0: supports D1 D2
[    8.464466] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    8.476356] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    8.480332] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[    8.480338] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]
[    8.480342] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[    8.480444] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[    8.480536] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]
[    8.480564] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[    8.480567] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]
[    8.480571] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[    8.480707] pcieport 0008:00:00.0: Adding to iommu group 7
[    8.480809] pcieport 0008:00:00.0: PME: Signaling with IRQ 188
[    8.481476] pcieport 0008:00:00.0: AER: enabled with IRQ 188
[    8.512569] Rootfs mounted over PARTUUID=6693956c-0478-4f7e-a3b5-a5e44fc23e95
[    8.520006] Switching from initrd to actual rootfs
[    8.594811] systemd[1]: System time before build time, advancing clock.
[    8.615320] NET: Registered PF_INET6 protocol family
[    8.615708] Segment Routing with IPv6
[    8.615715] In-situ OAM (IOAM) with IPv6
[    8.631547] systemd[1]: systemd 249.11-0ubuntu3.21 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    8.631893] systemd[1]: Detected architecture arm64.
[    8.647523] systemd[1]: Hostname set to <GTW-ONX16-ubuntu>.
[    8.660552] systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', version 0, device /dev/watchdog
[    8.660572] systemd[1]: Set hardware watchdog to 2min.
[    8.788101] systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[    8.815586] systemd[1]: /lib/systemd/system/snapd.service:23: Unknown key name 'RestartMode' in section 'Service', ignoring.
[    8.834363] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    8.840815] systemd[1]: /etc/systemd/system/nvargus-daemon.service:44: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    8.888905] systemd[1]: Queued start job for default target Graphical Interface.
[    8.890804] systemd[1]: Created slice Slice /system/modprobe.
[    8.891529] systemd[1]: Created slice Slice /system/serial-getty.
[    8.892141] systemd[1]: Created slice Slice /system/systemd-fsck.
[    8.892605] systemd[1]: Created slice User and Session Slice.
[    8.893804] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    8.894142] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.894293] systemd[1]: Reached target Slice Units.
[    8.894347] systemd[1]: Reached target Mounting snaps.
[    8.894396] systemd[1]: Reached target Swaps.
[    8.894448] systemd[1]: Reached target Local Verity Protected Volumes.
[    8.894587] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    8.894803] systemd[1]: Listening on LVM2 poll daemon socket.
[    8.900718] systemd[1]: Listening on RPCbind Server Activation Socket.
[    8.901112] systemd[1]: Listening on Syslog Socket.
[    8.901321] systemd[1]: Listening on fsck to fsckd communication Socket.
[    8.901459] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    8.901794] systemd[1]: Listening on Journal Audit Socket.
[    8.901953] systemd[1]: Listening on Journal Socket (/dev/log).
[    8.902163] systemd[1]: Listening on Journal Socket.
[    8.902402] systemd[1]: Listening on Network Service Netlink Socket.
[    8.902605] systemd[1]: Listening on udev Control Socket.
[    8.902745] systemd[1]: Listening on udev Kernel Socket.
[    8.903948] systemd[1]: Mounting Huge Pages File System...
[    8.905338] systemd[1]: Mounting POSIX Message Queue File System...
[    8.947689] systemd[1]: Mounting Kernel Debug File System...
[    8.959622] systemd[1]: Mounting Kernel Trace File System...
[    8.962606] systemd[1]: Starting Journal Service...
[    8.969444] systemd[1]: Finished Availability of block devices.
[    8.971042] systemd[1]: Starting Set the console keyboard layout...
[    8.972448] systemd[1]: Starting Create List of Static Device Nodes...
[    8.989770] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    8.991180] systemd[1]: Starting Load Kernel Module configfs...
[    8.992531] systemd[1]: Starting Load Kernel Module drm...
[    9.011332] systemd[1]: Starting Load Kernel Module efi_pstore...
[    9.012615] systemd[1]: Starting Load Kernel Module fuse...
[    9.019108] fuse: init (API version 7.34)
[    9.025818] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[    9.027334] systemd[1]: Starting NVIDIA specific first-boot udev script...
[    9.028797] systemd[1]: Started Nameserver information manager.
[    9.048348] systemd[1]: Reached target Preparation for Network.
[    9.054429] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    9.056235] systemd[1]: Starting Load Kernel Modules...
[    9.057914] systemd[1]: Starting Remount Root and Kernel File Systems...
[    9.063556] nvsciipc: loading out-of-tree module taints kernel.
[    9.064429] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null). Quota mode: none.
[    9.064593] nvsciipc: loaded module
[    9.070645] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    9.071274] nvmap_page_pool_init: Total RAM pages: 4007633
[    9.071277] nvmap_page_pool_init: nvmap page pool size: 500954 pages (1956 MB)
[    9.071345] nvmap_background_zero_thread: PP zeroing thread starting.
[    9.078174] tegra-host1x 13e00000.host1x: Adding to iommu group 8
[    9.079330] host1x-context host1x-ctx.0: Adding to iommu group 9
[    9.079452] host1x-context host1x-ctx.1: Adding to iommu group 10
[    9.079560] host1x-context host1x-ctx.2: Adding to iommu group 11
[    9.079665] host1x-context host1x-ctx.3: Adding to iommu group 12
[    9.079770] host1x-context host1x-ctx.4: Adding to iommu group 13
[    9.079872] host1x-context host1x-ctx.5: Adding to iommu group 14
[    9.079974] host1x-context host1x-ctx.6: Adding to iommu group 15
[    9.080100] host1x-context host1x-ctx.7: Adding to iommu group 16
[    9.080202] host1x-context host1x-ctx.8: Adding to iommu group 17
[    9.080307] host1x-context host1x-ctx.9: Adding to iommu group 18
[    9.080424] host1x-context host1x-ctx.10: Adding to iommu group 19
[    9.080533] host1x-context host1x-ctx.11: Adding to iommu group 20
[    9.080645] host1x-context host1x-ctx.12: Adding to iommu group 21
[    9.080754] host1x-context host1x-ctx.13: Adding to iommu group 22
[    9.080867] host1x-context host1x-ctx.14: Adding to iommu group 23
[    9.080971] host1x-context host1x-ctx.15: Adding to iommu group 24
[    9.088757] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-0028
[    9.088776] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-0020
[    9.088791] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-0038
[    9.088804] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-0030
[    9.088818] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-0010
[    9.088830] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-0011
[    9.088842] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-001a
[    9.088858] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-003e
[    9.088870] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-002e
[    9.088885] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-003f
[    9.088897] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-002f
[    9.088908] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-004e
[    9.088921] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-004f
[    9.088933] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-0028
[    9.088945] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-0020
[    9.088961] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-0038
[    9.088975] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-0030
[    9.088990] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-0010
[    9.089003] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-0011
[    9.089015] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-001a
[    9.089029] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-003e
[    9.089043] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-002e
[    9.089054] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-003f
[    9.089068] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-002f
[    9.089081] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-004e
[    9.089096] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 10-004f
[    9.089108] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with tegra-capture-vi
[    9.105093] systemd[1]: Starting Coldplug All udev Devices...
[    9.131840] nvgpu: 17000000.gpu          nvgpu_nvhost_syncpt_init:122  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.156793] systemd[1]: Started Journal Service.
[    9.495931] systemd-journald[292]: Received client request to flush runtime journal.
[    9.697281] mc: Linux media interface: v0.10
[    9.705840] videodev: Linux video capture interface: v2.00
[    9.722676] scare-pigeon 13e00000.host1x:vi0-thi@15f00000: Adding to iommu group 25
[    9.724878] tegra-soc-hwpm f100000.hwpm: Adding to iommu group 26
[    9.864657] scare-pigeon 13e00000.host1x:vi0-thi@15f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.868445] scare-pigeon 13e00000.host1x:vi1-thi@14f00000: Adding to iommu group 27
[    9.873447] scare-pigeon 13e00000.host1x:vi1-thi@14f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.880808] scare-pigeon 13e00000.host1x:isp-thi@14b00000: Adding to iommu group 28
[    9.884877] scare-pigeon 13e00000.host1x:isp-thi@14b00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.978924] nvdla 15880000.nvdla0: Adding to iommu group 29
[    9.983213] pva 16000000.pva0: Adding to iommu group 30
[    9.985333] nvdla 15880000.nvdla0: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.985531] nvdla 158c0000.nvdla1: Adding to iommu group 31
[    9.995572] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 32
[    9.995869] nvdla 158c0000.nvdla1: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[    9.996198] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[   10.006927] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 33
[   10.008283] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[   10.009529] tegra-vic 15340000.vic: Adding to iommu group 34
[   10.015006] Inserting ivc_ext.ko module
[   10.016344] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 35
[   10.017577] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[   10.028139] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 36
[   10.031424] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[   10.036540] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 37
[   10.038287] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[   10.040454] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee027f size=131712
[   10.040891] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[   10.042042] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x512]=0x1900-0x1b80 TX[1x512]=0x1b80-0x1e00
[   10.042624] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1e00-0x3e80 TX[1x8192]=0x3e80-0x5f00
[   10.044372] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 38
[   10.044939] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[   10.056013] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5f00-0xaf80 TX[64x320]=0xaf80-0x10000
[   10.056428] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0x10000-0x18080 TX[512x64]=0x18080-0x20100
[   10.056644] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20100-0x201c0 TX[1x64]=0x201c0-0x20280
[   10.056956] tegra-nvdec 15480000.nvdec: Adding to iommu group 39
[   10.065305] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (218)
[   10.065314] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[   10.065620] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=e2238c99959d2df9350d393f04e1f44e5bef98cb
[   10.065749] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[   10.065753] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[   10.065757] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[   10.065759] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[   10.065762] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[   10.065764] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[   10.065770] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.065774] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.066570] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 40
[   10.067761] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[   10.072379] capture_ivc: module verification failed: signature and/or required key missing - tainting kernel
[   10.076678] tegra-nvenc 154c0000.nvenc: Adding to iommu group 41
[   10.081797] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 42
[   10.081924] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[   10.084427] [RCE] TCU debug prints will be routed to traces.
[   10.090380] tegra-nvjpg 15380000.nvjpg: Adding to iommu group 43
[   10.095114] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 44
[   10.096816] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[   10.102529] pva 16000000.pva0: pdata->version is HW_GEN2
[   10.104751] tegra-nvjpg 15540000.nvjpg: Adding to iommu group 45
[   10.108929] pva 16000000.pva0: Completed nvhost_client_device_init
[   10.110142] pva 16000000.pva0: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   10.126346] tegra-ofa 15a50000.ofa: Adding to iommu group 46
[   10.132723] drm drm: [drm] Cannot find any crtc or sizes
[   10.149861] [drm] Initialized tegra 1.0.99 20120330 for drm on minor 0
[   10.317169] tegra-dce d800000.dce: Adding to iommu group 47
[   10.317822] tegra194-vi5 13e00000.host1x:vi0@15c00000: Adding to iommu group 25
[   10.317885] dce: dce_ipc_channel_init:311  Invalid Channel State [0x0] for ch_type [2]
[   10.318074] tegra194-isp5 14800000.isp: Adding to iommu group 28
[   10.318160] dce: tegra_dce_probe:245  Found display consumer device
[   10.318906] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x5]
[   10.318912] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x5]
[   10.319161] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319174] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319179] dce: dce_admin_send_cmd_ver:456  version : [0x3] err : [0x0]
[   10.319180] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319188] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319194] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319202] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319207] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319212] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319216] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319222] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319232] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319237] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319244] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319249] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319256] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319262] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319268] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319274] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319281] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319294] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319301] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319309] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319316] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319324] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319331] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319339] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[   10.319381] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x1]
[   10.319387] dce: dce_admin_setup_clients_ipc:585  Channel Reset Complete for Type [1] ...
[   10.319388] dce: dce_admin_setup_clients_ipc:561  Get queue info failed for [2]
[   10.319596] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x2]
[   10.319601] dce: dce_admin_setup_clients_ipc:585  Channel Reset Complete for Type [3] ...
[   10.320283] tegra194-vi5 13e00000.host1x:vi1@14c00000: Adding to iommu group 27
[   10.320378] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[   10.320500] (NULL device *): fops function table already registered
[   10.320583] dce: dce_start_boot_flow:166  DCE_BOOT_DONE
[   10.320669] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[   10.321478] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[   10.392353] nv_platform 13800000.display: Adding to iommu group 48
[   10.402536] at24 0-0050: 256 byte 24c02 EEPROM, read-only
[   10.404352] platform 13800000.display:nvdisplay-niso: Adding to iommu group 49
[   10.436878] spi-tegra114 3210000.spi: Adding to iommu group 1
[   10.451303] r8168 0008:01:00.0: Adding to iommu group 7
[   10.454628] r8168 Gigabit Ethernet driver 8.053.00-NAPI loaded
[   10.454705] r8168 0008:01:00.0: enabling device (0000 -> 0003)
[   10.483620] spi-tegra114 3230000.spi: Adding to iommu group 1
[   10.488348] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[   10.490424] r8168  Copyright (C) 2024 Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[   10.490626] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   10.490967] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   10.491135] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   10.506308] tegra-hda 3510000.hda: Adding to iommu group 50
[   10.510673] Intel(R) Wireless WiFi driver for Linux
[   10.510818] iwlwifi 0007:01:00.0: Adding to iommu group 6
[   10.510940] iwlwifi 0007:01:00.0: enabling device (0000 -> 0002)
[   10.541786] iwlwifi 0007:01:00.0: Direct firmware load for iwlwifi-ty-a0-gf-a0-66.ucode failed with error -2
[   10.541794] iwlwifi 0007:01:00.0: Falling back to sysfs fallback for: iwlwifi-ty-a0-gf-a0-66.ucode
[   10.614580] CAN device driver interface
[   10.621624] tegra234-aon c000000.aon: Adding to iommu group 51
[   10.623540]  c000000.aon:hsp: probed
[   10.625459] tegra234-aon c000000.aon: init done
[   10.626250] thermal-trip-event cpu-throttle-alert: cooling device registered.
[   10.629294] thermal-trip-event gpu-throttle-alert: cooling device registered.
[   10.632320] thermal-trip-event cv0-throttle-alert: cooling device registered.
[   10.649372] thermal-trip-event cv1-throttle-alert: cooling device registered.
[   10.657141] thermal-trip-event cv2-throttle-alert: cooling device registered.
[   10.657689] TT CAN feature is not supported
[   10.659650] 	 Message RAM Configuration
               	| base addr   |0x0c312000|
               	| sidfc_flssa |0x00000000|
               	| xidfc_flesa |0x00000040|
               	| rxf0c_f0sa  |0x000000c0|
               	| rxf1c_f1sa  |0x000009c0|
               	| rxbc_rbsa   |0x000009c0|
               	| txefc_efsa  |0x000009c0|
               	| txbc_tbsa   |0x00000a40|
               	| tmc_tmsa    |0x00000ec0|
               	| mram size   |0x00001000|
[ 10.661152\] Release 3.2.3 from 09.06.2018
\[ 10.670350\] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=3 as /devices/platform/bus@0/3510000.hda/sound/card0/input4
\[ 10.670642\] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=7 as /devices/platform/bus@0/3510000.hda/sound/card0/input5
\[ 10.670729\] net can0: mttcan device registered (regs=000000007ce81c71, irq=200)
\[ 10.672111\] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=8 as /devices/platform/bus@0/3510000.hda/sound/card0/input6
\[ 10.672196\] thermal-trip-event soc0-throttle-alert: cooling device registered.
\[ 10.673043\] gic 2a41000.interrupt-controller: GIC IRQ controller registered
\[ 10.673526\] tegra-aconnect bus@0:aconnect@2900000: Tegra ACONNECT bus registered
\[ 10.674466\] thermal-trip-event soc1-throttle-alert: cooling device registered.
\[ 10.677639\] input: NVIDIA Jetson Orin NX HDA HDMI/DP,pcm=9 as /devices/platform/bus@0/3510000.hda/sound/card0/input7
\[ 10.689267\] irq: type mismatch, failed to map hwirq-131 for gpio@2200000!
\[ 10.690162\] fusb301 1-0025: failed to read device id, err : 0xffffff87
\[ 10.690170\] fusb301 1-0025: fusb301 not support
\[ 10.690176\] fusb301: probe of 1-0025 failed with error -22
\[ 10.694025\] cdi_tsc c6a0000.tsc_sig_gen: CDI TSC probing...
\[ 10.695699\] cdi_tsc c6a0000.tsc_sig_gen: cdi_tsc_probe: Initializing the driver
\[ 10.696102\] thermal-trip-event soc2-throttle-alert: cooling device registered.
\[ 10.701101\] cdi_tsc c6a0000.tsc_sig_gen: cdi_tsc_probe: Successfully initialized the tsc char driver
\[ 10.706807\] thermal-trip-event hot-surface-alert: cooling device registered.
\[ 10.765939\] usbcore: registered new interface driver btusb
\[ 10.769808\] Bluetooth: hci0: Firmware timestamp 2022.5 buildtype 1 build 38020
\[ 10.776297\] Bluetooth: hci0: Found device firmware: intel/ibt-0041-0041.sfi
\[ 10.776324\] Bluetooth: hci0: Boot Address: 0x100800
\[ 10.776326\] Bluetooth: hci0: Firmware Version: 132-5.22
\[ 10.776328\] Bluetooth: hci0: Firmware already loaded
\[ 10.928978\] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
\[ 10.930060\] nvvrs-pseq-rtc nvvrs-pseq-rtc: setting system clock to 2026-11-03T06:00:46 UTC (1793685646)
\[ 10.958281\] r8168 0008:01:00.0 enP8p1s0: renamed from eth0
\[ 10.978510\] loop0: detected capacity change from 0 to 8
\[ 10.987056\] loop1: detected capacity change from 0 to 377544
\[ 11.019167\] loop2: detected capacity change from 0 to 382632
\[ 11.021331\] iwlwifi 0007:01:00.0: Direct firmware load for iwlwifi-ty-a0-gf-a0-65.ucode failed with error -2
\[ 11.021338\] iwlwifi 0007:01:00.0: Falling back to sysfs fallback for: iwlwifi-ty-a0-gf-a0-65.ucode
\[ 11.057616\] loop3: detected capacity change from 0 to 141232
\[ 11.065041\] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
\[ 11.065049\] unable to read xattr id index table
\[ 11.085200\] loop4: detected capacity change from 0 to 141288
\[ 11.088752\] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
\[ 11.088758\] unable to read xattr id index table
\[ 11.093802\] loop5: detected capacity change from 0 to 126688
\[ 11.098843\] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
\[ 11.098848\] unable to read xattr id index table
\[ 11.134429\] loop6: detected capacity change from 0 to 126640
\[ 11.140689\] iwlwifi 0007:01:00.0: Direct firmware load for iwlwifi-ty-a0-gf-a0-64.ucode failed with error -2
\[ 11.140698\] iwlwifi 0007:01:00.0: Falling back to sysfs fallback for: iwlwifi-ty-a0-gf-a0-64.ucode
\[ 11.140776\] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
\[ 11.140779\] unable to read xattr id index table
\[ 11.155760\] loop7: detected capacity change from 0 to 110976
\[ 11.167582\] iwlwifi 0007:01:00.0: api flags index 2 larger than supported by driver
\[ 11.167620\] iwlwifi 0007:01:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.25
\[ 11.168055\] iwlwifi 0007:01:00.0: loaded firmware version 63.c04f3485.0 ty-a0-gf-a0-63.ucode op_mode iwlmvm
\[ 11.175001\] loop8: detected capacity change from 0 to 111936
\[ 11.184534\] enP8p1s0: 0xffff800008fbd000, 4c:bb:47:02:14:ce, IRQ 256
\[ 11.194686\] loop9: detected capacity change from 0 to 98784
\[ 11.209980\] tegra-adma 2930000.dma-controller: Tegra210 ADMA driver registered 32 channels
\[ 11.210053\] loop10: detected capacity change from 0 to 98792
\[ 11.219001\] loop11: detected capacity change from 0 to 501888
\[ 11.219502\] loop12: detected capacity change from 0 to 511520
\[ 11.226136\] loop13: detected capacity change from 0 to 1149192
\[ 11.229832\] loop14: detected capacity change from 0 to 1150960
\[ 11.231892\] loop15: detected capacity change from 0 to 187776
\[ 11.246192\] loop16: detected capacity change from 0 to 357512
\[ 11.246812\] loop17: detected capacity change from 0 to 385528
\[ 11.247701\] loop18: detected capacity change from 0 to 89112
\[ 11.252227\] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
\[ 11.252234\] unable to read xattr id index table
\[ 11.253009\] loop19: detected capacity change from 0 to 79128
\[ 11.257419\] iwlwifi 0007:01:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
\[ 11.258301\] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
\[ 11.258305\] unable to read xattr id index table
\[ 11.263881\] thermal thermal_zone9: failed to read out thermal zone (-61)
\[ 11.346647\] tegra210-admaif 290f000.admaif: Adding to iommu group 52
\[ 11.409859\] iwlwifi 0007:01:00.0: loaded PNVM version 0x581d4936
\[ 11.421194\] iwlwifi 0007:01:00.0: Detected RF GF, rfid=0x10d000
\[ 11.488640\] iwlwifi 0007:01:00.0: base HW address: e4:4a:e0:21:ae:e4
\[ 11.509473\] iwlwifi 0007:01:00.0 wlP7p1s0: renamed from wlan0
\[ 13.529269\] using random self ethernet address
\[ 13.529277\] using random host ethernet address
\[ 13.568759\] loop20: detected capacity change from 0 to 32768
\[ 13.578133\] FAT-fs (loop20): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
\[ 13.586783\] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
\[ 13.586795\] Bluetooth: BNEP filters: protocol multicast
\[ 13.586806\] Bluetooth: BNEP socket layer initialized
\[ 13.599618\] NET: Registered PF_ALG protocol family
\[ 13.640398\] nv_nvsciipc_init.sh\[919\]: found /dev/nvsciipc
\[ 13.650743\] nvsciipc: set_db start
\[ 13.650771\] nvsciipc: set_db done
\[ 13.740750\] Mass Storage Function, version: 2009/09/11
\[ 13.740760\] LUN: removable file: (no medium)
\[ 13.751931\] using random self ethernet address
\[ 13.751940\] using random host ethernet address
\[ 13.774671\] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
\[ 13.779748\] usb0: HOST MAC de:ba:11:ff:ec:ac
\[ 13.779757\] usb0: MAC de:ba:11:ff:ec:ad
\[ 13.783049\] usb1: HOST MAC de:ba:11:ff:ec:ae
\[ 13.783058\] usb1: MAC de:ba:11:ff:ec:af
\[ 13.783086\] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
\[ 13.939918\] pstore: Using crash dump compression: deflate
\[ 13.940032\] printk: console \[ramoops-1\]: printing thread started
\[ 13.940058\] printk: console \[ramoops-1\] enabled
\[ 13.940060\] pstore: Registered ramoops as persistent store backend
\[ 13.940062\] ramoops: using 0x200000@0x4725f0000, ecc: 0
\[ 14.032672\] ACPI: <n/a>: failed to evaluate \_DSM (0x1001)
\[ 14.032684\] ACPI: <n/a>: failed to evaluate \_DSM (0x1001)
\[ 14.032686\] ACPI: <n/a>: failed to evaluate \_DSM (0x1001)
\[ 14.032687\] ACPI: <n/a>: failed to evaluate \_DSM (0x1001)
\[ 14.034695\] l4tbr0: port 1(usb0) entered blocking state
\[ 14.034709\] l4tbr0: port 1(usb0) entered disabled state
\[ 14.034846\] device usb0 entered promiscuous mode
\[ 14.041752\] l4tbr0: port 2(usb1) entered blocking state
\[ 14.041775\] l4tbr0: port 2(usb1) entered disabled state
\[ 14.041982\] device usb1 entered promiscuous mode
\[ 14.049582\] loop20: detected capacity change from 0 to 32768
\[ 14.137819\] nvgpu: 17000000.gpu gk20a_scale_init:541 \[INFO\] enabled scaling for GPU
\[ 14.218559\] zram: Added device: zram0
\[ 14.241050\] zram: Added device: zram1
\[ 14.242167\] zram: Added device: zram2
\[ 14.302144\] zram: Added device: zram3
\[ 14.303114\] zram: Added device: zram4
\[ 14.303285\] zram: Added device: zram5
\[ 14.303426\] zram: Added device: zram6
\[ 14.303560\] zram: Added device: zram7
\[ 14.313763\] r8168: enP8p1s0: link up
\[ 14.313845\] IPv6: ADDRCONF(NETDEV_CHANGE): enP8p1s0: link becomes ready
\[ 14.383852\] zram0: detected capacity change from 0 to 2003816
\[ 14.398606\] Adding 1001904k swap on /dev/zram0. Priority:5 extents:1 across:1001904k SS
\[ 14.403063\] zram1: detected capacity change from 0 to 2003816
\[ 14.410597\] Adding 1001904k swap on /dev/zram1. Priority:5 extents:1 across:1001904k SS
\[ 14.416609\] zram2: detected capacity change from 0 to 2003816
\[ 14.434762\] Adding 1001904k swap on /dev/zram2. Priority:5 extents:1 across:1001904k SS
\[ 14.437170\] zram3: detected capacity change from 0 to 2003816
\[ 14.444354\] Adding 1001904k swap on /dev/zram3. Priority:5 extents:1 across:1001904k SS
\[ 14.450106\] zram4: detected capacity change from 0 to 2003816
\[ 14.450630\] sl_max96712 9-0029: Driver Version : v1.4.0
\[ 14.459872\] Adding 1001904k swap on /dev/zram4. Priority:5 extents:1 across:1001904k SS
\[ 14.471716\] zram5: detected capacity change from 0 to 2003816
\[ 14.482346\] Adding 1001904k swap on /dev/zram5. Priority:5 extents:1 across:1001904k SS
\[ 14.484762\] zram6: detected capacity change from 0 to 2003816
\[ 14.498804\] Adding 1001904k swap on /dev/zram6. Priority:5 extents:1 across:1001904k SS
\[ 14.504086\] zram7: detected capacity change from 0 to 2003816
\[ 14.518552\] Adding 1001904k swap on /dev/zram7. Priority:5 extents:1 across:1001904k SS
\[ 14.559201\] overlayfs: idmapped layers are currently not supported
\[ 14.572660\] sl_max96712 9-0029: slow_reset_Dser: Setup Deser as 2 lanes output
\[ 15.649376\] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: Active GMSL ports : 2
\[ 15.916891\] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: No camera connected to GMSL port 0
\[ 16.007230\] loop21: detected capacity change from 0 to 8
\[ 16.349067\] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: No camera connected to GMSL port 1
\[ 16.616977\] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: Camera connected to GMSL port 2
\[ 16.688947\] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 540.4.0 Release Build (buildbrain@mobile-u64-6354-d6000) Thu Sep 18 15:33:51 PDT 2025
\[ 16.699793\] \[drm\] \[nvidia-drm\] \[GPU ID 0x00020000\] Loading driver
\[ 16.996841\] \[drm\] Initialized nvidia-drm 0.0.0 20160202 for 13800000.display on minor 1
\[ 16.997162\] nv_platform 13800000.display: \[drm\] Cannot find any crtc or sizes
\[ 17.352914\] sl_max96712 9-0029: sl_max96712_get_camera_model: zedx camera connected to this port
\[ 17.382273\] sl_max96712 9-0029: sl_max96712_pipes_setup: camera pipeline operational
\[ 17.382284\] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: GMSL #2 : Link Camera zedx (id: 0) to port-index 0
\[ 17.497162\] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: Camera connected to GMSL port 3
\[ 18.236901\] sl_max96712 9-0029: sl_max96712_get_camera_model: zedx camera connected to this port
\[ 18.266314\] sl_max96712 9-0029: sl_max96712_pipes_setup: camera pipeline operational
\[ 18.266324\] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: GMSL #3 : Link Camera zedx (id: 2) to port-index 2
\[ 18.485054\] sl_max96712 9-0029: sl_max96712_probe: success
\[ 18.497664\] sl_max9295 9-0062: Driver Version : v1.4.0
\[ 18.720425\] sl_max9295 9-0062: probe_serializer: Serializer pipeline operational
\[ 18.722209\] sl_max9295 9-0062: probe_serializer: Serializer for zedx detect success
\[ 18.727146\] sl_max9295 10-0062: Driver Version : v1.4.0
\[ 18.948424\] sl_max9295 10-0062: probe_serializer: Serializer pipeline operational
\[ 18.949275\] sl_max9295 10-0062: probe_serializer: Serializer for zedx detect success
\[ 18.971721\] zedx 9-0020: Driver Version : v1.4.0
\[ 18.972087\] zedx 9-0020: tegracam sensor driver:video1_v2.0.6
\[ 19.302882\] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 9-0020 bound
\[ 19.350030\] zedx 9-0020: ZED-X sensor initialisation done
\[ 19.350039\] zedx 9-0020: zedx_probe: Serial Number : 53906460
\[ 19.350052\] Video device name is video0
\[ 19.350056\] Video device ID is 0
\[ 19.350147\] zedx 9-0020: zedx_probe: success
\[ 19.352395\] zedx 9-0028: Driver Version : v1.4.0
\[ 19.352847\] zedx 9-0028: tegracam sensor driver:video0_v2.0.6
\[ 19.683730\] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 9-0028 bound
\[ 19.684509\] zedx 9-0028: ZED-X sensor initialisation done
\[ 19.684516\] zedx 9-0028: zedx_probe: Serial Number : 53906460
\[ 19.684529\] Video device name is video1
\[ 19.684532\] Video device ID is 1
\[ 19.684550\] zedx 9-0028: zedx_probe: success
\[ 19.687455\] zedx 10-0020: Driver Version : v1.4.0
\[ 19.687619\] zedx 10-0020: tegracam sensor driver:video14_v2.0.6
\[ 20.020573\] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 10-0020 bound
\[ 20.021279\] zedx 10-0020: ZED-X sensor initialisation done
\[ 20.021285\] zedx 10-0020: zedx_probe: Serial Number : 44541403
\[ 20.021296\] Video device name is video2
\[ 20.021300\] Video device ID is 2
\[ 20.021322\] zedx 10-0020: zedx_probe: success
\[ 20.022107\] zedx 10-0028: Driver Version : v1.4.0
\[ 20.022279\] zedx 10-0028: tegracam sensor driver:video13_v2.0.6
\[ 20.352729\] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 10-0028 bound
\[ 20.354223\] zedx 10-0028: ZED-X sensor initialisation done
\[ 20.354233\] zedx 10-0028: zedx_probe: Serial Number : 44541403
\[ 20.354245\] Video device name is video3
\[ 20.354248\] Video device ID is 3
\[ 20.354271\] zedx 10-0028: zedx_probe: success
\[ 20.502575\] rfkill: input handler disabled
\[ 20.567670\] bmi088 9-004b: removed
\[ 20.567687\] bmi088: probe of 9-004b failed with error -5
\[ 20.587064\] audit: type=1326 audit(1793685656.152:2): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=2632 comm="cupsd" exe="/snap/cups/1264/sbin/cupsd" sig=0 arch=c00000b7 syscall=55 compat=0 ip=0xffff828a7a4c code=0x50000
\[ 20.671279\] bmi088 9-003b: probe done
\[ 20.773190\] bmi088 10-004b: removed
\[ 20.773206\] bmi088: probe of 10-004b failed with error -5
\[ 20.874915\] bmi088 10-003b: probe done
\[ 27.645776\] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
\[ 60.103650\] nvgpu: 17000000.gpu railgate_enable_store:365 \[INFO\] railgate is disabled.
\[ 507.586844\] bmi_spsc spsc_bmi1: spsc_bmi1: I/O error, stopping acquisition (use timer_control to restart)
\[ 507.590598\] bmi_spsc spsc_bmi0: spsc_bmi0: I/O error, stopping acquisition (use timer_control to restart)
\[ 533.195551\] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 10-0028 unbind
\[ 533.195891\] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 10-0020 unbind
\[ 533.196235\] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 9-0028 unbind
\[ 533.196723\] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 9-0020 unbind
\[ 533.274825\] sl_max9295 10-0062: ZED-X serializer successfully removed
\[ 533.274927\] sl_max9295 9-0062: ZED-X serializer successfully removed
\[ 533.298818\] sl_max96712 9-0029: sl_max96712_remove: success
\[ 533.331412\] sl_max96712 9-0029: Driver Version : v1.4.0
\[ 533.446658\] sl_max96712 9-0029: slow_reset_Dser: Setup Deser as 2 lanes output
\[ 534.520849\] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: Active GMSL ports : 2
\[ 534.792814\] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: No camera connected to GMSL port 0
\[ 535.220793\] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: No camera connected to GMSL port 1
\[ 535.488860\] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: Camera connected to GMSL port 2
\[ 536.224820\] sl_max96712 9-0029: sl_max96712_get_camera_model: zedx camera connected to this port
\[ 536.252419\] sl_max96712 9-0029: sl_max96712_pipes_setup: camera pipeline operational
\[ 536.252422\] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: GMSL #2 : Link Camera zedx (id: 0) to port-index 0
\[ 536.360855\] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: Camera connected to GMSL port 3
\[ 537.096846\] sl_max96712 9-0029: sl_max96712_get_camera_model: zedx camera connected to this port
\[ 537.124494\] sl_max96712 9-0029: sl_max96712_pipes_setup: camera pipeline operational
\[ 537.124497\] sl_max96712 9-0029: sl_max96712_gmsl_pipeline_setup: GMSL #3 : Link Camera zedx (id: 2) to port-index 2
\[ 537.340821\] sl_max96712 9-0029: sl_max96712_probe: success
\[ 537.349688\] sl_max9295 9-0062: Driver Version : v1.4.0
\[ 537.568418\] sl_max9295 9-0062: probe_serializer: Serializer pipeline operational
\[ 537.570062\] sl_max9295 9-0062: probe_serializer: Serializer for zedx detect success
\[ 537.573710\] sl_max9295 10-0062: Driver Version : v1.4.0
\[ 537.788423\] sl_max9295 10-0062: probe_serializer: Serializer pipeline operational
\[ 537.789178\] sl_max9295 10-0062: probe_serializer: Serializer for zedx detect success
\[ 537.804788\] zedx 9-0020: Driver Version : v1.4.0
\[ 537.805087\] zedx 9-0020: tegracam sensor driver:video1_v2.0.6
\[ 538.134315\] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 9-0020 bound
\[ 538.134989\] zedx 9-0020: ZED-X sensor initialisation done
\[ 538.134992\] zedx 9-0020: zedx_probe: Serial Number : 53906460
\[ 538.135001\] Video device name is video0
\[ 538.135004\] Video device ID is 0
\[ 538.135028\] zedx 9-0020: zedx_probe: success
\[ 538.137847\] zedx 9-0028: Driver Version : v1.4.0
\[ 538.138010\] zedx 9-0028: tegracam sensor driver:video0_v2.0.6
\[ 538.466220\] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 9-0028 bound
\[ 538.466704\] zedx 9-0028: ZED-X sensor initialisation done
\[ 538.466707\] zedx 9-0028: zedx_probe: Serial Number : 53906460
\[ 538.466717\] Video device name is video1
\[ 538.466720\] Video device ID is 1
\[ 538.466757\] zedx 9-0028: zedx_probe: success
\[ 538.468884\] zedx 10-0020: Driver Version : v1.4.0
\[ 538.469000\] zedx 10-0020: tegracam sensor driver:video14_v2.0.6
\[ 538.800209\] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 10-0020 bound
\[ 538.800699\] zedx 10-0020: ZED-X sensor initialisation done
\[ 538.800702\] zedx 10-0020: zedx_probe: Serial Number : 44541403
\[ 538.800710\] Video device name is video2
\[ 538.800712\] Video device ID is 2
\[ 538.800737\] zedx 10-0020: zedx_probe: success
\[ 538.801109\] zedx 10-0028: Driver Version : v1.4.0
\[ 538.801212\] zedx 10-0028: tegracam sensor driver:video13_v2.0.6
\[ 539.128255\] tegra-camrtc-capture-vi tegra-capture-vi: subdev zedx 10-0028 bound
\[ 539.128946\] zedx 10-0028: ZED-X sensor initialisation done
\[ 539.128950\] zedx 10-0028: zedx_probe: Serial Number : 44541403
\[ 539.128957\] Video device name is video3
\[ 539.128960\] Video device ID is 3
\[ 539.128983\] zedx 10-0028: zedx_probe: success
\[ 539.265090\] bmi088 10-003b: removed
\[ 539.265207\] bmi088 9-003b: removed
\[ 539.400406\] bmi088 9-004b: removed
\[ 539.400417\] bmi088: probe of 9-004b failed with error -5
\[ 539.502849\] bmi088 9-003b: probe done
\[ 539.604267\] bmi088 10-004b: removed
\[ 539.604275\] bmi088: probe of 10-004b failed with error -5
\[ 539.705725\] bmi088 10-003b: probe done
Hi @patcharapon-fullstac,
Thank you for the detailed information and logs.
The message Received signal, shutting down... means that the daemon was stopped by an external request, like systemctl restart; it is not a crash. Are these restarts triggered manually or by a watchdog script in your application?
The relevant event is in dmesg, about 507 seconds after boot: the IMU acquisition of both cameras (spsc_bmi0 and spsc_bmi1) fails with an I/O error at the same instant. This means that the I2C control channel over GMSL2 was lost on both links at once, which points to a common cause on the ZED Box side, like power supply or temperature, rather than to a single camera or cable.
It is a likely contributor. The ZED Box Orin operating temperature range is 0 °C to 50 °C, so 40 to 50 °C inside an enclosure under direct sunlight is at the upper limit. The Jetson temperatures reported by jtop do not reflect the temperature of the GMSL2 deserializer and of the power stage.
Power is also worth checking: the ZED Box Orin DC input range is 12 to 19 V, and the cameras are powered from it through the GMSL2 coax. A 12 V lithium battery works at the lower bound of this range, and its voltage drops further under load and while discharging. What is the battery chemistry, and what voltage does it provide under load?
My suggestions:
  1. Upgrade to ZED X Driver v1.4.4 and ZED SDK v5.5.1. Driver v1.4.4 fixed an issue with hybrid ZED X/ZED X Mini configurations, which is your setup.
  2. Shade the enclosure from direct sunlight and improve its ventilation to keep the internal temperature well below 50 °C.
  3. If possible, run an outdoor test with the original power supply to separate the power and thermal causes.
If the problem persists after the upgrade, please share the full sudo dmesg output collected right after the error.
