GMSL@ cable extend
Solution requested for GMSL2
Hi @muthu.swamy,
The GMSL2 connection between a ZED X series camera and the host can be extended using our GMSL2 Fakra Extension Cable M-F, available in lengths from 0.5 m to 15 m.
The extension cable must be chained to the cable that matches your host device:
Please note that the maximum validated total length of a GMSL2 link is 15 m. Each cable-to-cable coupling adds noise and can reduce that length, so use the longest extension available to keep the number of couplings to a minimum.
You can find all the details in the GMSL2 cable guide.
If you need more help choosing the right setup, please share:
  1. The camera model
  2. The host device (ZED Box model or ZED Link capture card with Jetson)
  3. The total distance between the camera and the host
