Hi , I am working with zed2i cam for positional tracking , While trying out positional tracking examples given in the zed-sdk examples , got segmentation fault.
Issue arises only when the area_file_path is set to the previously saved area memory and trying to localize wrt to the world frame.
ZED-SDK version = 4.2
Platform = Orin Nano (Jetpack 6.0 L4T36.3)
Positional Tracking Parameters:
Please let me know is it the issue with sdk or the configuration ? If there is any more issue please let me know
Hi @mathanprasannakumar1,
Welcome to the Stereolabs community
I can confirm that we have already identified a bug in version 4.2.2 of the ZED SDK involving the area relocation file and positional tracking GEN_2.
We are currently investigating the issue and plan on providing a fix in the next patch release 4.2.3.
Hi @mattrouss ,
Thanks for the response and pointing out the underlying bug.
Will the the area memory re-localization will work properly for the lower zed-sdk version with the Positional tracking GEN1 / GEN2 ,
i am also facing the same issue with zed sdk 4.1.3 as well. and what is the suggested Postional tracking mode for area relocalization for now ?
below is the stdout info for the seg fault
The recommended mode for area relocalization is GEN_1 for now, while we work on fixes for GEN_2.
Do I understand correctly that you also have these issues on positional tracking GEN_1?
Hi @mattrouss ,
Thanks for the suggestion , in GEN_1 we havent faced seg fault as of now . But in GEN_1 tracking accuracy is pretty low and facing lot of deviations.
Just letting you know that we have identified the issue and will provide a fix in the next version of the ZED SDK, planned for before the end of the year.
