Dear all,
I want to manage ZED BOX / ZED BOX Mini serial number using software.
Can I get ZED BOX / ZED BOX Mini serial number on the bottom of the device on linux?
Thanks,
Dear all,
Thanks,
Hi @andre.b.kim
When the ZED Box is flashed in production, we set the hostname with the serial number value.
You can retrieve it by using the command
hostname -f
or
cat /etc/hostname
Note: if you reset or reflash the device, the hostname is set to a default value. You can change it again with the command
sudo hostname <your-new-name>
or by editing the file /etc/hostname
