Zed sdk version 4.1
Errors occur on both Zed Box orin with L4T 35.3 and on Ubuntu 22
I am attempting to perform fused pose / GNSS integration with a dataset comprising of a .SVO file and recorded GNSS data.
When I build the zed camera from the .SVO file and subscribe the fusion object to it, it appears that the fusion object is using the systems current timestamp and not the timestamp from the .SVO file.
camera = Camera(source=svo_path,zed_config=self.zed_config)
camera.start_publishing()
dummygps = DummyGPSServer(gps_path)
fusion = Fusion(self.zed_config)
fusion.subscribe(camera)
Checking Fusion process metrics:
fusion.fusion.get_process_metrics()
(SUCCESS, <pyzed.sl.FusionMetrics object at 0xfffee57e34e0>)
special variables
function variables
0:
SUCCESS
1:
special variables
function variables
camera_individual_stats:
mean_camera_fused:
0.0
mean_stdev_between_camera:
0.0
len():
2
Running the image capture sequence:
image = camera.capture()
gps_measurement = dummygps.get_measurement(image.timestamp,tolerance=.5)
>>> image.timestamp
datetime.datetime(2024, 3, 20, 13, 1, 41)
>>> gps_measurement.timestamp()
ingest_status = fusion.add_gps_measurement(**dict(gps_measurement))
>>ingest_status
INVALID TIMESTAMP
Terminal output:
[2024-04-18 20:57:04 UTC][ZED][WARNING] The timestamp of the GNSS data you are attempting to ingest for [GeoTracking] is different from the camera timestamp. Timestamp difference: 1564317192 ms.
Additionally, when I try to retrive measurements/Images from the fusion it does not return anything.
