Fused_cameras : ID problems for tracking
When I use the fused_cameras code found in ZED SDK\samples\body tracking\multi-camera\python>, I extract all the skeleton data as a json file. I noticed that the ids of each skeleton were the same. They appear in the viewer in the same colour.
My objective is to visualise the movement of each skeleton on a 2D map in real time (current position + past position in the form of a trajectory). The code below allows this for a single skeleton. As soon as I have several people in the field of view of the cameras, the code considers that it’s the same skeleton because, I think, it doesn’t distinguish the identifiers.
How can I display all the merged skeletons detected on the same 2D map? When I’m juggling with the different positions, it bugs.
It might be necessary to modify the skeleton class in ogl_viewer. Is this possible? If so, how?
Ce code prend en entrée le fichier de calibration des caméras et permet de :
- détecter et visualiser le squelette fusionné dans le viewer de Stereolabs
- enregistrer un grand nombre de données des squelettes fusionnés à chaque
  timestamps (position, bounding box, keypoints, ...)
- visualiser en temps réel la position actuelle du squelette (poit rouge)
  ainsi que ses précédentes (trajectoire bleu)
- visualiser en temps réel la Heatmap basée sur la position du squelette
import cv2
import sys
import pyzed.sl as sl
import time
import ogl_viewer.viewer as gl
import numpy as np
import json
import matplotlib.pyplot as plt
# Fonctions permettant l'enregistrement de l'ensemble des données des
# squelettes dans un fichier .json
def addIntoOutput(out, identifier, tab):
    out[identifier] = []
    for element in tab:
        out[identifier].append(element)
    return out
def serializeBodyData(body_data):
    """Serialize BodyData into a JSON like structure"""
    out = {}
    out["id"] = body_data.id
    out["unique_object_id"] = str(body_data.unique_object_id)
    out["tracking_state"] = str(body_data.tracking_state)
    out["action_state"] = str(body_data.action_state)
    addIntoOutput(out, "position", body_data.position)
    #addIntoOutput(out, "velocity", body_data.velocity)
    addIntoOutput(out, "bounding_box_2d", body_data.bounding_box_2d)
    out["confidence"] = body_data.confidence
    addIntoOutput(out, "bounding_box", body_data.bounding_box)
    addIntoOutput(out, "dimensions", body_data.dimensions)
    addIntoOutput(out, "keypoint_2d", body_data.keypoint_2d)
    addIntoOutput(out, "keypoint", body_data.keypoint)
    #addIntoOutput(out, "keypoint_cov", body_data.keypoints_covariance)
    addIntoOutput(out, "head_bounding_box_2d", body_data.head_bounding_box_2d)
    addIntoOutput(out, "head_bounding_box", body_data.head_bounding_box)
    addIntoOutput(out, "head_position", body_data.head_position)
    addIntoOutput(out, "keypoint_confidence", body_data.keypoint_confidence)
    #addIntoOutput(out, "local_position_per_joint", body_data.local_position_per_joint)
    #addIntoOutput(out, "local_orientation_per_joint", body_data.local_orientation_per_joint)
    #addIntoOutput(out, "global_root_orientation", body_data.global_root_orientation)
    #print(dir(body_data))
    return out
def serializeBodies(bodies):
    """Serialize Bodies objects into a JSON like structure"""
    out = {}
    out["is_new"] = bodies.is_new
    out["is_tracked"] = bodies.is_tracked
    out["timestamp"] = bodies.timestamp.data_ns
    out["body_list"] = []
    for sk in bodies.body_list:
        out["body_list"].append(serializeBodyData(sk))
    return out
class NumpyEncoder(json.JSONEncoder):
    def default(self, obj):
        if isinstance(obj, np.ndarray):
            return obj.tolist()
        return json.JSONEncoder.default(self, obj)
#  Visualisation du déplacement du squelette sur une map 2D
#  et
#  Création d'une HeatMap
def create_visualization():
    global heatmap_data
    global fig
    global heatmap_plot
    '''# Initialiser la fenĂŞtre OpenGL
    viewer = gl.GLViewer()
    viewer.init()'''
    # Créer une figure pour la carte de chaleur
    fig = plt.figure()
    fig.suptitle("Room Visualization")
    ax_heatmap = fig.add_subplot(121)
    ax_heatmap.set_title("Heatmap")
    heatmap_plot = ax_heatmap.imshow(heatmap_data, cmap='hot', origin='lower', extent=[0, ROOM_WIDTH, 0, ROOM_HEIGHT])
    plt.colorbar(heatmap_plot)
    # Créer une figure pour la carte 2D et la trajectoire
    ax_map2d = fig.add_subplot(122)
    ax_map2d.set_title("2D Map")
    ax_map2d.set_xlabel("X")
    ax_map2d.set_ylabel("Y")
    ax_map2d.set_xlim([0, ROOM_WIDTH])
    ax_map2d.set_ylim([0, ROOM_HEIGHT])
    ax_map2d.grid(True)
def update_visualization(positions):
    global heatmap_data
    global fig
    global heatmap_plot
    global previous_positions
    # Mettre Ă  jour la carte de chaleur
    heatmap_data *= 0.95  # Diminuer progressivement les valeurs existantes pour l'effet de fondu
    for x, y in positions:
        heatmap_x = int(x / ROOM_WIDTH * HEATMAP_RESOLUTION)
        heatmap_y = int(y / ROOM_HEIGHT * HEATMAP_RESOLUTION)
        #heatmap_x = int(min(x / ROOM_WIDTH, 1) * HEATMAP_RESOLUTION)
        #heatmap_y = int(min(y / ROOM_HEIGHT, 1) * HEATMAP_RESOLUTION)
        heatmap_data[heatmap_y, heatmap_x] += 1
    # Mettre Ă  jour l'affichage de la carte de chaleur
    heatmap_plot.set_data(heatmap_data)
    plt.pause(0.001)
    # Mettre Ă  jour la carte 2D et la trajectoire
    fig.clf()
    ax_map2d.grid(True)
    # Trajectoire
    if len(previous_positions) > 0:
        x_coords, y_coords = zip(*previous_positions)
        ax_map2d.plot(x_coords, y_coords, 'b-', label='Trajectory')
    # Position actuelle
    if len(positions) > 0:
        x, y = positions[-1]
        ax_map2d.plot(x, y, 'ro', label='Current Position')
    ax_map2d.legend()
    plt.pause(0.001)
# MAIN
if __name__ == "__main__":
    if len(sys.argv) < 2:
        print("This sample display the fused body tracking of multiple cameras.")
        print("It needs a Localization file in input. Generate it with ZED 360.")
        print("The cameras can either be plugged to your devices, or already running on the local network.")
        exit(1)
    filepath = sys.argv[1]
    fusion_configurations = sl.read_fusion_configuration_file(filepath, sl.COORDINATE_SYSTEM.RIGHT_HANDED_Y_UP, sl.UNIT.METER)
    if len(fusion_configurations) <= 0:
        print("Invalid file.")
        exit(1)
    senders = {}
    network_senders = {}
    # common parameters
    init_params.depth_mode = sl.DEPTH_MODE.ULTRA
    init_params.camera_resolution = sl.RESOLUTION.HD720
    communication_parameters = sl.CommunicationParameters()
    communication_parameters.set_for_shared_memory()
    positional_tracking_parameters.set_as_static = True
    body_tracking_parameters = sl.BodyTrackingParameters()
    body_tracking_parameters.detection_model = sl.BODY_TRACKING_MODEL.HUMAN_BODY_ACCURATE
    body_tracking_parameters.body_format = sl.BODY_FORMAT.BODY_18
    body_tracking_parameters.enable_body_fitting = False
    body_tracking_parameters.enable_tracking = False
    for conf in fusion_configurations:
        print("Try to open ZED", conf.serial_number)
        init_params.input = sl.InputType()
        # network cameras are already running, or so they should
        if conf.communication_parameters.comm_type == sl.COMM_TYPE.LOCAL_NETWORK:
            network_senders[conf.serial_number] = conf.serial_number
        # local camera needs to be run form here, in the same process than the fusion
        else:
            init_params.input = conf.input_type
            senders[conf.serial_number] = sl.Camera()
            init_params.set_from_serial_number(conf.serial_number)
            status = senders[conf.serial_number].open(init_params)
                print("Error opening the camera", conf.serial_number, status)
                del senders[conf.serial_number]
                continue
            status = senders[conf.serial_number].enable_positional_tracking(positional_tracking_parameters)
                print("Error enabling the positional tracking of camera", conf.serial_number)
                continue
            status = senders[conf.serial_number].enable_body_tracking(body_tracking_parameters)
                print("Error enabling the body tracking of camera", conf.serial_number)
                continue
            senders[conf.serial_number].start_publishing(communication_parameters)
        print("Camera", conf.serial_number, "is open")
    if len(senders) + len(network_senders) < 1:
        print("No enough cameras")
        exit(1)
    print("Senders started, running the fusion...")
    init_fusion_parameters = sl.InitFusionParameters()
    init_fusion_parameters.coordinate_system = sl.COORDINATE_SYSTEM.RIGHT_HANDED_Y_UP
    init_fusion_parameters.coordinate_units = sl.UNIT.METER
    init_fusion_parameters.output_performance_metrics = False
    init_fusion_parameters.verbose = True
    fusion = sl.Fusion()
    camera_identifiers = []
    fusion.init(init_fusion_parameters)
    print("Cameras in this configuration : ", len(fusion_configurations))
    # warmup
    bodies = sl.Bodies()
    for serial in senders:
        zed = senders[serial]
            zed.retrieve_bodies(bodies)
            # print(bodies)
    for i in range(0, len(fusion_configurations)):
        conf = fusion_configurations[i]
        uuid = sl.CameraIdentifier()
        uuid.serial_number = conf.serial_number
        print("Subscribing to", conf.serial_number, conf.communication_parameters.comm_type)
        status = fusion.subscribe(uuid, conf.communication_parameters, conf.pose)
        if status != sl.FUSION_ERROR_CODE.SUCCESS:
            print("Unable to subscribe to", uuid.serial_number, status)
        else:
            camera_identifiers.append(uuid)
            print("Subscribed.")
    if len(camera_identifiers) <= 0:
        print("No camera connected.")
        exit(1)
    body_tracking_fusion_params = sl.BodyTrackingFusionParameters()
    body_tracking_fusion_params.enable_tracking = True
    body_tracking_fusion_params.enable_body_fitting = False
    fusion.enable_body_tracking(body_tracking_fusion_params)
    rt = sl.BodyTrackingFusionRuntimeParameters()
    rt.skeleton_minimum_allowed_keypoints = 7
    viewer.init()
    # Create ZED objects filled in the main loop
    single_bodies = [sl.Bodies]
    # Dimensions de la pièce (à adapter selon votre cas)
    ROOM_WIDTH = 10  # Largeur de la pièce en mètres
    ROOM_HEIGHT = 10  # Hauteur de la pièce en mètres
    # Résolution de la carte de chaleur
    HEATMAP_RESOLUTION = 10000  # Nombre de points en x et y pour la carte de chaleur
    # Initialiser la carte de chaleur
    heatmap_data = np.zeros((HEATMAP_RESOLUTION, HEATMAP_RESOLUTION))
    # Positions précédentes pour la trajectoire
    previous_positions = []
    positions = []
    # Initialiser le visualiseur
    while (viewer.is_available()):
        if fusion.process() == sl.FUSION_ERROR_CODE.SUCCESS:
            # Retrieve detected objects
            fusion.retrieve_bodies(bodies, rt)
            # for debug, you can retrieve the data send by each camera, as well as communication and process stat just to make sure everything is okay
            # for cam in camera_identifiers:
            #     fusion.retrieveBodies(single_bodies, rt, cam);
            if bodies.is_new:
                body_array = bodies.body_list
                print(str(len(body_array)) + " Person(s) detected\n")
            skeleton_file_data = {}
                    # enregistrement des données du squelette en fichier json
                    skeleton_file_data[str(bodies.timestamp.get_milliseconds())] = serializeBodies(bodies)
                    # permet de voir le squelette dans le viewer
                    viewer.update_bodies(bodies)
                    # Récupération des données de positions pour la map2D et la HeatMap
                    positions = []
                        x = abs(sk.position[0])  # Coordonnée X du squelette
                        y = abs(sk.position[2])  # Coordonnée Y du squelette
                        positions.append((x, y))
                        #print(positions)
                    # Ajouter les positions précédentes à la trajectoire
                    previous_positions.extend(positions)
                    """# Limiter la taille de la trajectoire
                    if len(previous_positions) > 100:
                        previous_positions = previous_positions[-100:]"""
                    # Mettre Ă  jour la visualisation
            # Save data into JSON file:
            file_sk = open("bodies.json", 'w')
            file_sk.write(json.dumps(skeleton_file_data, cls=NumpyEncoder, indent=4))
            file_sk.close()
    for sender in senders:
        senders[sender].close()
    viewer.exit()
Hi @Antoine ,
I think the tracking is not enabled in the sample code you provided, so the SDK does not distinguish the skeletons by id.
Use body_tracking_parameters.enable_tracking = True instead of false and it should work.
Best,
Jean-Loup
Hi, How do you create your configurations json file? I got error when sl.read_fusion_configuration_file() try to open json file.
Thanks
Here’s one of my codes:
import cv2
import sys
import time
import numpy as np
import json
from tkinter import Tk
from tkinter.filedialog import askopenfilename
import os
# Choisir de travailler à partir du flux vidéo ou de fichiers .svo
def get_file_path():
    Tk().withdraw()
    file_path = askopenfilename()
    return file_path
def display_menu():
    print(" ")
    print("Choose 1 or 2 :")
    print("1. Work with 2 svo file")
    print("2. Work with live stream of cameras")
    print(" ")
def get_user_choice():
    while True:
        choice = input("Enter option 1 or 2 : ")
        if choice in ['1', '2']:
            return choice
        else:
            print("Invalid Option. Please, retry.")
def zed360_file_adapt_to_work_with_svo(filepath):
    svo_paths = {
    "25491013": "path/to/file.svo",
    "27490510": "path/to/file.svo"
    # Charger le premier fichier JSON
    with open(filepath, 'r') as json_file:
        data = json.load(json_file)
    # Mettre à jour les chemins d'accès dans le fichier JSON
    for key, value in svo_paths.items():
        data[key]["input"]["zed"]["configuration"] = value
        data[key]["input"]["zed"]["type"] = "SVO_FILE"
    # Enregistrer les modifications dans le deuxième fichier JSON
    with open('svo_cali.json', 'w') as json_file:
        json.dump(data, json_file, indent=4)
    # Obtenir le chemin absolu du répertoire courant
    current_directory = os.getcwd()
    # Concaténer le nom du fichier pour obtenir le filepath complet
    filepath_svo = os.path.join(current_directory, "svo_cali.json")
    return filepath_svo
def select_live_or_svo(filepath):
    # Afficher le menu
    display_menu()
    # Récupérer le choix de l'utilisateur
    user_choice = get_user_choice()
    # Utiliser le choix de l'utilisateur
    if user_choice == '1':
        print("You choose option 1 : Work with 2 svo file")
        print(" ")
        print("Select the svo files (cam0 and then cam1) corresponding to the recording to be processed")
        print(" ")
        filepath_svo = zed360_file_adapt_to_work_with_svo(filepath)
        # Chargement du fichier JSON
        with open(filepath_svo, 'r') as json_file:
        # Modification des chemins d'accès dans le fichier JSON
        filepath1 = data["25491013"]["input"]["zed"]["configuration"] = get_file_path()
        print("You choose to work with :")
        print("- File 1 : ", filepath1)
        filepath2 = data["27490510"]["input"]["zed"]["configuration"] = get_file_path()
        #print("and")
        print("- File 2 : ", filepath2)
        file_name_with_extension = os.path.basename(filepath1)
        file_name_without_extension = os.path.splitext(file_name_with_extension)[0]
        new_filename = "Calibration_file_for_" + file_name_without_extension + "_1"
        # Extraire le répertoire du fichier
        directory = os.path.dirname(filepath)
        # Construire le nouveau chemin d'accès avec le nouveau nom de fichier
        new_filepath = os.path.join(directory, f"{new_filename}.json")
        print(" ")
        print("New calibration file name : ", new_filepath)
        print(" ")
        # Enregistrement des modifications dans le fichier JSON
        with open(new_filepath, 'w') as json_file:
        # Supprimer le fichier svo intermédiare qui a été créé
        if os.path.exists(filepath_svo):
            os.remove(filepath_svo)
        filepath = new_filepath
    if user_choice == '2':
        print("You choose option 2 : Work with live stream of cameras")
    return filepath
    for element in tab:
    return out
    out = {}
    #addIntoOutput(out, "bounding_box_2d", body_data.bounding_box_2d)
    #addIntoOutput(out, "bounding_box", body_data.bounding_box)
    #addIntoOutput(out, "head_bounding_box_2d", body_data.head_bounding_box_2d)
    #addIntoOutput(out, "head_bounding_box", body_data.head_bounding_box)
    return out
    out = {}
    return out
            return obj.tolist()
# MAIN
        exit(1)
    filepath = select_live_or_svo(filepath)
        exit(1)
    senders = {}
    # common parameters
        else:
                continue
                continue
                continue
        exit(1)
    # warmup
            # print(bodies)
        else:
        exit(1)
    viewer.init()
    HEATMAP_RESOLUTION = 50  # Nombre de points en x et y pour la carte de chaleur
    positions = []
            '''if bodies.is_new:
                print(str(len(body_array)) + " Person(s) detected\n")'''
    file_sk.close()
    viewer.exit()
    plt.close('all')
Does this help?
thanks. That helps me alot.
