Freeze when connecting to a not-started stream
i’m running two instances of ZED Studio on one PC, one streams, the other receives. works as expected when i start the stream before connecting the receiver.
but: when i start the receiver before the streaming source, the receiver freezes forever. when i then try to start the streaming source, i get a popup saying that it cannot start the stream.
is there a way to get the receiver trying to connect non-blocking? and why can’t the streaming source be started when there is a connection pending?
i’m eventually developing using C# where i found the same issue but thought it’s easier to repro using ZED Studio.
Hi @joreg
Is the issue present with the latest v5.3 too?
yes, this is with 5.3
Thank you for the information.
I’ve forwarded all the details to the ZED SDK team.
This behavior will be fixed with one of the next patch releases of the ZED SDK.
