Noticed while testing SDK 5.2 that zed explorer reports a framerate which rapidly toggles between ‘0’ and ‘N/A’ for zed2i, regardless of resolution or selected framerate. No apparent issue with actual image feed, so likely a bug in the way it is being calculated/reported.
Issue appears to be present for both x86 and jetson machines, when using USB-connected zed2i. Does not appear when using GMSL zed-x mini on jetson.
