We want to flash ZED BOX Mini with Jetpack 6.0 + GPIO Enabled.
But I could find only for Jetpack 6.2 on the online manual.
We are preparing manufacture hardware with ZED BOX Mini with Jetpack 6.0 + GPIO Enabled.
So we need the flash script for manufacture.
Hi @andre.b.kim,
Indeed, the current flash script only supports Jetpack 6.2 flashes, this is the recommended Jetpack to use, as it contains the most up-to-date stability fixes from Nvidia for running ZED X cameras for long-term operations.
Do you have specific constraints that require installing Jetpack 6.0? I’ve transferred to the team to see if they can provide a script for jetpack 6.0 as well
Hi Mattrouss,
Because of legacy software dependency which is based on Jetpack 6.0.
So I need your support.
Thank you for your support.
Hi @andre.b.kim,
Could you send an email to support@stereolabs.com so that we can send you the driver?
We will provide the flash script as well.
