The first problem is that Husky is not able to localize itself (localization:=true). The robot reacts (husky_navigation) to RVIZ NAV 2D commands (no map), but I don’t know how to load a previously made map.
I’ve been looking through the .launch files and I don’t understand why this part ( sl_rtabmap.launch.xml) is commented out:
Some tips, parameters, etc. to be able to make Husky load a map, locate within it and navigate using RVIZ 2D NAV commands?
Hi @Augusto
the ZED node uses the depth map and the odometry generated by the ZED SDK, enabling the odometry from RTABmap will generate a conflict unless you set publish_tf to false for the ZED node.
