Hey all
i ran the image capture example and everything worked perfectly however, i couldn’t find the images that were captured saved anywhere.
further more i would like to record the depth sensing data and save it onto a matrix or txt file
thanks in advance
Hi @SaifK2049 the example that you linked only retrieves the data, it does not save them. You must add a few lines of code calling the write method of the sl::Mat object to save the data.
write
sl::Mat
To retrieve depth information you must follow other tutorials: zed-sdk/tutorials/tutorial 3 - depth sensing at master · stereolabs/zed-sdk · GitHub
Here you can find the detailed documentation of each ZED SDK module, object and function.
