Explorer Recording Broken after GPU Settings Change
Hello all, SVO recording has stopped working after I temporarily changed my Graphics settings to force Zed Explorer to use NVIDIA when I was trying to find a way to record with a laptop closed in my backpack for mobility. Restored original settings, reinstalled NVIDIA drivers, reinstalled Zed SDK, still I cannot record except in lossless format in Explorer. I suspect NVENC and Zed SDK are no longer playing nice with each other, but after reinstalling everything I don’t see why it would still be the case, any help is very much appreciated. Thanks!
Hi @Sollyman
Please connect the camera and run the ZED Diagnostic tool, then save the report and share the content here.
Hi @Myzhar, thanks for your reply. If I run Diagnostics without attempting to record first, the report shows no issues. If I try to record and then run diagnostics I have a low USB bandwidth failure. I cannot upload the report because I’m a new user, but the report says:
Low USB bandwidth
Frame drops: 28/500
Frame tearing: 0/500
I’ve noticed another problem that is new: This Zed 2i is no longer recognized by Touchdesigner, reading as “no camera detected”
I need the reports, please.
Otherwise, I have no clues to try to understand the cause of the issue.
