zed_camera.launch.xml defines arguments cam_roll, cam_pitch, cam_yaw to give the orientation of the ZED with respect to the base frame; I can’t find any documentation which indicates what set of Euler angles should be used (szxz, rxyx, ryzy, etc.). The default euler-from-matrix axes used by tf are sxyz; is this also the convention ZED uses?
Hi @joshuaoreilly
The ZED ROS Wrapper always uses the same conventions used by ROS, so Euler XYZ for Roll Pitch and Yaw
Perfect, thank you so much!
