EGL issues when connecting to ZEDX
When attempting to run ZED_Explorer, I’m hitting an issue with EGL.
USER@ubuntu ~ [SIGABRT]> ZED_Explorer
nvbufsurface: Failed to create EGLImage.
(Argus) Error BadParameter:  (propagating from src/common/ScopedNvGlsiEglImageRef.cpp, function reset(), line 39)
(Argus) Error BadParameter:  (propagating from src/rpc/socket/client/CustomMethods.cpp, function createBuffer(), line 524)
#22   Object "[0xffffffffffffffff]", at 0xffffffffffffffff, in
#21   Object "ZED_Explorer", at 0x45f8af, in
#20   Object "/lib/aarch64-linux-gnu/libc.so.6", at 0xffffa52474d7, in __libc_start_main
#19   Object "/lib/aarch64-linux-gnu/libc.so.6", at 0xffffa52473ff, in
#18   Object "ZED_Explorer", at 0x43752f, in
#17   Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffa59741cb, in QCoreApplication::exec()
#16   Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffa596b06b, in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)
#15   Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffa59cb523, in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#14   Object "/lib/aarch64-linux-gnu/libglib-2.0.so.0", at 0xffffa38d3413, in g_main_context_iteration
#13   Object "/lib/aarch64-linux-gnu/libglib-2.0.so.0", at 0xffffa392cf9f, in
#12   Object "/lib/aarch64-linux-gnu/libglib-2.0.so.0", at 0xffffa38d5fa7, in g_main_context_dispatch
#11   Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffa59cb1ab, in
#10   Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffa59ca7e3, in QTimerInfoList::activateTimers()
#9    Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffa596cb8f, in QCoreApplication::notifyInternal2(QObject*, QEvent*)
#8    Object "/lib/aarch64-linux-gnu/libQt5Widgets.so.5", at 0xffffaa9f2abf, in QApplicationPrivate::notify_helper(QObject*, QEvent*)
#7    Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffa599cecf, in QObject::event(QEvent*)
#6    Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffa59ac00f, in QTimer::timeout(QTimer::QPrivateSignal)
#5    Object "/lib/aarch64-linux-gnu/libQt5Core.so.5", at 0xffffa59a7913, in
#4    Object "ZED_Explorer", at 0x4b579b, in
#3    Object "ZED_Explorer", at 0x4b4ca3, in
#2    Object "ZED_Explorer", at 0x4b7743, in
#1    Object "ZED_Explorer", at 0x5f2e13, in
#0    Object "ZED_Explorer", at 0x5c2754, in
Segmentation fault (Address not mapped to object [(nil)])
fish: Job 1, 'ZED_Explorer' terminated by signal SIGSEGV (Address boundary error)
USER@ubuntu ~ [SIGSEGV]>
I’m using a Zed X camera connected to a Zed Link Duo, running on an AGX Orin. I’m running jetpack release 6.2.2, with the 1.4.1 ZEDX driver and ZED SDK 5.2
Running ZEDX_Diagnostics results in a similar error, although the checks with the –dmesg flag pass.
USER@ubuntu ~> ZED_Diagnostic
Stack trace (most recent call last) in thread 2924:
#9    Object "[0xffffffffffffffff]", at 0xffffffffffffffff, in
#8    Object "/usr/lib/aarch64-linux-gnu/libc.so.6", at 0xffff97039e9b, in
#7    Object "/usr/lib/aarch64-linux-gnu/libc.so.6", at 0xffff96fd0397, in
#6    Object "/usr/lib/aarch64-linux-gnu/libstdc++.so.6", at 0xffff972a29cb, in
#5    Object "ZED_Diagnostic", at 0x45a07f, in
#4    Object "ZED_Diagnostic", at 0x4785d7, in
#3    Object "ZED_Diagnostic", at 0x4780df, in
#2    Object "ZED_Diagnostic", at 0x46e6e7, in
#1    Object "ZED_Diagnostic", at 0x595a33, in
#0    Object "ZED_Diagnostic", at 0x5654d4, in
fish: Job 1, 'ZED_Diagnostic' terminated by signal SIGSEGV (Address boundary error)
USER@ubuntu ~ [SIGSEGV]> ZED_Diagnostic --dmesg
 ** Please wait for completion... This might take up to 1 minute **
- Running GMSL DRIVER Diagnostic : OK
- Running Log Kernel Trace (for ZED X) Diagnostic : OK
Running via CLI gives me this information before it crashes.
USER@ubuntu ~> ZED_Diagnostic -c
ZED Diagnostic Tool
- Running ZED SDK Diagnostic : OK
    ZED SDK version: 5.2.3
    CUDA version: V12.6.68
- Running Processor Diagnostic : OK
    Processor:   ARMv8 Processor rev 1 (v8l)
    Motherboard:  Jetson, NVIDIA
- Running Graphics Card Diagnostic : OK
    Graphics card:  Orin
- Running CUDA Operations Diagnostic : OK
    GPU 0 (Orin): CUDA operations working correctly
- Running AI Models Diagnostic : OK
    MULTI CLASS DETECTION is optimized
    MULTI CLASS MEDIUM DETECTION is optimized
    MULTI CLASS ACCURATE DETECTION is optimized
    HUMAN BODY FAST DETECTION is optimized
    HUMAN BODY MEDIUM DETECTION is optimized
    HUMAN BODY ACCURATE DETECTION is optimized
    HUMAN BODY 38 FAST DETECTION is optimized
    HUMAN BODY 38 MEDIUM DETECTION is optimized
    HUMAN BODY 38 ACCURATE DETECTION is optimized
    PERSON HEAD DETECTION is optimized
    PERSON HEAD ACCURATE DETECTION is optimized
    REID ASSOCIATION is optimized
    NEURAL LIGHT DEPTH is optimized
    NEURAL DEPTH is optimized
    NEURAL PLUS DEPTH is optimized
I’ve seen some information in prior posts about needing a dummy HDMI plug, but I’m guessing that since I’m able to get a noVNC instance up and running, and connect and see the applications before this error is hit, that isn’t the case.
You indeed need to have a monitor plugged to your zed box in order to run opengl application (or have a dummy hdmi dongle).
You can also follow this guide to setup a virtual display on your Jetson :
