Do you have a plan to provide RJ45 / USB locking mechanism in the future?
I am considering using the Zedbox mini as the main computing unit for a mobile robotics system. However, I have some concerns about the robustness of the RJ45 cable connection. In mobile robotics, one of the most vulnerable points is the Ethernet (as well as USB) connection, and RJ45 connectors often cause significant issues.
I would like to know if you have any plans to provide special accessories for the current Zedbox—such as reinforced connectors—or if you are considering offering screw-lock type cables or connectors in future products.
Thank you
Thank you for your feedback regarding the use of the Zedbox mini in mobile robotics applications.
We understand your concerns about the robustness of RJ45 and USB connections in such environments.
At the moment, we do not plan to provide reinforced connectors or screw-lock type cables for the current Zedbox.
However, we have taken note of your request and will share it with our technical teams for consideration in future developments.
Sincerely,
Damien
Orders & Shipping
