@Myzhar yes, both machines are operating in MAXN power mode.
When I look at the journal logs while the recording application is running, I’m seeing the following Argus error a lot:
Aug 29 15:18:43 collection-2 nvargus-daemon[1168]: (Argus) Error AlreadyAllocated: Device 0 (of 1) is in use (in src/api/CameraProviderImpl.cpp, function createCaptureSessionInternal(), line 272)
On Machine 1, the error appears every now and then - every 30 seconds or so
On Machine 2, the error is logged constantly - several times per second
Hi @andrew.stringfield
we are trying to replicate your configuration to find a reason to the behavi or that you described.
Can you please run the command sudo ZED_Diagnostic --dmesg and send the report file to support@stereolabs.com?
