Difference in framerate between multi zedx cameras on Jetson
We use multi camera on a jetson Orin. where each camera has his own process to check for object detection.
we see that after some time, the framerate between the difference camera’s is increasing. where 1 camera always drops the framerate to +/- 10fps, and the other stay at 30fps.
this has been verified with the 5.4.1 and 5.5.1 SDK. (we test this on a orin nx16 and orin agx 64gb. with 3 ZEDx camera’s.
how can we adjust this so every camera would get the same fps?
Hi @Martijn,
Thank you for reporting this.
Can you confirm that you can experience the same behavior with our latest benchmark tool available here: GitHub - stereolabs/zed-benchmarks · GitHub
This will allow us to confirm with our officially implementation and monitored implementation.
