Hi, when I run the Depth Viewer I always get the error: " An NVIDIA GPU (Pascal or NEWER) is required to run this software (For Kepler and maxwell GPU, please use cuda 10.2 zed ".
Also the AI model optimization always fails before finishing (tried in Diagnostics GUI and in terminal, both not working).
I use ZED SDK version 4.1.3 and CUDA version: V12.1.66. GPU is Quadro M2000M.
The Quadro M2000M is a GPU card based on the Maxwell architecture, so you can use it only with the ZED SDK for CUDA 10.2.
You must uninstall the current version of CUDA and launch the installer of ZED SDK for CUDA 10.2 which will guide you in installing the required CUDA version.
I recommend upgrading your old GPU card model to obtain the best results with our devices.
