Hello
I’m having bad time trying to install the sdk and make everything work
I want to track body, and that is the one tutorial python script i cannot achieve to run
when i run it it says that cudnn is not installed, but it is, following nvidia’s installation instructions
I tried to run the diagnostic tool, everything is okay, except the ai models that are not optimized, and i cannot find something to make it work, here is the diagnostic
"AI Models": {
"info": [
"NEURAL DEPTH is not optimized"
"Camera Test": {
"InternalDevicesCount": 2,
"ZEDCount": 1,
"camera": {
"Device ID": 0,
"Firmware": 1523,
"Init Output": "OK",
"Model": "ZED 2i",
"Serial Number": 31363832,
"valid": [
"<b>Camera: </b>ZED 2i",
"<b>Firmware: </b>1523"
"resolutions": {
"HD1080@15": {
"fps (input)": 15,
"fps (output)": 15,
"height (input)": 1080,
"height (output)": 1080,
"initialization": "OK",
"status": true,
"width (input)": 1920,
"width (output)": 1920
"HD1080@30": {
"fps (input)": 30,
"fps (output)": 30,
"status": true,
"HD2K@15": {
"fps (input)": 15,
"fps (output)": 15,
"height (input)": 1242,
"height (output)": 1242,
"status": true,
"width (input)": 2208,
"width (output)": 2208
"HD720@15": {
"fps (input)": 15,
"fps (output)": 15,
"height (input)": 720,
"height (output)": 720,
"status": true,
"width (input)": 1280,
"width (output)": 1280
"HD720@30": {
"fps (input)": 30,
"fps (output)": 30,
"status": true,
"HD720@60": {
"dropCount": 3,
"fps (input)": 60,
"fps (output)": 59,
"imageCount": 497,
"status": true,
"tearingCount": 0,
"VGA@100": {
"fps (input)": 100,
"fps (output)": 38,
"height (input)": 376,
"height (output)": 376,
"status": true,
"width (input)": 672,
"width (output)": 672
"VGA@15": {
"fps (input)": 15,
"fps (output)": 15,
"status": true,
"VGA@30": {
"fps (input)": 30,
"fps (output)": 18,
"status": true,
"VGA@60": {
"fps (input)": 60,
"fps (output)": 31,
"status": true,
"sensors": {
"Firmware": 777,
"Model": "ZED 2i (MCU)",
"Graphics Card": {
"deviceCount": 1,
"deviceDriverVersion": 11070,
"devices": [
"arch": "Turing",
"computeCapability": "7.5",
"cores": 3840,
"name": "NVIDIA GeForce RTX 2060",
"totalMemoryBytes": "6442123264",
"totalMemoryMB": 6143.6875
"initResult": 0,
"valid": [
"<b>Graphics card: </b> NVIDIA GeForce RTX 2060"
"Processor": {
"avxSupported": true,
"coreCount": "6",
"cpu": "Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz",
"datetime": "2022-10-24 17:12:01",
"hyperThreading": "1",
"motherboard": "0TTHVM, Dell Inc.",
"ramCapacity": "15.7673",
"ramUsage": "0",
"ramUsed": "6.68895",
"threadCount": "12",
"valid": [
"<b>Processor: </b> Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz",
"<b>Motherboard: </b> 0TTHVM, Dell Inc."
"USB": {
"ASMediaFound": false,
"CorruptedFirmware": false,
"MCUDetected": true,
"OC_Cam_Detected": false,
"OtherUSBDevices": [
"USBList": [
"USBMode": 2,
"USB_path": "/3/2",
"bDescriptorType": 1,
"bDeviceProtocol": 0,
"bLength": 18,
"bMaxPacketSize0": 64,
"bNumConfigurations": 1,
"bcdDevice": "3.9",
"bcdUSB": "2.0",
"bcdUSBClass": 0,
"bcdUSBSubClass": 0,
"busNumber": 3,
"device": "ZED2i MCU",
"iManufacturer": 1,
"iProduct": 2,
"iSerial": 3,
"idProduct": "0xf881",
"idVendor": "0x2b03"
"USB_path": "/11",
"idProduct": "0x0550",
"idVendor": "0x187c"
"USBMode": 3,
"USB_path": "/19",
"bDeviceProtocol": 1,
"bLength": 18,
"bMaxPacketSize0": 9,
"bcdDevice": "1.0",
"bcdUSB": "3.0",
"bcdUSBClass": 239,
"bcdUSBSubClass": 2,
"busNumber": 3,
"device": "ZED2i",
"iManufacturer": 1,
"iProduct": 2,
"iSerial": 4,
"idProduct": "0xf880",
"USBMode": 3,
"USB_path": "/19",
"bLength": 18,
"bcdDevice": "1.0",
"bcdUSB": "3.0",
"bcdUSBClass": 239,
"busNumber": 3,
"device": "ZED2i",
"iManufacturer": 1,
"iProduct": 2,
"iSerial": 4,
"USB_path": "/14",
"idProduct": "0x0026",
"idVendor": "0x8087"
"USB_path": "/5",
"idProduct": "0x5538",
"idVendor": "0x0bda"
"USB_path": "/3",
"idProduct": "0x2512",
"idVendor": "0x0424"
"USB_path": "/5",
"USBMode": 3,
"ZED Camera Module Detected": 63616,
"ZED MCU Module Detected": 63617,
"ZEDDetected": true,
"captureDevices": [
"controllers": [
"CompatibleIDs": "PCI\\VEN_8086&DEV_15E9&REV_06",
"Description": "USB xHCI Compliant Host Controller",
"DeviceName": "Intel(R) USB 3.1 eXtensible Host Controller - 1.10 (Microsoft)",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0003",
"Location": "PCI bus 6, device 0, function 0",
"Manufacturer": "Generic USB xHCI Host Controller",
"Name": "PCI",
"PhysicalName": "\\Device\\NTPNP_PCI0030"
"CompatibleIDs": "PCI\\VEN_10DE&DEV_1ADA&REV_A1",
"DeviceName": "NVIDIA USB 3.10 eXtensible Host Controller - 1.10 (Microsoft)",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0001",
"Location": "PCI bus 1, device 0, function 2",
"Name": "PCI",
"PhysicalName": "\\Device\\NTPNP_PCI0022"
"CompatibleIDs": "PCI\\VEN_8086&DEV_06ED&REV_00",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0000",
"Location": "PCI bus 0, device 20, function 0",
"Name": "PCI",
"PhysicalName": "\\Device\\NTPNP_PCI0007"
"CompatibleIDs": "",
"Description": "USB Root Hub (USB 3.0)",
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0005",
"Location": "",
"Manufacturer": "(Standard USB HUBs)",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-0"
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0004",
"Location": "",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-1"
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0006",
"Location": "",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-2"
"CompatibleIDs": "USB\\USB20_HUB",
"Description": "Generic USB Hub",
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0034",
"Location": "Port_#0001.Hub_#0002",
"Name": "USB",
"PhysicalName": ""
"valid": [
"<b>USB Bandwidth: </b> OK"
"ZED SDK": {
"CUDA Toolkit version": "V11.7.64 -->located in C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v11.7/bin/nvcc.exe",
"CUDA loading": false,
"CUDA_reachable": true,
"ZED SDK Version (Diag)": "3.8.0",
"ZED SDK Version (RT)": "3.8.0",
"ai": {
"checkAI": true,
"cudaVersion": 11070,
"cudnnCudartVersion": 11080,
"cudnnVersion": 8600,
"cudnnVersionExpected": 8401,
"tensorVersion": 8402
"binFiles": [
"cudnn64_8.dll",
"cudnn_adv_infer64_8.dll",
"cudnn_adv_train64_8.dll",
"cudnn_cnn_infer64_8.dll",
"cudnn_cnn_train64_8.dll",
"cudnn_ops_infer64_8.dll",
"cudnn_ops_train64_8.dll",
"nvinfer.dll",
"nvinfer_builder_resource.dll",
"nvinfer_plugin.dll",
"nvonnxparser.dll",
"nvparsers.dll",
"sl_ai64.dll",
"sl_zed64.dll",
"zlibwapi.dll"
"driverVersion": "516.94",
"drivervDllVersion": "31.0.15.1694",
"resourcesFiles": [
"resourcesFilesExpected": [
"objects_performance_2.2"
"runtimeDllVersion": 11070,
"valid": [
"<b>ZED SDK version:</b> 3.8.0",
"<b>CUDA version:</b> V11.7.64"
I’m on windows,
Do you have any suggestions ?
Thanks !
