Hi, I installed entire zed sdk. Now running Zedfu with Zed2i camera:
I get following error:
CUDA Initialisation failed : cudaErrorUnknown
#22 Object “[0xffffffffffffffff]”, at 0xffffffffffffffff, in
#21 Object “/usr/local/zed/tools/ZEDfu”, at 0x55e7624435a4, in
#20 Object “/lib/x86_64-linux-gnu/libc.so.6”, at 0x7f8782e29e3f, in __libc_start_main
#19 Object “/lib/x86_64-linux-gnu/libc.so.6”, at 0x7f8782e29d8f, in
#18 Object “/usr/local/zed/tools/ZEDfu”, at 0x55e76244346b, in
#17 Object “/lib/x86_64-linux-gnu/libQt5Core.so.5”, at 0x7f87838c0cf3, in QCoreApplication::exec()
#16 Object “/lib/x86_64-linux-gnu/libQt5Core.so.5”, at 0x7f87838b875a, in QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag)
#15 Object “/lib/x86_64-linux-gnu/libQt5Core.so.5”, at 0x7f87839130b7, in QEventDispatcherGlib::processEvents(QFlagsQEventLoop::ProcessEventsFlag)
#14 Object “/lib/x86_64-linux-gnu/libglib-2.0.so.0”, at 0x7f87821193e2, in g_main_context_iteration
#13 Object “/lib/x86_64-linux-gnu/libglib-2.0.so.0”, at 0x7f87821706c7, in
#12 Object “/lib/x86_64-linux-gnu/libglib-2.0.so.0”, at 0x7f878211bd3a, in g_main_context_dispatch
#11 Object “/lib/x86_64-linux-gnu/libQt5Core.so.5”, at 0x7f8783913a66, in
#10 Object “/lib/x86_64-linux-gnu/libQt5Core.so.5”, at 0x7f87838bcf26, in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*)
#9 Object “/lib/x86_64-linux-gnu/libQt5Core.so.5”, at 0x7f87838b9e39, in QCoreApplication::notifyInternal2(QObject*, QEvent*)
#8 Object “/usr/local/zed/tools/ZEDfu”, at 0x55e762444e62, in
#7 Object “/lib/x86_64-linux-gnu/libQt5Widgets.so.5”, at 0x7f878456c712, in QApplicationPrivate::notify_helper(QObject*, QEvent*)
#6 Object “/lib/x86_64-linux-gnu/libQt5Core.so.5”, at 0x7f87838e741d, in QObject::event(QEvent*)
#5 Object “/usr/local/zed/tools/ZEDfu”, at 0x55e7624679fc, in
#4 Object “/usr/local/cuda/lib64/libcudart.so.11.0”, at 0x7f8784c681b7, in cudaMemcpy2DToArray
#3 Object “/usr/local/cuda/lib64/libcudart.so.11.0”, at 0x7f8784c18a3c, in
#2 Object “/usr/local/cuda/lib64/libcudart.so.11.0”, at 0x7f8784c44643, in
#1 Object “/usr/local/cuda/lib64/libcudart.so.11.0”, at 0x7f8784c42714, in
#0 Object “/lib/x86_64-linux-gnu/libcuda.so.1”, at 0x7f87852c5915, in
Segmentation fault (Signal sent by the kernel [(nil)])
PLEASE Let me know what more information I should post
It worked when I installed zed from anaconda env.
And launched zed fu from anaconda activated environment
You cuda installation looks broken. If you just installed it, try to reboot.
Otherwise, remove it with
sudo apt purge nvidia-* cuda-* libnvidia-*
sudo rm -rf /usr/local/cuda*
sudo prime-select nvidia
sudo ubuntu-drivers install
The two last lines are especially helpful when using a laptop.
Then install the SDK again.
