I am currently using the Zed X camera for development work on a drone and it worked out of the box with the original cables and settings.
After some initial usage, we accidentally broke the CSI2 MIPI cable that connects the Jetson to the capture card.
We attempted to use a custom cable with the same 22-to-22 pin configuration, but unfortunately, it did not work. Although the camera is detected when running ./ZED_Explorer --all, we are unable to retrieve any images. We also tried using the ROS node, but that did not work either.
To diagnose the issue, we ran the diagnostic tool, and I have attached the diagnostic file for your reference.
We would appreciate your assistance in determining whether the new cable we purchased is the source of the problem. If that is the case, could you advise us on where we can purchase additional compatible cables in Switzerland?
Thank you for your support, and I look forward to your response.
Thanks for the advice! Following your advice, we will plan to buy shorter cables (e.g., 50mm), do you think this cable will be suitable for the platform?
Carrier Board: we are using AIB-SN41-1-A1 (Aetina), link: AIB-SO21/31 | AIB-SN31/41. Since we already tested the carrier board before with the normal CSI2 cable, we can also confirm that the carrier board is not the cause and we contacted the producer Aetina that this board works with the ZEDX setting.
