Hi!
I want to convert the reference frame of the point cloud from the camera coordinate system to the floor, as shown in the image below:
But my following code doesn’t seem to do that, specifically where went wrong
import sys
import pyzed.sl as sl
def main():
zed = sl.Camera()
# Set configuration parameters
init = sl.InitParameters()
init.depth_mode = sl.DEPTH_MODE.ULTRA
init.coordinate_units = sl.UNIT.METER
init.camera_resolution = sl.RESOLUTION.HD1080
# If applicable, use the SVO given as parameter
# Otherwise use ZED live stream
if len(sys.argv) == 2:
filepath = sys.argv[1]
print("Reading SVO file: {0}".format(filepath))
init.set_from_svo_file(filepath)
# Open the camera
status = zed.open(init)
print(repr(status))
exit(1)
cloud = sl.Mat() # current left image
pose = sl.Pose() # positional tracking data
plane = sl.Plane() # detected plane
zed.enable_positional_tracking()
retrieve_cloud_state = False
reset_tracking_floor_frame = sl.Transform()
while True:
tracking_state = zed.get_position(pose)
if tracking_state == sl.POSITIONAL_TRACKING_STATE.OK:
find_plane_status = zed.find_floor_plane(plane, reset_tracking_floor_frame)
if find_plane_status == sl.ERROR_CODE.SUCCESS:
resetTrackingFloorFrame_inverse = sl.Transform()
reset_tracking_floor_frame.inverse_mat(resetTrackingFloorFrame_inverse)
zed.reset_positional_tracking(resetTrackingFloorFrame_inverse)
retrieve_cloud_state = True
break
if retrieve_cloud_state == True:
zed.retrieve_measure(cloud, sl.MEASURE.XYZRGBA)
cloud.write('Pointcloud.ply')
print("successfully save Pointcloud{}.ply")
zed.disable_positional_tracking()
zed.close()
if __name__ == "__main__":
main()
Thank you!
