I have two Zed X One cameras plugged into a Zed Box Mini via Fakra cable for GMSL. They show up in the ZED Diagnostic and both can live stream in ZED Explorer. However, when I try to run the tutorial hello_zed.py from the ZED SDK repo, I get the following error:
[2025-08-22 17:17:08 UTC][ZED][WARNING] CAMERA NOT DETECTED in sl::ERROR_CODE sl::Camera::open(sl::InitParameters)
My setup:
I’m running Nvidia Jetpack 6.2 on Ubuntu 22.04
I have Zed SDK 5.0.5 installed (ZED SDK for JetPack 6.1 and 6.2 (L4T 36.4) 5.0 (Jetson Orin, CUDA 12.6). I followed these steps.
I have the ZED link driver for Jetpack 6.1/6.2 for the ZED Box Mini installed. I followed these steps.
Below are some diagnostics that I have already run:
When I try to check if the devices are connected with sl.Camera.get_device_list(), it returns an empty list.
Running ZED_Explorer --all prints:
## Cam 0 ##
Model : "ZED XOne UHD"
S/N : 317489306
State : "AVAILABLE"
Path : /dev/i2c-2
Type : "GMSL"
## Cam 1 ##
Model : "ZED XOne GS"
S/N : 305929280
State : "AVAILABLE"
Path : /dev/i2c-2
Type : "GMSL"
Running v4l2-ctl --list-devices prints:
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
/dev/media0
vi-output, zedxone_uhd 2-001a (platform:tegra-capture-vi:0):
/dev/video1
vi-output, zedx 2-0011 (platform:tegra-capture-vi:2):
/dev/video0
My ZED_Diagnosic_Results.json is shown below:
"AI Models": {
"info": [
"REID ASSOCIATION is not optimized"
"valid": [
"NEURAL LIGHT DEPTH is optimized",
"NEURAL DEPTH is optimized",
"NEURAL PLUS DEPTH is optimized"
"Camera Test": {
"InternalDevicesCount (GMSL)": 2,
"InternalDevicesCount (USB)": 0,
"ZEDCount": 2,
"ZEDs": [
"Devices": {
"CorruptedFirmware": false,
"GMSL driver": "ii stereolabs-zedbox-mini 1.3.1-SL-MAX9296-all-ZEDBOX-MINI-L4T36.4.0 arm64 NVIDIA Kernel DTB Modified Package by Stereolabs\n",
"GMSLList": [
"Serial": "305929280",
"id": 0,
"path": "/dev/i2c-2",
"state": "Available"
"Serial": "317489306",
"id": 1,
"id": 0,
"id": 1,
"USBList": [
"USB_path": "/1/4",
"idProduct": "0x0411",
"idVendor": "0x0bda"
"USB_path": "/1/3/4",
"idProduct": "0x0620",
"idVendor": "0x05e3"
"USB_path": "/1/3/3",
"USB_path": "/1/3",
"USB_path": "/1",
"USB_path": "/3",
"idProduct": "0x0032",
"idVendor": "0x8087"
"USB_path": "/2/4/4",
"idProduct": "0x49c2",
"idVendor": "0x2939"
"USB_path": "/2/4/3",
"idProduct": "0x6001",
"idVendor": "0x0403"
"USB_path": "/2/4/1",
"USB_path": "/2/4",
"idProduct": "0x5411",
"USB_path": "/2/3/4",
"idProduct": "0x0610",
"USB_path": "/2/3/3/4",
"idProduct": "0x0670",
"idVendor": "0x1992"
"USB_path": "/2/3/3/3",
"USB_path": "/2/3/3/2",
"USB_path": "/2/3/3/1",
"idProduct": "0x374b",
"idVendor": "0x0483"
"USB_path": "/2/3/3",
"USB_path": "/2/3",
"USB_path": "/2/1",
"idProduct": "0x385a",
"idVendor": "0x062a"
"USB_path": "/2",
"GMSL Driver": {
"dmesg": {
"DMESG [DTS] LOG ": [
"dmesg: read kernel buffer failed: Operation not permitted"
"DMESG [MAX9x] LOG": [
"DMESG [PCA] LOG ": [
"DMESG [ZEDX] LOG": [
"DTB list SLabs": [
"board.py",
"extlinux.py",
"fio.py",
"Headers",
"Jetson",
"Linux",
"__pycache__",
"Utils",
"zlconfig"
"DTB list original": [
"/boot/dtb/kernel_tegra234-p3768-0000+p3767-0000-nv.dtb"
"Dpkg list Stereolabs": [
"ii stereolabs-zedbox-mini 1.3.1-SL-MAX9296-all-ZEDBOX-MINI-L4T36.4.0 arm64 NVIDIA Kernel DTB Modified Package by Stereolabs"
"Dpkg list zed": [
"Driver list": {
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max9295/sl_max9295.ko": "exists",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max9296/max9296.ko": "not found",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max9296/sl_max9296.ko": "exists",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max96712/max96712.ko": "not found",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/max96712/sl_max96712.ko": "not found",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedone4k/sl_zedxone_uhd.ko": "exists",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedx/max96712.ko": "not found",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedx/sl_zedx.ko": "exists",
"/usr/lib/modules/5.15.148-tegra/kernel/drivers/stereolabs/zedxpro/sl_zedxpro.ko": "exists"
"EXTlinux file": [
"TIMEOUT 30",
"DEFAULT Stereolabs",
"MENU TITLE L4T boot options",
"LABEL primary",
" MENU LABEL primary kernel",
" LINUX /boot/Image",
" INITRD /boot/initrd",
" APPEND ${cbootargs} root=PARTUUID=bc4fd2c5-edb6-461e-b8dd-fbbc8d78584c rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb video=efifb:off console=tty0",
"# When testing a custom kernel, it is recommended that you create a backup of",
"# the original kernel and add a new entry to this file so that the device can",
"# fallback to the original kernel. To do this:",
"# 1, Make a backup of the original kernel",
"# sudo cp /boot/Image /boot/Image.backup",
"# 2, Copy your custom kernel into /boot/Image",
"# 3, Uncomment below menu setting lines for the original kernel",
"# 4, Reboot",
"# LABEL backup",
"# MENU LABEL backup kernel",
"# LINUX /boot/Image.backup",
"# INITRD /boot/initrd",
"# APPEND ${cbootargs}",
"LABEL Stereolabs",
"\tMENU LABEL Stereolabs kernel",
"\tLINUX /boot/Image",
"\tFDT /boot/dtb/kernel_tegra234-p3768-0000+p3767-0000-nv.dtb",
"\tINITRD /boot/initrd",
"\tAPPEND ${cbootargs} root=PARTUUID=bc4fd2c5-edb6-461e-b8dd-fbbc8d78584c rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb video=efifb:off console=tty0",
"\tOVERLAYS /boot/tegra234-p3768-camera-zedbox-mini-sl-overlay.dtbo"
"I2C Trace list": {
"I2C Trace /dev/i2C-0": [
" 0 1 2 3 4 5 6 7 8 9 a b c d e f",
"00: -- -- -- -- -- -- -- -- ",
"10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"50: UU -- -- -- -- -- -- UU -- -- -- -- -- -- -- -- ",
"60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"70: -- -- -- -- -- -- -- -- "
"I2C Trace /dev/i2C-1": [
"40: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- ",
"I2C Trace /dev/i2C-2": [
"10: -- UU -- -- -- -- -- -- 18 -- UU -- -- -- -- -- ",
"20: -- -- -- -- -- -- -- -- 28 -- -- -- -- -- -- -- ",
"30: -- -- -- -- -- -- -- -- -- -- -- 3b 3c -- -- -- ",
"40: -- -- -- UU UU -- -- -- UU -- -- 4b 4c -- -- -- ",
"50: -- -- -- -- 54 55 56 57 -- -- -- -- -- -- -- -- ",
"60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- -- ",
"I2C Trace /dev/i2C-7": [
"Jetpack": [
"# R36 (release), REVISION: 4.4, GCID: 41062509, BOARD: generic, EABI: aarch64, DATE: Mon Jun 16 16:07:13 UTC 2025",
"# KERNEL_VARIANT: oot",
"TARGET_USERSPACE_LIB_DIR=nvidia",
"TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia"
"Linux_uname": [
"Linux GTW-ONX16-ubuntu 5.15.148-tegra #1 SMP PREEMPT Mon Jun 16 08:24:48 PDT 2025 aarch64 aarch64 aarch64 GNU/Linux"
"ZED SDK Version": {
"Diag": "5.0.5",
"RT": "5.0.5"
"ZEDX Daemon Status LS": [
"● zed_x_daemon.service - ZED-X Daemon service",
" Loaded: loaded (/etc/systemd/system/zed_x_daemon.service; enabled; vendor preset: enabled)",
" Active: active (running) since Thu 2025-08-21 15:51:13 PDT; 46min ago",
" Main PID: 6837 (ZEDX_Daemon)",
" Tasks: 5 (limit: 18451)",
" Memory: 2.9M",
" CPU: 5.553s",
" CGroup: /system.slice/zed_x_daemon.service",
" └─6837 /usr/sbin/ZEDX_Daemon",
"Aug 21 16:05:42 GTW-ONX16-ubuntu ZEDX_Daemon[6837]: [ \"Thu Aug 21 16:05:42 2025\" ][ZED-X Daemon] Port 0 CLOSING for CAM ModeliD 13",
"Aug 21 16:05:43 GTW-ONX16-ubuntu ZEDX_Daemon[6837]: [ \"Thu Aug 21 16:05:43 2025\" ][ZED-X Daemon] Port 0 CLOSING for CAM ModeliD 13",
"Aug 21 16:05:43 GTW-ONX16-ubuntu ZEDX_Daemon[6837]: [ \"Thu Aug 21 16:05:43 2025\" ][ZED-X Daemon] Port 1 CLOSING for CAM ModeliD 13",
"Aug 21 16:05:44 GTW-ONX16-ubuntu ZEDX_Daemon[6837]: [ \"Thu Aug 21 16:05:44 2025\" ][ZED-X Daemon] Port 1 OPENING for CAM ModeliD 13",
"Aug 21 16:05:45 GTW-ONX16-ubuntu ZEDX_Daemon[6837]: [ \"Thu Aug 21 16:05:45 2025\" ][ZED-X Daemon] Port 1 Running for CAM ModeliD 13",
"Aug 21 16:05:45 GTW-ONX16-ubuntu ZEDX_Daemon[6837]: [ \"Thu Aug 21 16:05:45 2025\" ][ZED-X Daemon] Port 1 CLOSING for CAM ModeliD 13",
"Aug 21 16:05:46 GTW-ONX16-ubuntu ZEDX_Daemon[6837]: [ \"Thu Aug 21 16:05:46 2025\" ][ZED-X Daemon] Port 1 OPENING for CAM ModeliD 13",
"Aug 21 16:05:46 GTW-ONX16-ubuntu ZEDX_Daemon[6837]: [ \"Thu Aug 21 16:05:46 2025\" ][ZED-X Daemon] Port 1 Running for CAM ModeliD 13"
"ZEDX Driver State": [
"sl_zedxone_uhd 36864 0",
"sl_zedx 28672 0",
"sl_zedxpro 20480 0",
"sl_max9295 16384 3 sl_zedxpro,sl_zedxone_uhd,sl_zedx",
"sl_max9296 32768 4 sl_zedxpro,sl_zedxone_uhd,sl_max9295,sl_zedx",
"tegra_camera 217088 8 sl_zedxpro,nvhost_isp5,nvhost_nvcsi_t194,sl_zedxone_uhd,nvhost_vi5,sl_zedx",
"videodev 249856 7 v4l2_async,sl_zedxpro,videobuf2_v4l2,tegra_camera,sl_zedxone_uhd,videobuf2_common,sl_zedx"
"i2C Trace": [
"i2c-0\ti2c \t3160000.i2c \tI2C adapter",
"i2c-1\ti2c \tc240000.i2c \tI2C adapter",
"i2c-2\ti2c \t3180000.i2c \tI2C adapter",
"i2c-4\ti2c \tTegra BPMP I2C adapter \tI2C adapter",
"i2c-5\ti2c \t31b0000.i2c \tI2C adapter",
"i2c-7\ti2c \tc250000.i2c \tI2C adapter"
"Graphics Card": {
"deviceCount": 1,
"deviceDriverVersion": 12060,
"devices": [
"arch": "Ampere",
"computeCapability": "8.7",
"cores": 1024,
"name": "Orin",
"totalMemoryBytes": "16415617024",
"totalMemoryMB": 15655.15234375
"glx_info": "OpenGL vendor string: NVIDIA Corporation\nOpenGL renderer string: NVIDIA Tegra Orin (nvgpu)/integrated\nOpenGL core profile version string: 4.6.0 NVIDIA 540.4.0\nOpenGL core profile shading language version string: 4.60 NVIDIA\nOpenGL core profile context flags: (none)\nOpenGL core profile profile mask: core profile\nOpenGL core profile extensions:\nOpenGL version string: 4.6.0 NVIDIA 540.4.0\nOpenGL shading language version string: 4.60 NVIDIA\nOpenGL context flags: (none)\nOpenGL profile mask: (none)\nOpenGL extensions:\nOpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 540.4.0\nOpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20\nOpenGL ES profile extensions:\n",
"initResult": 0,
"valid": [
"<b>Graphics card: </b> Orin"
"Processor": {
"L4T version": "36.4.4",
"OS": "Ubuntu 22.04.5 LTS ",
"avxSupported": false,
"coreCount": "8",
"cpu": " ARMv8 Processor rev 1 (v8l)",
"datetime": "2025-08-21 04:37:46 PM",
"hyperThreading": "0",
"motherboard": "Jetson, NVIDIA",
"ramCapacity": "16.415617",
"ramUsage": "",
"ramUsed": "11.114283",
"threadCount": "8",
"valid": [
"<b>Processor: </b> ARMv8 Processor rev 1 (v8l)",
"<b>Motherboard: </b> Jetson, NVIDIA"
"ZED SDK": {
"CUDA Toolkit version": "V12.6.68 -->located in /usr/local/cuda-12.6/bin/nvcc",
"CUDA loading": false,
"GPU Driver Version": "Driver Version : 540.4.0",
"GPU Performance": " Performance State : N/A",
"ZED SDK Version (Diag)": "5.0.5",
"ZED SDK Version (RT)": "5.0.5",
"ai": {
"checkAI": true,
"cudaVersion": 12060,
"tensorVersion": 100300
"binFiles": [
"libsl_ai.so",
"libsl_zed.so"
"resourcesFiles": [
"neural_depth_5.3.model",
"neural_depth_light_5.2.model"
"resourcesFilesExpected": [
"objects_performance_3.2"
"valid": [
"<b>ZED SDK version:</b> 5.0.5",
"<b>CUDA version:</b> V12.6.68"
Please let me know if you have any ideas here. I am happy to run other diagnostics and reply with the results. Thank you for your help.
-Emerson
