I have two graphics cards, how do I choose which one livelink fusion will run on?
Best,
Kuba
Best,
Kuba
You currently cannot choose which GPU the fusion runs on.
I’ve logged the missing feature internally so it can be added in a future version.
Best,
Update: I just double check and this has been added in the 5.0 release.
You can choose the GPU by using sl::InitFusionParameters::sdk_gpu_id
Hi @BenjaminV thanks for response!
Could you show me solution on the example?
ZEDLiveLinkConfig.json (765 Bytes)
is it will be ok?
Best,
Kuba
You need to directly modify the c++ code for this parameter,
Add init_params.sdk_gpu_id = 1 here : https://github.com/stereolabs/zed-livelink/blob/main/sender-multi-camera/src/main.cpp#L120
Hi @BenjaminV
This solution is not working.
HI,
After some testing, I confirm there is an issue in the current version of the ZED SDK preventing the use of multiple GPUs.
We are currently working on a fix that should be included in the next ZED SDK release.
Sorry for the inconvenience.
Best,
