Hi Stereolabs,
I am using 2 zedx cameras with orin AGX jetson Orin in Jetpack 5.1.1. I can compile all the ros1 packages and launch them, but when I change params in ros_wrapper/params/common.yaml such as ( brightness contrast hue saturation to -1, auto_exposure_gain to false and changed exposure from 10 to 100, the image output from topic /zedx/zed_node/left/image_rect_color and /image_raw never changes, I tried with zed SDK and the image does change a lot. I am not sure what’s the issue, please help me check this. (in general, I need to increase the saturation and make the output image dimmer)
