I am trying to run object detection using the c++ sample code. When I try to run it, the application crashes in nvonnxparser.dll.
Looking around, I found some evidence that it may be related to running ZED Depth Viewer.exe in neural mode; this crashes without giving an error. I tried manually optimizing the AI models using ZED Diagnostics.exe, but this crashes as well.
I have tried reinstalling the ZED SDK, trying different versions of it, and reinstalling CUDA, all of which have made no difference.
Here is my output from ZED Diagnostics:
"AI Models": {
"info": [
"HUMAN BODY 70 FAST DETECTION is not optimized",
"HUMAN BODY 70 MEDIUM DETECTION is not optimized",
"HUMAN BODY 70 ACCURATE DETECTION is not optimized",
"NEURAL DEPTH is not optimized"
"Camera Test": {
"InternalDevicesCount": 2,
"ZEDCount": 1,
"camera": {
"Device ID": 1,
"Firmware": 1523,
"Init Output": "OK",
"Model": "ZED 2i",
"Serial Number": 34988684,
"valid": [
"<b>Camera: </b>ZED 2i",
"<b>Firmware: </b>1523"
"resolutions": {
"HD1080@15": {
"fps (input)": 15,
"fps (output)": 15,
"height (input)": 1080,
"height (output)": 1080,
"initialization": "OK",
"status": true,
"width (input)": 1920,
"width (output)": 1920
"HD1080@30": {
"fps (input)": 30,
"fps (output)": 30,
"status": true,
"HD2K@15": {
"fps (input)": 15,
"fps (output)": 15,
"height (input)": 1242,
"height (output)": 1242,
"status": true,
"width (input)": 2208,
"width (output)": 2208
"HD720@15": {
"fps (input)": 15,
"fps (output)": 15,
"height (input)": 720,
"height (output)": 720,
"status": true,
"width (input)": 1280,
"width (output)": 1280
"HD720@30": {
"fps (input)": 30,
"fps (output)": 30,
"status": true,
"HD720@60": {
"dropCount": 0,
"fps (input)": 60,
"fps (output)": 60,
"imageCount": 501,
"status": true,
"tearingCount": 0,
"VGA@100": {
"fps (input)": 100,
"fps (output)": 97,
"height (input)": 376,
"height (output)": 376,
"status": true,
"width (input)": 672,
"width (output)": 672
"VGA@15": {
"fps (input)": 15,
"fps (output)": 15,
"status": true,
"VGA@30": {
"fps (input)": 30,
"fps (output)": 30,
"status": true,
"VGA@60": {
"fps (input)": 60,
"fps (output)": 48,
"status": true,
"sensors": {
"Firmware": 777,
"Model": "ZED 2i (MCU)",
"Devices": {
"ASMediaFound": false,
"CorruptedFirmware": false,
"MCUDetected": true,
"OC_Cam_Detected": false,
"OtherUSBDevices": [
"USBMode": 3,
"USB_path": "/5/3",
"bDescriptorType": 1,
"bDeviceProtocol": 0,
"bLength": 18,
"bMaxPacketSize0": 9,
"bNumConfigurations": 2,
"bcdDevice": "49.0",
"bcdUSB": "3.0",
"bcdUSBClass": 0,
"bcdUSBSubClass": 0,
"busNumber": 2,
"iManufacturer": 1,
"iProduct": 2,
"iSerial": 6,
"idProduct": 33107,
"idVendor": 3034
"USBList": [
"USB_path": "/1/4",
"idProduct": "0x0608",
"idVendor": "0x05e3"
"USB_path": "/1/4/2/2",
"idProduct": "0x5411",
"idVendor": "0x0bda"
"USB_path": "/2",
"idProduct": "0x2514",
"idVendor": "0x0424"
"USB_path": "/1/4/1",
"idProduct": "0x5029",
"idVendor": "0x18d1"
"USB_path": "/1/4/2/1",
"idProduct": "0xc339",
"idVendor": "0x046d"
"USB_path": "/5/3",
"idProduct": "0x8153",
"USB_path": "/1",
"idProduct": "0x5918",
"idVendor": "0x062a"
"USB_path": "/1/4/2/2/3",
"idProduct": "0xc53a",
"USB_path": "/1/4/2/4",
"idProduct": "0x0aba",
"USB_path": "/1/4/2/2/5",
"idProduct": "0x1100",
"USB_path": "/3",
"idProduct": "0x1866",
"idVendor": "0x0b05"
"USBMode": 3,
"USB_path": "/6",
"bDeviceProtocol": 1,
"bLength": 18,
"bNumConfigurations": 1,
"bcdDevice": "1.0",
"bcdUSB": "3.0",
"bcdUSBClass": 239,
"bcdUSBSubClass": 2,
"busNumber": 2,
"device": "ZED2i",
"iManufacturer": 1,
"iProduct": 2,
"iSerial": 4,
"idProduct": "0xf880",
"idVendor": "0x2b03"
"USB_path": "/1/5",
"idProduct": "0x8347",
"idVendor": "0x291a"
"USB_path": "/4",
"idProduct": "0x3563",
"idVendor": "0x13d3"
"USB_path": "/1/4/2/2/1",
"idProduct": "0x482f",
"idVendor": "0x17ef"
"USBMode": 2,
"USB_path": "/2/2",
"bLength": 18,
"bMaxPacketSize0": 64,
"bcdDevice": "3.9",
"bcdUSB": "2.0",
"bcdUSBClass": 0,
"busNumber": 2,
"device": "ZED2i MCU",
"iManufacturer": 1,
"iProduct": 2,
"iSerial": 3,
"idProduct": "0xf881",
"USB_path": "/1/4/2",
"idProduct": "0x2817",
"idVendor": "0x2109"
"USB_path": "/1",
"USB_path": "/5",
"idProduct": "0x0817",
"USBMode": 3,
"ZED Camera Module Detected": 63616,
"ZED MCU Module Detected": 63617,
"ZEDDetected": true,
"captureDevices": [
"CompatibleIDs": "UMB\\http://schemas.microsoft.com/windows/2006/08/wdp/scan/ScannerServiceType",
"Description": "WSD Scan Device",
"DeviceName": "Xerox 4141",
"Driver": "{6bdd1fc6-810f-11d0-bec7-08002be2092f}\\0002",
"Location": "http://192.168.10.20/ws/",
"Manufacturer": "Xerox",
"Name": "SWD",
"PhysicalName": ""
"controllers": [
"CompatibleIDs": "PCI\\VEN_1022&DEV_1639&REV_00",
"Description": "USB xHCI Compliant Host Controller",
"DeviceName": "AMD USB 3.10 eXtensible Host Controller - 1.10 (Microsoft)",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0000",
"Location": "PCI bus 6, device 0, function 3",
"Manufacturer": "Generic USB xHCI Host Controller",
"Name": "PCI",
"PhysicalName": "\\Device\\NTPNP_PCI0027"
"CompatibleIDs": "USB\\USB20_HUB",
"Description": "Generic USB Hub",
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0026",
"Location": "Port_#0004.Hub_#0005",
"Manufacturer": "(Standard USB HUBs)",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-12"
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0011",
"Location": "Port_#0002.Hub_#0007",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-16"
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0025",
"Location": "Port_#0002.Hub_#0001",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-21"
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0006",
"Location": "Port_#0001.Hub_#0001",
"Name": "USB",
"PhysicalName": ""
"CompatibleIDs": "USB\\USB30_HUB",
"Description": "Generic SuperSpeed USB Hub",
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0005",
"Location": "Port_#0005.Hub_#0001",
"Name": "USB",
"PhysicalName": ""
"CompatibleIDs": "",
"Description": "USB Root Hub (USB 3.0)",
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0003",
"Location": "",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-0"
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0028",
"Location": "Port_#0002.Hub_#0006",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-14"
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0022",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-8"
"DeviceName": "",
"Driver": "{36fc9e60-c465-11cf-8056-444553540000}\\0021",
"Name": "USB",
"PhysicalName": "\\Device\\USBPDO-3"
"valid": [
"<b>USB Bandwidth: </b> OK"
"Graphics Card": {
"deviceCount": 1,
"deviceDriverVersion": 12020,
"devices": [
"arch": "Ampere",
"computeCapability": "8.6",
"cores": 3840,
"name": "NVIDIA GeForce RTX 3060 Laptop GPU",
"totalMemoryBytes": "6441926656",
"totalMemoryMB": 6143.5
"initResult": 0,
"valid": [
"<b>Graphics card: </b> NVIDIA GeForce RTX 3060 Laptop GPU"
"Processor": {
"avxSupported": true,
"coreCount": "8",
"cpu": "AMD Ryzen 9 5900HX with Radeon Graphics ",
"datetime": "2023-08-28 17:32:25",
"hyperThreading": "1",
"motherboard": "G713QM, ASUSTeK COMPUTER INC.",
"ramCapacity": "31.4222",
"ramUsage": "0",
"ramUsed": "11.1359",
"threadCount": "16",
"valid": [
"<b>Processor: </b> AMD Ryzen 9 5900HX with Radeon Graphics ",
"<b>Motherboard: </b> G713QM, ASUSTeK COMPUTER INC."
"ZED SDK": {
"CUDA Toolkit version": "V12.1.66 -->located in C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v12.1/bin/nvcc.exe",
"CUDA loading": false,
"ZED SDK Version (Diag)": "4.0.4",
"ZED SDK Version (RT)": "4.0.4",
"ai": {
"checkAI": true,
"cudaVersion": 12010,
"cudnnCudartVersion": 12020,
"cudnnVersion": 8904,
"cudnnVersionExpected": 8801,
"tensorVersion": 8003
"binFiles": [
"cudnn64_8.dll",
"cudnn_adv_infer64_8.dll",
"cudnn_adv_train64_8.dll",
"cudnn_cnn_infer64_8.dll",
"cudnn_cnn_train64_8.dll",
"cudnn_ops_infer64_8.dll",
"cudnn_ops_train64_8.dll",
"nvinfer.dll",
"nvinfer_builder_resource.dll",
"nvinfer_dispatch.dll",
"nvinfer_lean.dll",
"nvinfer_plugin.dll",
"nvinfer_vc_plugin.dll",
"nvonnxparser.dll",
"nvparsers.dll",
"sl_ai64.dll",
"sl_zed64.dll",
"zlibwapi.dll"
"driverVersion": "536.67",
"drivervDllVersion": "31.0.15.3667",
"resourcesFiles": [
"neural_depth_2.0.model",
"objects_accurate_3.2.model",
"objects_performance_3.2.model"
"resourcesFilesExpected": [
"objects_performance_3.2"
"runtimeDllVersion": 12010,
"valid": [
"<b>ZED SDK version:</b> 4.0.4",
"<b>CUDA version:</b> V12.1.66"
